Old 02-02-2010, 04:21 PM   #21
e4sixxx
My Ride: 2000 328ci
i cleared the codes after doing this mod, the mod cleared the post cat codes, but i am still throwing pre cat codes.
e4sixxx is offline   Reply With Quote
Old 02-02-2010, 05:51 PM   #22
mvrk10256
My Ride: E30 325i
pre cat codes, have to be bad 02 sensors. have you swapped those? also check the wires, possibly got dammaged in the swap?
Old 03-18-2010, 01:10 PM   #23
mvrk10256
My Ride: E30 325i
So i finally did this, and accoding to my computer my o2 sensors are in order but the car randomly throws these codes under acceleration. any help?
p0173, p0170, p1189, p1188
Old 04-21-2010, 12:19 AM   #24
e4sixxx
My Ride: 2000 328ci
what codes do those codes translate to according to the peak tool?
Old 05-12-2010, 07:18 PM   #25
JT325
My Ride: 2003 325i
These codes seem to indicate a lean mixture. I would check for any vacuum leaks, or other air intake leaks. Start looking for things you may have caused in the areas where you were working (broken crankcase vent valve hoses, etc.), but also check common vacuum leaks like the intake air boot. These codes may not be related to the o2 sensor mod as the rear o2 sensors have no effect on fuel mixtures. Just my 2 cents.
JT325 is offline   Reply With Quote
Old 05-27-2010, 11:02 AM   #26
powerstrokenstang
My Ride: '00 328i
anyone know which wire is for the sensor signal and which one is sensor ground. i got the o2 sims and need to wire them up.
2000 328i 4door 5spd-clear corners, markers, cdv delete, cai, lost resonator, bavauto race springs, koni adjustables, uuc race trans mounts, turner subframe reinforment kit and solid diff mounts, 3.46 gears, ebay headers, 3.0 intake manifold, 18's.
powerstrokenstang is offline   Reply With Quote
323, 330, cel, ebay headers, mil eliminator
