Sponsored by The Tire Rack
Old 11-12-2009, 12:16 PM   #1
Ratty
My Ride: Alpine E46
Which would be less likely to rub, 245 or 255?
Tires 245/35/19 or tires 255/30/19 on a 19 x 9.5 wheel would less likely to rub??
Ratty is offline   Reply With Quote
Old 11-12-2009, 01:12 PM   #2
VMRWheels
VMRWheels's Avatar
My Ride: Anything with VMRs!
245's are a bit wide for a Non-M front. What width and offsets will you be running? We would need to know that to determine tire fitment.
-Charles@VMRWheels
Tracy @ VMR | Wheels
Winter Wheel/Tire Sale!
Old 11-12-2009, 01:33 PM   #3
Ratty
My Ride: Alpine E46
it is for the rear and offset is 44.
Old 11-12-2009, 02:03 PM   #4
VMRWheels
VMRWheels's Avatar
255 would be a better fit for a 9.5" wheel. If you have a sedan then 245/255 would work with a +44 offset.
-Charles@VMRWheels
Old 11-13-2009, 12:09 AM   #5
jack s
My Ride: 2005 325i
On any given offset, the narrower tire should be less likely to rub. But I'd go 245/30R19 rather than 245/35R19 because it's closer to stock diameter.
jack s is offline   Reply With Quote
Old 11-13-2009, 01:15 AM   #6
InLoveWithE46
My Ride: e46 non-M, e36 ///M
Send a message via AIM to InLoveWithE46
-Charles@VMRWheels
+1 this is what you want, if you have a coupe you could even do 265 with that offset. Do you want a stretched looked or no? Because 245 on a 9.5 is going to be a bit stretched.
~Leslie~
~euro.techniks~
InLoveWithE46 is offline   Reply With Quote
Old 11-13-2009, 08:24 PM   #7
Ratty
My Ride: Alpine E46
Could I run a 245/30/19? I thought I would need 245/35/19..
Old 11-13-2009, 09:09 PM   #8
VMRWheels
VMRWheels's Avatar
I would recommend a 245/35/19 if you were to run the 245's. For the 255's they would be a 255/30/19.
-Charles@VMRWheels
Old 11-13-2009, 09:23 PM   #9
Ratty
My Ride: Alpine E46
How many mm difference from a 245 to 255 tire? Also from a 35 to 30 profile tire??
Old 11-13-2009, 09:35 PM   #10
BartenderPlease
My Ride: '03 540i/6 M-Sport
10, the difference between 245 and 255.
.............................................@jb540i6
'02 JR/Naturbraun 330i M-Tech I | M-Tech II Fr. | Supersprint Headers | Remus Sport |
.....| SM Flywheel Conv. | 18" CH'ish reps | Short Shift | Orion V2.5 | RCR LED Tail |
'03 JB/Schwarz 540i M-Sport 337 | Decatted | Short Shift | Carbon Fiber Trim |
BartenderPlease is offline   Reply With Quote
Old 11-13-2009, 09:36 PM   #11
Ratty
My Ride: Alpine E46
what about 35 to 30 profile tire?
Old 11-14-2009, 12:10 AM   #12
InLoveWithE46
5. Just subtract. 255-245 = 10mm difference 35-30 = 5mm difference in height.
~Leslie~
~euro.techniks~
Old 11-14-2009, 03:15 AM   #13
BartenderPlease
no the profile height is a ratio, not mm. for example: 235/35/19 = 235mm wide, 82.25mm (which is 35% of the 235mm width).
think about how low of a profile a 30mm sidewall height would be
