Old 07-07-2010, 02:42 AM   #41
thenovice
My Ride: BMW 325i
tranny
Originally Posted by e46bonestock View Post
you need to make sure which tranny you have, GM or ZF.
hi Guys I am relatively new to the forum. How would I know if my tranny is made by GM or ZF. Mine is a 2002 325i (nonfacelifted) sedan bought locally here in Manila, Philippines. According to realoem my transmission part number is A5S325Z. thanks
thenovice is offline   Reply With Quote
Old 07-07-2010, 02:50 AM   #42
thenovice
My Ride: BMW 325i
Originally Posted by Hageee View Post
Is there a noticeable difference between the shiftings from a dexron III Oil to Dexron VI (Valvoline or Mobil 1) ?
OT:
Does anyone else has the problem, that the A5S390R will pull the converter bypass @ 60 mph (100 km/h) in? if i press down the throttle (no kickdown) the egs pulls the bypass in. My M54B30 is running @ 2000 RPM / 60 mph...
Will it be okay to use Mobil 1 synthetic ATF multi vehicle Mercon V to change my ATF in my tranny? Nor really sure if this is the same Mobil dextron Vi atf.
8072b, as5390r, dexron vi, dexron-vi, texaco etl 8072b
