Old 11-09-2009, 12:10 PM   #1
spennI
My Ride: 2004 330i
PS Cap/Reservoir Gunk
Before cleaning my engine bay several months back I noticed a lot of gunk on the PS reservoir cap and down the side of the reservoir. A month later and I now noticed gunk on the cap and down the sides of the reservoir. I don't see any ps fluid on my garage floor but a little on the lines attached to the reservoir. It appears the fluid is coming from the cap (maybe the cap isn't tight enough )
Is this a case where the clamps need replacing? Do I have too much fluid in the reservoir? I checked and the fluid level looks fine?
Thoughts, please.
spennI is offline   Reply With Quote
Old 11-10-2009, 02:05 PM   #2
barfoot1
My Ride: 2002 325xi
I had the same problem on my 325, the body of the reservoir would be caked in grime. Assuming your cap is not damaged, try replacing the cap O-ring (#3 in the picture below), that worked for me.
barfoot1 is offline   Reply With Quote
Old 11-10-2009, 02:37 PM   #3
spennI
My Ride: 2004 330i
Barfoot1: I'll give that a try.
Old 12-07-2009, 05:13 PM   #4
spennI
My Ride: 2004 330i
I replaced the PS reservoir, cut 1/2" off both hoses, replaced both clamps w/ screw clamps and no more leaks.
Old 12-08-2009, 05:17 AM   #5
///Mechanic
My Ride: None currently
There is nothing wrong. There is a breather hole in the cap. No matter what you do to the system, or no matter what you 'think' you fixed, you will never always have a clean reservoir.
YOU BOUGHT A BMW, IF YOU CANT AFFORD TO MAINTAIN IT............SELL IT.
///Mechanic is offline   Reply With Quote
Old 12-08-2009, 08:45 AM   #6
spennI
My Ride: 2004 330i
Hmmmmmm I C.
Old 12-08-2009, 07:39 PM   #7
ZR1Trev
My Ride: '03 325i
This may be true, but I know that my O-ring (item 3 in diagram above) was rock hard and deformed. I replaced it and there was a big improvement in the amount of fluid seepage on the outside of the reservoir.
ZR1Trev is offline   Reply With Quote
Old 12-08-2009, 10:38 PM   #8
///Mechanic
If you see obvious damage like that, I can see it resolving a large amount of it. That is probably from over-tighening it.
Old 02-20-2010, 08:29 PM   #9
4G63 T
My Ride: 330i
any part number on #3?
4G63 T is offline   Reply With Quote
Old 02-21-2010, 10:20 AM   #10
ZR1Trev
My Ride: '03 325i
You can find the part number on realoem.com. Part number is: 32411128333
Autohausaz.com or pelicanparts.com has it for around $1.50 plus shipping.
