Old 11-06-2009, 08:21 PM   #1
ajv85483
My Ride: E46 325I
Thermosat failed!! 2000 323ci
So I'm looking at a car for sale. Seller says the car heats up after 20min city running. He says a mechanic stopped by and said that the thermostat had failed.
Any idea how much a repair of that nature will cost? Any information/ advice is helpful
ajv85483 is offline   Reply With Quote
Old 11-06-2009, 10:31 PM   #2
TxZHP04
My Ride: ESS TS2+ ZHP
On a car that age with unknown maintenance history, I would HIGHLY recommend a complete cooling system overhaul. Could be looking in the neighborhood of $1500 or more if paying someone to do a complete overhaul.
Not that I recommend it but for just a thermostat, the thermostat is ~ $75 and I could replace it and then top off and bleed the cooling system in less than an hour so figure a couple of hours for shop labor plus parts... maybe $300?
