Old 11-04-2009, 09:16 AM   #1
sooper
My Ride: '99 323i
Help: How do i do a smoke test for air leak?
I installed an AA SC and my car has been going on limp mode. I then discovered that the vacuum hoses were not placed right and air was leaking out. Last weekend i re worked the vacuum hoses. The car still goes on limp mode once in a while, particularly when i turn on the engine. I do a few on and off starting of the engine and then it goes back to normal. Im suspecting that i still have a leak somewhere and plan to do a smoke test next weekend, also change the idle control valve.
I got hand of a smoke machine which i borrowed. It is usually used before for discos to produce artificial fog. I plan to pump the smoke over the engine bay and look for leaks. Is this the right way of doing this test?
Another question, do i still have to check for codes and delete them? I plan to do so after the smoke test and ICV install. Thanks, help is most welcome.
sooper is offline   Reply With Quote
Old 11-04-2009, 09:23 AM   #2
jhsoccerodp
My Ride: 2001 330ci SC & 99M3
does it actually produce pressure from the machine? if so you have to make sure the smoke is safe for the engine. If so you can go in through the oil dipstick or through the supercharger outlet to intercooler or intake manifold if you dont have a IC
"If only there was a passing lane for the passing lane"
jhsoccerodp is offline   Reply With Quote
Old 11-04-2009, 09:28 AM   #3
sooper
My Ride: '99 323i
yup the machine produces some pressure. The smoke is vapor from a liquid used for the machine. It is safe for human inhalation though and leaves no residue.
Old 11-04-2009, 09:47 AM   #4
sooper
My Ride: '99 323i
Im not sure though if it is safe for the engine. Would i detect leaks if i smoke the vac lines from the outside?
Old 11-04-2009, 10:23 AM   #5
Rob1796
My Ride: 2006 350Z
I'd think you'd be better off doing the soapy water test. Hasn't failed me yet, and you don't need to worry about pumping anything into the engine bay.
2006 Alpine White M3
Rob1796 is offline   Reply With Quote
Old 11-04-2009, 10:39 AM   #6
sooper
My Ride: '99 323i
Good idea..
Old 11-04-2009, 11:06 AM   #7
TxZHP04
My Ride: ESS TS2+ ZHP
Not likely. If you have smoke blowing all around in the engine bay, what would you see to indicate a leak?
Typically the smoke is injected inside the engine under light pressure (ideally around the peak boost pressure your motor sees) and then you look to see where it escapes. You would also need to block off the intake at the MAF, etc to be able to pressurize the intake.
For soapy water, you still need to pressurize the intake but instead of putting smoke in the engine you spray soapy water on the outside of the various connections and hoses where leaks might occur and look for bubbles.
Old 11-04-2009, 01:40 PM   #8
Activ3
My Ride: gets DRIVEN.
Send a message via AIM to Activ3
You need to make a plug that will fit in to and seal your intake pipe. Then bore a hole in the plug and inject the smoke from there, it should travel through the blower and all charge piping right up to your TB. If there are any leaks, you'll see smoke start to appear from where the leak is. If the system is sealed, you should see no smoke at all.
-David www.e46nonm.com | My Videos
2000 328i - Custom Turbo tuned by AA
Activ3 is offline   Reply With Quote
Old 11-04-2009, 07:37 PM   #9
sooper
My Ride: '99 323i
Oh, so the smoke is from the inside of the system. Thanks for the replies!
Old 11-05-2009, 06:58 AM   #10
bigjae1976
bigjae1976's Avatar
My Ride: 2011 E90 M3
http://www.ehow.com/how_4969007_check-vacuum-leaks.html
Is this a good DIY?
2013 F30 328i - Melbourne Red
2004 E46 M3 - Imola red
Old 11-05-2009, 07:44 AM   #11
sooper
My Ride: '99 323i
great site
