Old 11-11-2009, 03:04 PM   #1
Colmomalley811
My Ride: 2001 E46
Strange noise in steering. Help please
Hi I have a 01 320d and when I lock my steering wheel left while its moving I get a noise its like the noise of a cv joint gone on a front wheel drive car I replaced my drop links and was hanging on all the bushings but could'nt figure out what the problem was. It seems strange to me that I only have a noise when I'm turning left and is fine when I'm turning right. Anyone have any ideas what the problem could be
Colmomalley811 is offline   Reply With Quote
Old 11-11-2009, 09:09 PM   #2
simonappolis
My Ride: 2002 M3 Cabrio
I had a similar sounding problem with my 02 M3. Turned out to be sand/dirt that had gotten into the bearing at the top of the strut. Only made the noise turning in one direction. I fixed it by partially removing the strut, taking out the bearing assy and then cleaned, lubricated and reinstalled. Noise gone. There's a DIY for strut replacement that was very helpful. Good luck!
Mark
simonappolis is offline   Reply With Quote
Old 11-12-2009, 07:56 AM   #3
Colmomalley811
My Ride: 2001 E46
Thanks very much for that, thats great, I'll look up that DIY and try that really appreciate it.
Old 11-12-2009, 08:08 AM   #4
ssm1991
My Ride: 2004 325i
... or damaged front right wheel bearing.
ssm1991 is offline   Reply With Quote
Old 11-12-2009, 08:15 AM   #5
Colmomalley811
My Ride: 2001 E46
Good Point
Thats a good point too I'll check out both remove the strut and clean it if that dosen't solve it I'll replace the wheel bearing and if I'm still haing a problem I may replace the strut also hopefully that should solve it.
Old 11-16-2009, 10:11 PM   #6
Cowspoo
My Ride: 328Ci
mine squeeks when i turn it a few inches to the left, i assume thats not your problem. interested to see a fix tho!
spacebarissolazy
doesntfeelikebeingpressed
Cowspoo is offline   Reply With Quote
noise, steering, suspension
