Old 11-07-2009, 10:09 PM   #1
zero assault
My Ride: 2012 BMW M3
Unplugged negative terminal on the battery, and now my dash is a xmas tree
Title says it all, I unplugged the negative terminal on my battery, plug it back in and most of my dash is lit up. How do I reset this? I really don't remember this happening any other time I did work on the car. Is it because I didn't leave it unplugged long enough?
zero assault is offline   Reply With Quote
Old 11-07-2009, 10:55 PM   #2
zero assault
So I went out and unplugged it again and left it off for about 45 minutes and still nothing, so I can rule that out. I posted the original post rather quickly so I'll add in some more details. Basically I unplugged the negative terminal on the battery for about 30 seconds to reset the computer, I plug it back in and now the BRAKE, ABS, DSC lights are lit up in yellow on my dash. How do I get this to go away?
(Mods if this is in the wrong section, my apologies, please move it to the correct section)
Old 11-08-2009, 12:30 AM   #3
xi_ter
My Ride: 2003 325xi
You need to drive the car and the brake related lights BRAKE,ABS and DSC will go out.
Old 11-08-2009, 02:25 AM   #4
zero assault
Yeah, I went back out there and turned the car on and they were off. I was a little frustrated but at least now I know for next time.
Old 11-10-2013, 11:16 PM   #5
wentworth3
My Ride: 2003 330Xi
Massive thanks for this post! Just did a oil filter gasket change, replaced coolant tank, and replaced both belts. Removed the negative terminal from the battery overnight. Was massively stressing after brake, abs & dsc lights came on after i got it all back together! All of which shut off after i pulled out of the garage.
wentworth3 is offline   Reply With Quote
