Thread Tools Search this Thread Rating: Thread Rating: 197 votes, 4.92 average. Display Modes
Old 11-05-2009, 01:44 AM   #1
neil1138
The Official E46 Parts List: Maintenance Items
Disclaimer: everyone knows the Xi is an exception to every single rule so this thread does not cover the Xi and/or iT. Some parts will be the same but it is mainly for the early E46s, nonetheless I will add full 323/325/328/330 i/Ci/Cic support later. And make every part number clearer for some people. Use this list at your discretion, as always, I am not liable for mis-ordered parts.
Hey guys, Neil again
I see threads all the time asking for part numbers so I decided to compile a list of the most common maintenance items on E46s. I know this is a lost cause but you have to try anyway. With the exception of a few parts categories, I think this list is all encompassing. This list is all OEM parts, no aftermarket. So in places like what brake pads to use, I have only listed OEM pads. All of the part numbers root from my car, a 2000 328Ci. I have paid careful attention to where models matter and have indicated as such. If you know the part number is different for your car, tell me and I can add it in! Enjoy
Here is how the lists are sorted:
• # in diagram | Part Name - Part Number, $Cost
If you see a diagram reference number of 0, it is because the part listed doesn't correlate to the diagram above it. The manual parts conversion part doesn't have diagram reference numbers right now. I will put them later.
Front End Suspension: Some of the common wear and tear items are Control Arm Bushings as everybody has experienced I'm sure. Also the ball joints on the stock Control Arms go bad frequently and because they are pressed in, you have to replace the entire arm. Some part numbers for wheel bearings (If you have a groaning noise coming from your wheel when driving). And if you hear clunking while going over bumps your strut tower mount could be bad. Swaybar endlinks are also common wear items if you are lowered on stock suspension components.
  • 6 | Control Arm (Wishbone), Left - 31126777851 $344.95
  • 6 | Control Arm (Wishbone), Right - 31126777852 $344.95
  • 7 | Control Arm Bushings, D=66MM (CABs) - 31126783376 $202.95
  • 1 | Wheel Bearing D=83MM, Front - 31226757024 $288.50
  • 1 | Upper Shock Mount (To 11/2003) - 31336752735 $78.54
  • 1 | Upper Shock Mount (From 11/2003) - 31336760943 $78.54
  • 5 | Swaybar Endlinks - 31356780847 $56.04
Rear End Suspension: Oh the dreaded CV joints, you will hear the squealing all the time while driving. Also some part numbers for common maintenance items like the rtabs and rear strut mounts which blow out all the time, guaranteed. Lift your trunk lining to check
  • 1 | Output Shaft (CV Joint), Left (From 01/1998) - 33211229707 $539.05
  • 1 | Output Shaft (CV Joint), Right (From 01/1998) - 33211229708 $539.05
    For vehicles with an Automatic transmission:
    • 1 | Output Shaft (CV Joint), Left - 33211229591 $539.05
    • 1 | Output Shaft (CV Joint), Right - 33211229592 $539.05
  • 4 | Rear Trailing Arm Bushings (RTABs) - 33326770786 $33.46
  • 3 | Rear Wheel Bearing - 33411130617 $91.54
  • 7 | Rear Strut Tower Mounts (Common item, get Z3M reinforcement plates) - 33521092362 $42.04
Steering: Power Steering pumps are not so common failures on these cars but it does happen here and there. There are 2 kinds of pumps you can get, one is what we like to call 'over-boosted' and it makes the car feel artificial. If you have a loose feeling in the steering wheel, be sure to check your flexible steering coupling as it is a very common wear item. All of the hoses you need are included if you need to replace your ps pump
  • 1 | Power Steering Pump (LUK LF-30) - 32411094965 $556.99
  • 1 | Power Steering Pump (LUK LF-20) - 32416760036 $556.99
  • 4 | Power Steering Pulley - 32421740858 $45.34
  • 7 | Ribbed V-Belt - 11281706545 $51.48
  • 0 | Power Steering Cap Gasket O-ring - 32411128333 $3.45
  • 1 | Power Steering Intake Line (To 09/2001) - 32411095526 $40.85
  • 1 | Power Steering Intake Line (From 09/2001) - 32416750155 $52.29
  • 3 | PS High Pressure Line - 32416774215 $296.10
  • 2 | Flexible Steering Coupling (To 04/2001) - 32306752957 $61.21
  • 2 | Flexible coupling for steering (From 04/2001) - 32301094703 $61.21
Brakes: I personally don't mind OE brake pads, they do dust a lot but I have no complaint about the bite
  • Front Brake Pads - 34116761244 $103.18
  • Front Brake Rotors (328) - 34111164539 $110.85
  • Brake pad wear sensor (Front) - 34351164371 $23.94
  • Bolts (new rotor to hub) - 34211161806 $1.38
  • Rear Brake Pads - 34216778168 $110.12
  • Rear Brake Rotors (328) - 34211165563 $120.78
  • Brake Pad Wear Sensor (Rear) - 34351164372 $25.23
Engine related parts/seals/gaskets: A bad rear main seal is very evident. You will have oil spewed all over the bottom of the transmission and if it is bad enough, it will make your clutch start to slip if you own a manual. Crank and Cam sensors are pretty common occurrences in e46s and the oil level sensor is also a known maintenance item. I've included the VCG as just a common replacement item
  • 1 | Rear Main Seal Kit - 11141438274 $118.25
  • 8 | Crankshaft Position Sensor - 12141709616 $126.19
  • 1 | Oil Pan - 11131432703 $544.19
  • 8 | Oil Pan Gasket - 11131437237 $60.62
  • 3 | Drain plug - 11131273093 $5.34
  • 14 | Oil Level Sensor - 12617508003 $204.38
  • 12 | Dipstick O-ring - 11431740045 $2.62
  • 16 | Valve Cover Gasket - 11129070990 $48.06
  • 18 | Intake Camshaft Position Sensor - 12147539165 $136.60
  • 5 | Exhaust Camshaft Position Sensor - 12147518628 $136.60
  • 6 | Exhaust/Intake CPS O-ring - 12141748398 $1.20
  • 0 | Cylinder Head Gasket - 11127501305 $149.79
CCV Set: If you live in a cold climate these things blow all the time. You will notice your oil disappearing as it is being burned because of the failure of this vapor separator. All of the lines are included as you need to replace them as well, they become brittle and break as the result of oil and age.
  • 1 | Pressure regulating valve - 11617533400 $82.22
  • 2 | Vent pipe - 11617533398 $35.10
  • 3 | Connecting line - 11617533399 $42.34
  • 4 | Vent hose - 11157532629 $19.21
Flywheel (Manual):
  • 1 | Dual Mass Flywheel - 21217512474 $979.76
  • 5 | Pilot Bearing - 11211720310 $28.03
Engine oil related: The Oil Filter Housing Gasket is a very common seal you should check if your car is leaking oil heavily. Oil level sensor is listed here as well.
  • 2 | Oil Filter with O-ring - 11427512300 $14.16
  • 6 | Oil Filter Housing Gasket - 11421719855 $8.09
  • 0 | Oil Level Sensor - 12617508003 $204.38
Link to oil change kit: Tischer Oil Change Kit
Belts/Pulleys Engine: A lot of people have problems with their mechanical belt tensioner failing and as a result they need to replace it obviously. But BMW stopped making the mechanical tensioner so here is the part number to buy the new hydraulic tensioner.
  • 1 | Ribbed V-Belt (Accessory) - 11281706545 $51.48
  • 21 | Hydraulic Belt Tensioner - 11287838797 $87.05
Cooling System Related: The Achilles' heel of the e46. The cooling system is the most common failure item on these cars from my experiences. BMW has always been weak at making good cooling systems but nonetheless, here are the parts you need to buy for a full overhaul.
  • 2 | Fan Clutch - 11527505302 $252.76
  • 1 | Replacement Fan Clutch Blade - 11521712058 $76.12
  • 4 | Thermostat - 11537509227 $96.97
  • 1 | Water Pump - 11517527910 $144.7
  • 1 | Upper Radiator Hose - 17127510952 $41.22
  • 3 | Lower Radiator Hose - 11531436408 $33.91
  • 4 | Auto Thermostat - 17111437362 $57.40
  • 5 | Expansion Tank - 17117573781 $99.29
  • 6 | Radiator cap - 17111742231 $17.82
  • 0 | 1 Gal BMW Antifreeze - 82141467704 $15.00
  • 0 | Block Drain Plug crush washer - 07119963200 $0.38
Link to Cooling System kit: Tischer Kit
Intake/Exhaust System: A low idle can come from a bad idle control valve or even the adjuster unit (DISA unit) in some cases. These are easy items to replace so the part numbers have been included for these. O2 sensors go bad all the time, especially the pre-cat ones. If you ever take off your exhaust, new gaskets should be ordered so here are the part numbers for those as well. Also, a lot of people don't know this but your exhaust hangers go bad all the time.
  • 7 | Idle Control Valve - 13411744713 $264.10
  • 6 | Adjuster unit - 11611440049 $315.56
  • 1 | Pre-cat O2 Sensors (Qty. 2) - 11781742050 $269.56
  • 2 | Post-cat O2 Sensors (Qty. 2) - 11781433940 $269.56
  • 0 | Exhaust Manifold Gasket - 11621732969 $49.79
  • 0 | Exhaust Flat Gasket - 18301440183 $14.91
  • 2 | Exhaust Rubber Mounts - 18207503246 $26.76
  • 0 | Secondary Air Pump - 11727553056 $499.40
Engine Electrical System: Oh boi, ignition coils and spark plugs. These are self explanatory, if you car is misfiring and you think it's a coil or spark plug, order a new one.
  • Ignition coil (Bremi) - 12131748018 $95.06
  • Ignition coil (Bosch) - 12131703228 $95.06
  • Spark plug: NGK BKR6EQUP - stock #: 3199
  • Spark plug socket (Bremi) - 12139067831 $17.44
  • Spark plug socket (Bosch) - 12131740477 $17.44
  • Starter (Bosch) - 12411740379 $298.68
Fuel Supply:
  • 0 | Fuel Pump, Right - 16146766942 $351.71
  • 0 | Fuel Level Sensor, Left - 16116768788 $108.44
  • 0 | Fuel filter - 13321740985 $55.05
  • 0 | Fuel Pressure Regulator - 13531729319 $93.88
  • 0 | Throttle Body (323/328) - 13541433414 $725.64
  • 5 | Rubber Boot (Tube Elbow) - 13541435627 $17.96
  • 1 | Mass Air Flow Meter (323/328) - 13621432356 $502.90
  • 0 | Air Filter (OEM) - 13721730946 $35.62
  • 0 | Gas Cap - 16116756772 $16.75
Engine/Transmission/Clutch:
  • 1 | Clutch Kit - 21201223687 $280.34
  • 5 | Clutch Release Fork - 21511223302 $21.75
  • 0 | Universal Joint aka Guibo - 26117511454 $151.16
  • 0 | Engine Mounts - 22116771361
  • 2 | Transmission Mounts (Qty. 2) - 22316771219 $19.75
  • 0 | Transmission Oil Filter Set (GM) - 24117557070 $105.69
  • 0 | Transmission Oil Filter (ZF) - 24341423376 $33.05
Common OEM E46 Part Numbers:
  • Cabin Microfilter - 64311000004
  • Round Steering Wheel Airbag - 32306757891
  • ZHP Perforated Leather Steering Wheel - 32347906682
  • ZHP Alcantara Steering Wheel - 32347919218
  • M3 SMG Paddle Shift Alcantara Steering Wheel - 32342282502
  • M3 Stitched Leather Steering Wheel - 32342282022
  • Center Console - 51168218305
  • Window Regulator Coupe - 51338229105
  • Window Regulator Sedan (front) - 51337020659
  • Window Regulator Sedan (rear) - 51358212099
Exterior (Mtech II):
  • Mtech II Kit Coupe/Vert - 51710302082
  • Mtech II Kit Sedan - 51710139650
  • Mtech II/M3 Foglight, Left - 63177894017
  • Mtech II/M3 Foglight, Right - 63177894018
A lot of people experience what is called a "sticky 5th gear." If you decide to do the 5th/reverse fix, it's very wise to fix the shifter pins as well because the transmission is already out. There are 3 shifter pins plus the pins for 5th/reverse.
5th Gear Sticky Fix:
  • Reverse Gear/5th Gear Fix
    • 0 | Repair kit (Qty. 2) - 23117542726
    • 12/14 | Locking pins - 23317502165 / 23311224849
    Shift Pin Service
    • 28 | Repair kit (Qty. 3) - 23117525048
    • 25 | Sealing caps (Qty. 3) - 23317222988
And to end, my Comprehensive Manual Conversion Parts List (Includes every tranny related part). This list contains most of the manual transmission wear items so I am including it. This is for my 328Ci so if you have a 323/325/330, some parts will have different parts number. This is pretty much the official 5 speed parts list. Prices are listed next to the parts, most of them are from Pelican parts or BavAuto. Some of the bigger parts you can get at BMA Parts or even the dealer, it's all the same. All of the prices are listed considering the quantity of the parts. So those are the prices for those listed numbers of parts.
Gearbox Support:
  • 1 - GEARBOX SUPPORT------------------------22316769911------$37.95
  • 4 - HEX BOLT WITH WASHER-----------------22311091785------$4
Linkage Parts:
  • 1 - SHIFTING ARM ---------------------------- 25111434109-----$19.95
  • 1 - BUSH BEARING OVAL --------------------- 25117507695-----$2.95
  • 1 - BEARING BOLT ---------------------------- 25111221849-----$4.95
  • 1 - BEARING, SHIFTING ARM ---------------- 25111222015-----$16.95
  • 1 - BEARING, SHIFT LEVER ------------------ 25111220600-----$10
  • 1 - RUBBER BOOT ---------------------------- 25117522149-----$18
  • 4 - PLASTIC WASHER ------------------------- 25111220439----$2
  • 2 - CIRCLIP -------------------------------------25111220379----$1.85
  • 1 - GEARSHIFT ROD JOINT --------------------25111222688----$13.95
Pedal Assembly:
  • 1 - BRAKE PEDAL ---------------------------- 35206752649------$30.95
  • 1 - RUBBER PAD ----------------------------- 35211160422------$4.95
  • 3 - FLAT FUSES ------------------------------ 07129934921 ----- $3
  • 4 - BUSH BEARING -------------------------- 35211158290 ----- $8
  • 4 - GROMMET -------------------------------- 35411113728------ $4
  • 1 - RETURN SPRING -------------------------35301165321 ----- $1
  • 1 - CLUTCH SWITCH STARTLOCK------------61318363710 -----$40
  • 1 - CLUTCH PEDAL -------------------------- 35311163870 ----- $36
  • 1 - PIN, MASTER CYLINDER -----------------35311163874------$3
  • 1 - RUBBER PAD -----------------------------35211108634------ $4.95
  • 1 - CLIP -------------------------------------- 51488245867------$1
Flywheel:
  • 1 - Dual Mass Flywheel ---------------------- 21217512474----$979.76
  • 1 - GROOVED BALL BEARING ----------------11211720310-----$9.95
Clutch:
  • 1 - BALL PIN ---------------------------------- 21511223328-----$1.95
  • 6 - FILLISTER-HEAD SCREW------------------07119901023-----$6
Clutch Control:
  • 1 - INPUT CYLINDER CLUTCH --------------- 21526758822 -----$68
  • 1 - HEX BOLT --------------------------------- 07119901539 ----- $.95
  • 1 - HEX BOLT M6X45 ------------------------- 07119912324 ---- $.95
  • 1 - SELF-LOCKING HEX NUT ---------------- 07129900191 ----- $1
  • 1 - PIN, MASTER CYLINDER ----------------- 35311163874 ----- $1.25
  • 1 - GROMMET -------------------------------- 21521156082 ----- $1.50
  • 1 - PIPE -------------------------------------- 21526753332 ----- $18
  • 1 - SUPPORT PRESSURE HOSE---------------21521163906 ----- $1
  • 1 - RUBBER GROMMET------------------------21521165819 ---- $1.50
  • 1 - CLIP -------------------------------------- 34341163565 ----- $1
  • 1 - PIPE -------------------------------------- 21526774230 ----- $17.50
  • 2 - SELF-LOCKING HEX NUT ---------------- 07129904877 ---- $2
  • 2 - SELF-LOCKING HEX NUT ---------------- 07129906196 ----- $2
  • 1 - GROMMET -------------------------------- 21521163894 ----- $1.50
  • 1 - PIPE CLIP -------------------------------- 16121176767 ------ $1
  • 1 - MODULE, CLUTCH SWITCH---------------61316 905900 ---- $35
  • 2 - ADAPTER LEAD ---------------------------61116911072 ----- $14
  • 1 - HOSE ------------------------------------- 21521163714 ----- $9.75
Driveshaft Components:
  • 6 - HEX BOLT ---------------------------------26117523709-----$18
  • 6 - SELF-LOCKING HEX NUT ---------------- 07129900047-----$6
Exhaust Suspension:
  • 1 - BRACKET -----------------------------------18311728254
  • 2 - HEX BOLT ---------------------------------- 07119901120
  • 4 - RUBBER BUSHING ------------------------ 18207546579
  • 2 - HEX BOLT ---------------------------------- 07119913111
  • 2 - SELF-LOCKING HEX NUT ----------------- 07129964675
  • 1 - EXHAUST SUPPORT ----------------------- 18301436331
  • 1 - CLAMP LOWER ---------------------------- 18101433250
  • 1 - HEX BOLT ---------------------------------- 07119904533
Gearbox Mounting:
  • 2 - TORX BOLT -------------------------------- 23001222891
  • 2 - TORX BOLT -------------------------------- 23001222894
  • 3 - TORX BOLT -------------------------------- 23001222887
  • 1 - HEX BOLT ----------------------------------07119904094
  • 2 - DOWEL ------------------------------------ 11117524470
  • 2 - TORX BOLT ---------------------------------07129904681
Parts you might need if they don't already come with the transmission:
  • 1 - OUTPUT CYLINDER,CLUTCH---------------21526766279 --------$50.91
  • 1 - VENT SCREW ----------------------------- 21521116360
  • 1 - DUST CAP -------------------------------- 34111153198
  • 1 - Center Mount -----------------------------26127501257
  • 1 - SPRING CLIP ----------------------------- 21511223234
  • 1 - SPRING CLIP ----------------------------- 21517570284
Fluids:
  • Motor Oil 5W-30 LL-01 - 07510017866 $6.25
  • Differential fluid - Redline 75w-90
  • Transmission Fluid (Automatic GM (A5S360R) Tranny) - Texaco ETL - 7045 or DexronŽ III. Do not mix Texaco ETL - 7045 and DexronŽ III fluids. Information on page 3 as to why it is 7045 and not 7045E, per a real BMW service document. I'm not adding 8072B fluid here as that is for Xi's and iT's and this list covers i/Ci/Cic as stated in the disclaimer at the top.
  • Transmission Fluid (Automatic ZF Tranny) - ESSO LT 71141, BMW Part No. 83229407807
  • Manual Tranny: From model year 2004 some manual transmissions are filled with Castrol "MTF-LT-2" long-term fluid. This fluid has the same properties as the "MTF-LT-1" fluid indicated above in section D. The "MTF-LT-1" fluid may be mixed and/or substituted for the "MTF-LT-2" manual transmission fluid. Esso/Exxon MTF-LT-1 BMW Part No. 83229408942.
  • Power Steering Fluid - ATF only, must be Dexron III approved.
  • Brake Fluid - ATE Super Blue, factory BMW DOT 4 fluid is preferred (Any high quality DOT 4 fluid will work)
Well that is it for now guys, I know I still need to add some common interior wear items and I will eventually, but I'm tired of using etk right now, haha. As always, www.realOEM.com is my guide. But if you like my threads, rate them accordingly. Thank you!
-Special thanks to Matt for helping me compile a list
-The crush washer for the oil drain plug was added by bmwbun, great addition if you ask me
neil1138 is offline   Reply With Quote
Old 11-05-2009, 01:44 AM   #2
m1356guy
My Ride: is worth $5k
m1356guy is offline   Reply With Quote
Old 11-05-2009, 01:46 AM   #3
Snik
Snik's Avatar
My Ride: IR M3 Vert.
2nd?
Do you ride a sportbike?
Old 11-05-2009, 01:46 AM   #4
Snik
Snik's Avatar
yaaay i got 2nd and 3rd. lol
Old 11-05-2009, 01:46 AM   #5
JJR4884
My Ride: BMW
meh, kpeng has done better
j/k j/k good thread neil, thanks
JJR4884 is offline   Reply With Quote
Old 11-05-2009, 01:55 AM   #6
SHOF
My Ride: 911TT, E46 M3
SHOF is offline   Reply With Quote
Old 11-05-2009, 02:13 AM   #7
sonaldinho89
My Ride: e90 325i 6MT
good work! thanks neil
sonaldinho89 is offline   Reply With Quote
Old 11-05-2009, 02:16 AM   #8
burntass
My Ride: ///m3 vert, 05 MCS
nice work
2005 ///m3 cb/cinnamon vert: weekends
2005 Mini Cooper S/jet black hardtop: daily
1988 e30 325ix/gray hardtop: gone
2002 e46 tiag 325ci vert: gone
burntass is offline   Reply With Quote
Old 11-05-2009, 07:37 AM   #9
sonspot
My Ride: 330I Spot/Prem/cold
yeeep
sonspot is offline   Reply With Quote
Old 11-05-2009, 08:30 AM   #10
zhp pilot
Falling from 14k ft.
zhp pilot's Avatar
My Ride: is totaled :(
and
JK, thanks to you and Matt for taking the time.
'04 Silbergrau Metallic ZHP 6MT
zhp pilot is offline   Reply With Quote
Old 11-05-2009, 09:16 AM   #11
BMW#1_323i
My Ride: Loves curves!
Sticky this! Thanks..Very informative!
BMW#1_323i is offline   Reply With Quote
Old 11-05-2009, 09:33 AM   #12
Chriztofor
My Ride: 2000 323i (Auto)
For most BMW problems start off by reading your codes using a peake research tool. Note, as mentioned by other members, although Autozone checks your codes for free they use a generic OBDII tool that does not have the BMW specific fault codes.
Chriztofor is offline   Reply With Quote
Old 11-05-2009, 09:45 AM   #13
kelis_ac
My Ride: 2003 325i
kelis_ac is offline   Reply With Quote
Old 11-05-2009, 09:51 AM   #14
Whammy
My Ride: ZHP
Subscribed!
Whammy is offline   Reply With Quote
Old 11-05-2009, 09:56 AM   #15
kraimer
My Ride: 04 330Ci, 00 323it
Send a message via AIM to kraimer
good job man!
now back it up with images and diagrams
kraimer is offline   Reply With Quote
Old 11-05-2009, 01:43 PM   #16
snowcatxx87
My Ride: 04 330CI
E46 for life!
snowcatxx87 is offline   Reply With Quote
Old 11-05-2009, 02:18 PM   #17
neil1138
Originally Posted by m1356guy View Post
First
Who gives a damn?
Because you are first in my thread that makes you important or something? get outta here
Originally Posted by kraimer View Post
good job man!
Will do, thanks to everyone
Old 11-05-2009, 03:12 PM   #18
Chris-alfonso
My Ride: 330i
Thanks for taking the time to do this. Hopefully people wont need to post what pn things are.
MODS STICKY THIS
Chris-alfonso is offline   Reply With Quote
Old 11-05-2009, 03:36 PM   #19
MitchSF
My Ride: 11 M3 DCT
Thanks for the excellent work! I'm sure this will save many hours of searching and it will become a very useful and popular reference. IMHO, a sticky is well deserved for this.
I'm very interested in the sticky fifth fix, since my clutch will need replacing in a few months.
Two part numbers are listed for the locking pins. Are two of each needed for a total of four locking pins? Are sealing caps not required for 5th/reverse?
I seem to remember a DIY for this, but I can't find it at the moment.
* Reverse Gear/5th Gear Fix
o Repair kit (Qty. 2) - 23117542726
o Locking pins - 23317502165 / 23311224849
Shift Pin Service
o Repair kit (Qty. 3) - 23117525048
o Sealing caps (Qty. 3) - 23317222988
MitchSF is offline   Reply With Quote
Old 11-05-2009, 03:44 PM   #20
SWINFORD
///PIITB
SWINFORD's Avatar
My Ride: Low Life Marie
Send a message via AIM to SWINFORD Send a message via MSN to SWINFORD
Vey nice Neil
Swinford-Hypnotyzd : Dirty South-Swinny
| Hypnotyzd FB |Tischer BMW|
SWINFORD is offline   Reply With Quote
bushings, check list, control arms, maintenance, official, part, part number
