Old 11-05-2009, 04:46 PM   #1
mvrk10256
My Ride: E30 325i
header CEL fix help
Ok so i was on bimmerfest doing my research about getting headers.
my dillema is much like the others, i want the power, but dont want the CEL and would preferably like to pass OBD II inspection.
so basically the defouler thing is less then 50% approval rate but i did find this.
http://www.vfaq.com/mods/O2bypass.html (not a bmw our wires are under hood.
so i have done a ton of searching on both e46fanatics and bimmerfest and teh internet in general, i was wondering if there were people on here that did this mod and did it work? i am currently talking to a guy on bimmerfest about how he did his, he claimes he did it underhood and has gone 5K+ miles with no CEL, the car throws no codes and he said that he passed OBDII inspection and the guy who did the visual check thought the resonators were cats......
so basically has anyone done it this way? has it worked for extended periods of time?
My buddy (dakkon) has his stocks on his 330 atm but he had headers and still has them, and wants to put em back on but only if he can pass inspection and get rid of the light. the defouler thing failed for him. once i get all the details from the bimmerfest guy we may try to put em back on and do this but i am trying to gather as much hard data as possible first. if it works i will get them over winter break as well ..
thanks in advance guys.
Old 11-05-2009, 05:02 PM   #2
mvrk10256
My Ride: E30 325i
EDIT: link to original thread: http://www.bimmerfest.com/forums/sho...t=ebay+headers
EDIT2: The two WHITE wires are just for heating the tip. They remain hooked up and working. The black and gray SENSING wires are cut from the sensor and the 'SIM' that you create by soldering those components together acts as the sensor by mimicing a proper voltage feedback.
an update here is what that guy sent me.
2- 1uf Tantalum Capacitor # 272-1434
1- Pack of 1MegaOhm 1/4Watt resistors #271-1356
from the drawers in radio shack
Take one resistor and one capacitor. Polarity does not matter. and solder them together in paralell with the black and gray wires after cutting them at the sensor harness on top of the engine. Leave the two white heater circiut wires hooked up and sensors in the headers for reliability. Costs about $3 plus a piece of heat shrink tubing.
I used that link you had a referenced,but that one also added a heavy duty ceramic resistor in order to completly elimonate the O2 sensor. Those resistors dont last thats why I left my sensors in the headers and just worked with the black and grey wires under the center engine cover.
I cut the wires and slipped a piece of heat shrink onto each one. I then bent the resisor leads to match the cap. and twised them together in paralle. I soldered one half to a gray an one to the black wire and slid the heat shrink up over the connections. I then put on a third piece of heat shrink over every thing from the top to seal it off.
This is done for each of the two the rear sensors, which the plugs and connectors are on the TOP of the engine,not the ones directly above the manifold. You may understand those pics a litte better now.
he said it worked for him and one other guy who did it. 100% success rate.
Old 11-06-2009, 10:38 AM   #3
mvrk10256
My Ride: E30 325i
is there really no one on this site that has done this?
Old 11-09-2009, 11:37 PM   #4
Len013091
My Ride: S52 E30, 330i
Send a message via AIM to Len013091
I have, and it does work.
Len013091 is offline   Reply With Quote
Old 11-11-2009, 01:31 PM   #5
mvrk10256
My Ride: E30 325i
awsome. thats one. we will probably do the car during winter break.
Old 12-03-2009, 09:34 PM   #6
BMW04E46
My Ride: 2004 325Ci SMG
awesome info!
2005 Acura TL A-Spec
2004 325Ci SMG M-tech II (Sold and got 2005 Acura TL A-Spec) :-(
2002 530i Sport
1997 Mercedes Benz C280 Sport (Sold and got 2002 530i Sport!) :-)
2007 Yamaha VX Cruiser (WaveRunner)
see my garage for pics
How a Rogue IKON should look on a M-Tech II Coupe
http://forum.e46fanatics.com/showthread.php?t=537372
BMW04E46 is offline   Reply With Quote
Old 12-06-2009, 01:41 AM   #7
mvrk10256
My Ride: E30 325i
Originally Posted by BMW04E46 View Post
awesome info!
your welcome. it will be even better when we actually do it to my buddies car cause then we will have real pics.
Old 12-06-2009, 02:12 AM   #8
bimmerfan1990
Modded ///Member
My Ride: BMW ///M3
Keep us updated on if it works or not
bimmerfan1990 is offline   Reply With Quote
Old 12-06-2009, 11:24 AM   #9
mvrk10256
My Ride: E30 325i
will do.
Old 01-03-2010, 05:52 AM   #10
s142s14a
My Ride: E46 M3
Has anyone tried these?
http://www.o2simulator.com/index.php...products_id=10
I guess so..
http://www.o2simulator.com/index.php...&reviews_id=18
I bought myself a set of e-bay headers and i haven't installed them because of the CEL issue. I'm going to order one of the dual channel units from the site above and I'll report back with my findings.
s142s14a is offline   Reply With Quote
Old 01-03-2010, 05:16 PM   #11
mvrk10256
My Ride: E30 325i
I guess so..
thanks, i like to be cheap. and i am pretty sure these do the samething, except its more plug and play, and lesss DIY.
Old 01-12-2010, 07:21 AM   #12
techy330
My Ride: 01' 330ci
hey i did this and i am getting codes 1156,1152,1138,1135 now. I did drive for about a month without the mod so the check engine light was always on, could the back o2's throwing a code for so long possibly cause a front one to go bad??
techy330 is offline   Reply With Quote
Old 01-12-2010, 07:21 AM   #13
techy330
My Ride: 01' 330ci
Old 01-13-2010, 06:48 PM   #14
mvrk10256
My Ride: E30 325i
sorry i was not checking this thread.
did you do it right? as in did you cut the right wires? cause it doesnt matter if the O2 sensor is bad. what it does is alllows the heating wires to keep working (there is no sensor on them) and the actual o2 sensor wires get the cap and resistor, so they mimic the positive signal.
i do not know what those codes are from the top of my head, but to guess i would say you soldered the cap and resistor in the wrong way. take a look at your setup and get back to me so we can troubleshoot.
Old 01-13-2010, 07:45 PM   #15
e4sixxx
My Ride: 2000 328ci
subscribed
e4sixxx is offline   Reply With Quote
Old 01-14-2010, 01:07 AM   #16
bimmerfan1990
Modded ///Member
My Ride: BMW ///M3
I wish I was more electrically inclined so I could take this on. I'd love some headers without a CEL
Old 01-14-2010, 02:58 PM   #17
e4sixxx
My Ride: 2000 328ci
i did this last night after reading the post, i did everything correct but on the way to work this morning the SES came back on..... i hope its for a different trouble code, as i did run a "d2" code along with the o2 codes. i will check using my peak tool when i get home. i will keep you guys posted.
Old 01-14-2010, 06:44 PM   #18
e4sixxx
My Ride: 2000 328ci
i know this has been beaten to death but....
which o2 sensors do codes e3 and e4 pertain to? pre cats or post cats? thanks...
Old 01-20-2010, 07:04 PM   #19
mvrk10256
My Ride: E30 325i
I hope someone can chime in on this, cause i am really unsure. i know iits only the post cat o2 sensors that should have been modified.
Old 01-21-2010, 09:54 PM   #20
dpgrand
My Ride: 2005 330xi
If you throw codes from headers, you have to the codes cleared. They will not go away on their own.
'05 330xi - Koni, H&R, Rogue, Supersprint, UUC, Dinan, Apex
dpgrand is offline   Reply With Quote
323, 330, cel, ebay headers, mil eliminator
