Australia
Old 11-04-2009, 03:21 AM   #21
Nath
My Ride: MY13 Maloo
38 each corner
26 on the MTB bike
600hp Blown Maloo
Nath is offline   Reply With Quote
Old 11-04-2009, 04:54 AM   #22
TAAXED
My Ride: E92 M3
I'm also running 38psi cold for each wheel on the OEM 19s with Goodyear F1 Asymmetric tyres.
I find that your ideal pressures will depend a lot upon the tyres you run (how hard their sidewalls are) etc, how tall the sidewall is...
Running different pressures F/R will help cause/prevent understeer/oversteer, usually if you have it higher at the front and lower and the back you will cause less understeer and vice versa. Although I've only ever really noticed 2psi differences F/R on the track where you're really pushing the car to it's limits.
If you're finding your car to understeer, then there's a few techniques you can use to help cure this, like trail braking into corners, left-foot braking etc. My personal opinion is that these would make much more of a difference than tyre pressures...
If it's oversteering, which probably isn't likely in a BMW, then it would most likely just be down to how early and how smoothly you're putting the power down when you come out of a corner...
I found that my old S2000 was quite sensitive to tyre pressure changes compared to the M3, I just set it at 38psi all around and leave it, on track though I run about 44psi cold F/R.
2012 - BMW M3 M-DCT (Frozen Grey)
2007 - BMW M3 6MT (Jerez Black) - SOLD
2002 - BMW M3 SMGII - SOLD
TAAXED is offline   Reply With Quote
Old 11-04-2009, 05:56 AM   #23
ASSAIL
My Ride: E46 328, Jza80 Supra
low profile tyres should be run at 38+ psi
normal profile just go by ur tyre placard.
and do your pressures with cold tyres, not after uve been driving for 10 mins as the pressures increases as the tyres warm up.
ASSAIL is offline   Reply With Quote
Old 11-04-2009, 06:15 AM   #24
Wobbi
My Ride: 325Ci
standard car and standard suspension i dont think it would matter, anything between 33-40psi.
low profile tyres, bit more pressure.
i use to run different pressures in an awd, just to get more traction to the front end, but now you really wont notice it on the street.
having tight steering in the beemer feels good, so keep em all around 38psi
Life is not measured by the breaths we take, but the moments that take our breath away...
George Carlin
Wobbi is offline   Reply With Quote
Old 11-04-2009, 08:39 AM   #25
LKG
My Ride: MY13 Golf R
40F and 38R 19" on Goodyear F1 Asymmetrics, less understeer which is what I prefer.
LKG is offline   Reply With Quote
Old 11-04-2009, 07:20 PM   #26
Atlas
My Ride: 320i
Send a message via ICQ to Atlas
32 psi all around...
Atlas is offline   Reply With Quote
Old 11-04-2009, 07:25 PM   #27
TAAXED
My Ride: E92 M3
I'm glad I read your post because I used to be under the impression that lowering front pressures would help the front dig in more, as softening the suspension, sways etc. does. But as it turns out it's actually around the other way with the pressures...so higher pressure = more grip basically right?
BTW how are you finding the tyres?
Old 11-04-2009, 08:02 PM   #28
YGOAMG
My Ride: 325Ci ClubSport
Send a message via MSN to YGOAMG
TAAXED - i was under the impression that less pressure = more grip..
Find me on Instagram
@PeterMarquez346
Originally Posted by all4show View Post
who da F done that?
prestige warehouse or who?
YGOAMG is offline   Reply With Quote
Old 11-04-2009, 08:05 PM   #29
TAAXED
My Ride: E92 M3
So was I...but I just looked around on a few websites and it seems that we're not correct...softening front suspension, sway bars etc. will create more front end grip and adding some front toe-out will give you better turn in (but your car will get tugged left and right on small imperfections in the road)
Old 11-04-2009, 08:28 PM   #30
Ballistic325
My Ride: slow and steady
^ hmm I might try 38 all round then. I hate the way it has a little understeer tendency in some corners. If I wanted a FWD, I would have bought a Civic!
Vtec yo!
I can help with
* Reading Codes / Coding your car
* R&R FCAs, Tie Rods, Sway links....
* RTABs
Need an RTAB tool? Or clutch fan and water pump tools? PM me.
Ballistic325 is offline   Reply With Quote
Old 11-04-2009, 09:00 PM   #31
BMW //MPOWER
My Ride: The bus...
Same, they did a top gear thing on this from memory.
The only time more pressure = more grip was on salt.
BMW 325Ci MY2004 Individual //M Clubsport Edition, //M Clubsport package, //M Sport 18"s, Manual //M Short Shift, Carbon Black, Black Aluminium Cube Interior.
BMW //MPOWER is offline   Reply With Quote
Old 11-04-2009, 09:07 PM   #32
TAAXED
My Ride: E92 M3
Yeah on their road trip to America, that's more related to traction, not grip...two different things...
I'm confused about the whole thing now, only way to work it out is to test it!
Old 11-04-2009, 09:43 PM   #33
1q2w3e4r
My Ride: Madone, Beetle
All depends on the rubber as well with tyre pressures and grip on turn in. No point in comparing pressures on a Potenza RE555's, Direzza, Cup Sport or R888 with what you run in a road tyre.
|| 0-60 3.3| 60-130 7.1| 1/4 11.054@ 132.89 ||
Check out my movies
1q2w3e4r is offline   Reply With Quote
Old 11-04-2009, 10:06 PM   #34
Miss325
My Ride: 05 325CiC Individual
I thought the same...
I remember when I went 4wd'ing in the saudi desert the drivers all let half the air out of their tyres (not that that is really relevant to driving on tar though).
Miss325 is offline   Reply With Quote
Old 11-04-2009, 10:17 PM   #35
Worx
Euro tuner
My Ride: BMW
in my car, I don't care as long as they are not flat.
Worx is offline   Reply With Quote
Old 11-04-2009, 11:22 PM   #36
LKG
I researched this a while back, obviously lowering pressure will increase grip if we are talking straight line.
But when cornering, it reduces the stiffness of the sidewalls since E46 are inherently understeery, reducing the rear pressure helps alleviate this somewhat.
Lots more mucking around to do when I buy some sways + coils.
These tyres are awesome for street, I run out of balls before the tyres even thinks about giving up.
Great in the wet, incredible in the dry, and predictable when it does lose grip, well worth the money IMO.
Old 11-04-2009, 11:23 PM   #37
BMW //MPOWER
My Ride: The bus...
Yeah they also let all the air out of the tyres in the Arctic Adventures one when they were going through the softer snow...
Old 03-22-2010, 06:10 AM   #38
mpower_m3
My Ride: 335i M Sport
Send a message via MSN to mpower_m3
Originally Posted by M3_DU View Post
Damn! Why so high?
I run 32psi all around in mine.
lol 40 is too high indeed. i run 32s F 33s R
08' 335i M Sport
00' MB E55 AMG
87' BMW E30 325e
99' BMW E46 323i - SOLD
05' TRD Aurion SL3500 - SOLD
mpower_m3 is offline   Reply With Quote
Old 03-22-2010, 08:18 PM   #39
Ballistic325
I changed to 37 all round on 17s and am enjoying that so far. Reduced tramlining, comfortable and firm enough ride too.
I can help with
* RTABs
Old 03-22-2010, 09:44 PM   #40
Miss325
Wow, this thread is back from the dead again, and still running 38-40 PSI
