Australia
Old 11-03-2009, 08:06 PM   #1
YGOAMG
My Ride: 325Ci ClubSport
Send a message via MSN to YGOAMG
Tyre Pressure ... what's yours?
when pumping up ur tyres what tyre pressures do u guys use?
ive also heard of using different pressures on the front than on the back to promote understeer/oversteer ... anyone doing this?
thanks
-Peter
Find me on Instagram
@PeterMarquez346
Originally Posted by all4show View Post
who da F done that?
prestige warehouse or who?
YGOAMG is offline   Reply With Quote
Old 11-03-2009, 08:27 PM   #2
BMW //MPOWER
My Ride: The bus...
thanks
-Peter
I run 34psi at the front & 36psi at the back.
As an aside i've found that a some complaints about understeer & tramlining are actually due to worn FCAB's.
BMW 325Ci MY2004 Individual //M Clubsport Edition, //M Clubsport package, //M Sport 18"s, Manual //M Short Shift, Carbon Black, Black Aluminium Cube Interior.
BMW //MPOWER is offline   Reply With Quote
Old 11-03-2009, 08:29 PM   #3
1q2w3e4r
My Ride: Madone, Beetle
I just ran the same all around on the M3 and M Coupe when I had them. I don't reckon you push the car enough on the street to really worry about it too much in a F/RWD setup.
My M3 was corner weighted though.
|| 0-60 3.3| 60-130 7.1| 1/4 11.054@ 132.89 ||
Check out my movies
1q2w3e4r is offline   Reply With Quote
Old 11-03-2009, 08:32 PM   #4
YGOAMG
ive got 34 all around..
i might to what uve got Brad..
@PeterMarquez346
who da F done that?
Old 11-03-2009, 09:39 PM   #5
Beamer_Boi_83
My Ride: 2006 E46 320Ci Sport
220 front / 260 rear for standard load as per the placard inside the driver's door, checked when tyres cold
Beamer_Boi_83 is offline   Reply With Quote
Old 11-03-2009, 09:42 PM   #6
wilawok
My Ride: MY04 E46 330ci Indiv
My tyre Placard reads 260kpa (38psi) Front and 310kpa (44psi) rear. For the standard staggered 18's
Have found this to be ok for long distance cruising (giving slightly better fuel economy).
But for day to day running I use 36psi front and 38psi rear .
If I run my front at 34psi with the 19's it tramlines....... and the rear at anything over 40psi it skips a bit in bumpy twisty sections....
Hope this helps..........
6 speed short shift man with Aluminium cube interior, MTech II bodykit
19 inch Hamann reps with Dunlop SP Sport Maxx,
Factory TV and Nav, upgraded audio with Alpine, Lanzar and Phoenix Gold Components
Individual Colour Tannin Green
wilawok is offline   Reply With Quote
Old 11-03-2009, 09:45 PM   #7
wilawok
Had my FCABs done just before I put on my 19's and find the tramlining to be a pressure related thing........
Old 11-03-2009, 09:51 PM   #8
M3BAS
My Ride: E46 M3
I run 38 cold all around on the 19's, doesn't seem too harsh.
2005 PY M3
M3BAS is offline   Reply With Quote
Old 11-03-2009, 10:40 PM   #9
Miss325
My Ride: 05 325CiC Individual
40 PSI all round.
Miss325 is offline   Reply With Quote
Old 11-03-2009, 11:37 PM   #10
Ballistic325
My Ride: slow and steady
Like Brad, 34 front, 36 rear. However, I dropped down from 37F / 39R just to try the lower pressure and prefer the feel with the higher pressure, so I will go 36F / 38R. I only have 17s though.
+1 for FCAB change fixes a lot of direction stability issues, and also to Wilawok's comment about tyre pressure playing a part in that.
I can help with
* Reading Codes / Coding your car
* R&R FCAs, Tie Rods, Sway links....
* RTABs
Need an RTAB tool? Or clutch fan and water pump tools? PM me.
Ballistic325 is offline   Reply With Quote
Old 11-03-2009, 11:55 PM   #11
M3_DU
My Ride: '02 M3
Originally Posted by Miss325 View Post
40 PSI all round.
Damn! Why so high?
I run 32psi all around in mine.
M3_DU is offline   Reply With Quote
Old 11-04-2009, 12:31 AM   #12
CortinaD
My Ride: lots
32psi cold F and 34psi cold rear.
CortinaD is offline   Reply With Quote
Old 11-04-2009, 12:40 AM   #13
M3_GTR
My Ride: hates driveways
38 all round
FOR SALE!
M3_GTR is offline   Reply With Quote
Old 11-04-2009, 12:41 AM   #14
YGOAMG
what are FCAB's?
@PeterMarquez346
who da F done that?
Old 11-04-2009, 12:47 AM   #15
CortinaD
My Ride: lots
what are FCAB's?
front control arm bushing(s)
Old 11-04-2009, 12:49 AM   #16
YGOAMG
^^ oh k ye i need mine replaced
@PeterMarquez346
who da F done that?
Old 11-04-2009, 01:01 AM   #17
BrisM3
My Ride: 1990 E30 318is
40 psi all round too.
BrisM3 is offline   Reply With Quote
Old 11-04-2009, 01:10 AM   #18
M3_Aaron
My Ride: E46 M3
38psi
M3_Aaron is offline   Reply With Quote
Old 11-04-2009, 01:56 AM   #19
Miss325
Originally Posted by M3_DU View Post
Damn! Why so high?
Because that is what I was advised to put in them by Continental
Old 11-04-2009, 02:07 AM   #20
sprintman
My Ride: Ex 325CI owner
40 f, 44 r.
sprintman is offline   Reply With Quote
