Thread Tools Search this Thread Rating: Thread Rating: 15 votes, 5.00 average. Display Modes
Old 06-01-2010, 06:16 PM   #21
Bandersnatch
My Ride: 2002 330 CiC
Dan, see the 2nd and 3rd to last pics in the very first post.
PBSun cut the plastic frame off the OEM speaker. It has the oddball 3-hole mounting system that BMW uses. Then he screwed his speakers to the plastic frame. The gap all around the speaker is because he used 5 1/4 inch speakers.
I would think that the 6 1/2 inch Infinity 6022si's would drop right in with no gap. Use silicone to seal the bracket to the speaker all the way around. If the fit is too tight, I'm sure you can use the plastic basket as the mount like I did.
I think the bracket from the original speakers is a better solution. There was a little bit of slop in the fit to the basket, but the speaker bracket fits down inside the lip of the basket, so the bracket is a hair smaller than the basket and the fit might be perfect.
Good luck.
Originally Posted by DCJodon View Post
ZOMG HALP! *click*
oh hai, i can haz part numbro for florr matz? k thanxz.
Bandersnatch is offline   Reply With Quote
Old 06-01-2010, 10:23 PM   #22
ddombrowski
My Ride: 01 330ci 5spd
Send a message via AIM to ddombrowski
thanks, awesome. As long as its just modifying the plastic bracket from the old speaker and a little solder, it should be no big deal. Now - the question is do I want to go for the infinitys that I know will fit....or go for something with a little more low end punch for around the same price? I'll probably stick with the infinitys if theyre an improvement over stock, but since I have no plans to upgrade this further, some 6.5" subs in the rear would be appealing.
ddombrowski is offline   Reply With Quote
Old 06-01-2010, 10:39 PM   #23
Brilliant
My Ride: E46M3 Blk/Blk
I would modify the baskets rather than mount the speakers to your parcel tray. I thought it might sag overtime so I wanted the basket to support as much as possible. Its actually a snug fit.
Here is what I ended up with for the 60.9CS woofer. Don't worry about messing them up, a new set is like 20 bucks, and yes, it took me two tries of experimenting. You can cut the entire basket off though and just use the ring as a mount. As I said I didnt like this since it left the speaker hanging on the parcel tray.
AST 4100s, plates & s-RSMs | Eibach sways | OEM brace | CSL rack | CSL rotors & calipers w/ ST lines | Genuine CSLs w/ BBS caps
Euro headers & Euro cats | MILLTeK raspx | VAC pulleys | 3.91 M Gears | Z3 SSK
Infinity Kappa 5 amp, 50.9s, 60.9is | AC LC6i | CD53 retrofit w/ Aux | USASPEC ipod | OEM Sirius
OEM Euro folding mirrors | OEM LED retrofit & Euro LCM | V-CSL diffuser (fits like S) | misc cosmetics
Soon: CSL Intake
Brilliant is offline   Reply With Quote
Old 05-04-2011, 06:04 AM   #24
redwood77
My Ride: e46
old thread, but very helpful. one of my rear speakers blew and so i am replacing them. one thing that i wonder about is why the rear speakers are not in a sealed enclosure? as you can see from the pic in the post right above, the "basket" that the speaker sits in has like a grate at the bottom of it that is open to the trunk. perhaps the stock speakers are designed to be "free air"? its been my experience that just about all speakers sound better when in a sealed enclosure.. even if its a tiny one. anyone know what the deal is?
redwood77 is offline   Reply With Quote
Old 06-05-2011, 01:22 PM   #25
jallantaylor
My Ride: E46
those are the same kappa's that I used - or at least they look the same. Mine fit without modifying the cup. However, I used one of the grill plates from the box to mount it down to and now it bounces off the grille when installed. I need to go back out and figure how to adapt it to the cup without the grille-ring so it sits lower. It might not fit by the time I figure that out..
jallantaylor is offline   Reply With Quote
Old 06-05-2011, 07:01 PM   #26
jallantaylor
My Ride: E46
EDIT: Confirmed. I pulled the parcel shelf and tried to sink them into the cups. They bottomed out. I had to cut the cups up and gorrila glue them to the cups before installing.
Old 06-08-2011, 10:59 AM   #27
ThatGuy_JZ
My Ride: '02 Steel Blue 325Ci
Send a message via AIM to ThatGuy_JZ
Originally Posted by emandizzy View Post
Great post PBSUN, i just wish you had a coupe, i have the same problem with my rear speakers. Except in the coupe the panel is extremely shallow.
Here's a DIY for coupes fitting 6.5 Infinity's in the rear deck. I kept my baskets as well.
http://forum.e46fanatics.com/showthr...t=rear+speaker
OP, nice work on fitting the speakers!
- 2002 Steel Blue 325Ci -
ThatGuy_JZ is offline   Reply With Quote
Old 08-18-2013, 04:51 PM   #28
GeigerBMW
My Ride: 2003 330Ci 5 speed
Has anyone found rear deck speaker adapters for 6.5" speakers in the US
I have reviewed the solutions previously mentioned and would like to make use of purpose-made adapters but the only source still appears to be the UK with a cost with shipping of $30. I would like to cut the basket off of the old speakers, but the previous owner only left one behind. The use of MDF or plywood and black paint appears to be the only option left for a clean look.
Has anyone found another option yet?
Geiger
GeigerBMW is offline   Reply With Quote
Old 11-10-2014, 02:24 PM   #29
havnfun328
My Ride: '99 328i, '03 M5
Originally Posted by Bandersnatch View Post
The other nice thing about the Infinities is the tweeter doesn't stick up beyond the top of the woofer cone (unlike the ones above) so you can still use the stock speaker grill.
Sorry to resurrect an old thread, but I bought and installed a pair of Infinity Reference 6032cf speakers for my 99 sedan. They are two-ways and the tweeters stick up too far so that I can't install the grills.
Are there aftermarket grills that have more clearance? I haven't been able to find anything.
2003 E39 M5 Lemans Blue: Truly an amazing car
1999 E46 328i Bone stock 5-speed: Beater and Track Car
250K!!!!!!!!!!!!!!!!!!!
havnfun328 is offline   Reply With Quote
adapter, custom adapter, diy, frame, speaker
