Thread Tools Search this Thread Rating: Thread Rating: 232 votes, 4.97 average.
Old 05-07-2012, 10:26 PM   #1101
bluefethers
My Ride: bmw,2004 325i
bluefethers
no not yet, i will take out the radio first( after procrastinating for a day or 2)lol.
bluefethers is offline   Reply With Quote
Old 05-08-2012, 12:10 AM   #1102
Zell
Zell's Avatar
My Ride: so turbo wow
Does this also support Bluetooth Music, or just phone?
Old 05-08-2012, 02:47 AM   #1103
ZZen330
My Ride: 2002 330Ci
Just phone calls.
ZZen330 is offline   Reply With Quote
Old 05-08-2012, 12:06 PM   #1104
bluefethers
bluefethers
Haven't bought yet,waiting for my bid to be accepted on ebay for a 3000 and ctpparoo7 together for $120 but removed my radio and confirmed it is a business c53 with 17 pin.I am beginning to realize that most venders are wrong about what will work and what wont work.You guys here know more than the venders
Old 05-08-2012, 12:16 PM   #1105
jayjay_dee
My Ride: '10 X5 35d, '05 ZHP
bluefethers, i sent you a pm...
for everybody else, i have this installed on my 2005 330i last winter, my weekend car... im replacing it with Enco B146 (navigation), if interested, PM me...
jayjay_dee is offline   Reply With Quote
Old 05-08-2012, 02:54 PM   #1106
bluefethers
I just pulled off the overhead mic grill and there is a built in mic with the grill,so how could I use the parrot mic?
Old 05-08-2012, 07:21 PM   #1107
Ballistic325
My Ride: slow and steady
Just remove the mic and replace it with what comes with the Parrot kit. There is a DIY floating around which hooks up the factory mic, but it is up to you whether you want to go down that path.
CK3000 or Evo, it does not matter. Essentially they are the same device, just like a pre-face or facelift E46
I can help with
* Reading Codes / Coding your car
* R&R FCAs, Tie Rods, Sway links....
* RTABs
Need an RTAB tool? Or clutch fan and water pump tools? PM me.
Ballistic325 is offline   Reply With Quote
Old 05-08-2012, 08:05 PM   #1108
bluefethers
bluefethers
since the bmw mic and the grill is one peice i cannot install the parrot mike there,unless bmw has the grill without attached mike(is that possible?) do you think attaching the mic, via sticky footprint,to the bottom of the rear view mirror(its a flat surface) might work ok?
Old 05-08-2012, 08:33 PM   #1109
steve.325i
My Ride: 2003 325i
Hi, I had my mic mounted below the oem mic location originally. I liked it but I found that I was knocking it off too much - especially when dropping my son off at school - his back pack seemed to hit it all the time. PLease don't ask me how. I can't figure it out ...
http://forum.e46fanatics.com/album.p...pictureid=8762
I ended up moving it to the top side of the rearview mirror.
steve.325i is offline   Reply With Quote
Old 05-08-2012, 09:23 PM   #1110
bluefethers
bluefethers
thanks steve,did that work out good for you?
Old 05-09-2012, 02:49 AM   #1111
Ballistic325
^ to answer your question, yes it is possible to get a 'blank' to replace the OE mic with. It should be cheap from a wrecker or even dealer / online parts.
As for location, I am stll experimenting but the collective wisdom suggests that the OE location is best, plus it means for a totally hidden install!
I can help with
* RTABs
Old 05-09-2012, 10:52 AM   #1112
BM-MAN
My Ride: Hot 3 coupe
Send a message via MSN to BM-MAN
Originally Posted by ZZen330 View Post
Just phone calls.
Is there a setup that would support a2dp bluetooth audio?
BM-MAN is offline   Reply With Quote
Old 05-09-2012, 08:55 PM   #1113
steve.325i
My Ride: 2003 325i
Yes, I like having it on top of the mirror. I think I have had it there for 6-8 months. I would have to scan through old posts to make sure.
I tried the full stealth method first by putting the mic up behind the oem grill. The mic sensitivity was terrible.
Old 05-10-2012, 08:09 PM   #1114
Ballistic325
BM-MAN
yes, you can integrate other bluetooth solutions...
- Parrot MKi9xxx series
- Blackberry bluetooth music adapter (will require your HU to have AUX in)
- DICE / GROM / USA SPEC and similar manufacturers have A2DP streaming
- I am sure there are other solutions as well.... might take some hunting around on the web
I can help with
* RTABs
Old 05-12-2012, 01:34 PM   #1115
gnome
My Ride: 2003 325iT
Quick Question: I am installing a Parrot 3200 LS Color in my E46, but I am using the quickconnect connector as recommended by Parrot (model QCBMW-R, my Alpine head unit has round pins).
Loose connected everything, works well, but the head unit wont fit back in. Too many large connectors - I managed to place the blue Parrot module to the driver's side beside the vent but the cables are a no-go. The vent is removed like in the diagram but I can't get the "A" large connector to move up top near the vent, the plastic housing/shroud is preventing that. Any ideas without cutting the plastic? - just need to move the plastic shroud/frame around the radio and lower vent controls out a bit to get the cable routing done.
Any pics or suggestions?
Thanks!
gnome is offline   Reply With Quote
Old 05-12-2012, 09:49 PM   #1116
steve.325i
My Ride: 2003 325i
you are probably done by now, but there is not enough room to push everything to the drivers side imo. I remember trying it & gave up.
I put the blue box behind the glovebox & ended up removing the iso connectors and making direct connects to get everything to fix.
Not the answer you are looking for.
Old 05-13-2012, 08:22 AM   #1117
gnome
My Ride: 2003 325iT
Thanks!
What a PIA! I went savage and removed the climate controls, and plastic bracket that supports everything in that area, then re-routed every up just under the 2 vents, and put everything back in - fits. The blue box is just flat under one vent on the passenger side. Mic is routed to its oem place in the sunroof control area - works like a charm.
Now that I have my brushed aliminum trim off, I am thinking I want black cube trim - anyone have black cube trim for touring/sedan for sale?
Old 05-21-2012, 01:14 PM   #1118
Reefin Dude
My Ride: a blue one.
Originally Posted by JapanRed View Post
This diy made me look at my mess of wires and scratch my head since it was so nice and easy and no splicing or cutting up wires. I used the exisiting wiring harness for the parrot and the qcbmw-r and made it work with no big issues. I took some pics for any body who has to run this setup of the wire schematics.
To answer Zzen's questions yes I was too much in a rush to wait unfortunately and to me right now the steering wheel contorls i can do with out.
Thanks Steve325i for your want to help. I took pics to send to you but was able to figure it out with some trial and error.
Having fun taking the middle exhaust vent out and fitting the mic in the headliner. freaking tight. goign to put it all in tonight. now that the harness is done
Originally Posted by burnhamd View Post
I am studying electrical engineering at georgia tech.
My parts are on the way and I will have time next week to try to adapt the wiring. My plan is to directly connect some of the parrot cables to the plug in the trunk and bypass all the unnecessary stuff (speakers, mic). One of the connects 2 cables will probably not even be used and only about 4 pins from the other connects2 connector will be needed. IBUS, TEL ON, GROUND, maybe others I haven't completely written a pin conversion yet. I also have pinouts for the 54 trunk connector(i believe this is the ulf connector), the 25 pin trunk connector( apparently used some later models),
and the 17 pin connector for the radio. Now I just need to find the female versions of this plug so that I don't have to splice directly into the oem wiring harness.
does anybody have the pin outs for going the 54pin ULF connector instead of using the Connects2 adaptor discussed above? i do not want steering wheel controls for my phone. i have them mapped to another device and am hoping that just tapping into the harness without the Connects2 will keep my steering wheel buttons mapped the way they are. if it matters i have the Eclipse BT-E600.
Thanks,
G~
Reefin Dude is offline   Reply With Quote
Old 05-21-2012, 03:29 PM   #1119
Reefin Dude
for anybody interested, here is a list of the color codes for the parrot products and a fair amount of wiring diagrams for most car manufacturers.
i am still having a hard time finding the pin outs for the 54pin ULF connector, anybody?
thanks,
G~
Old 06-16-2012, 05:25 PM   #1120
InterlagosBlau
My Ride: 2001 325Ci
I have an eBay auction up for the CTPPAR007 parrot adapter if anyone is interested, its a little cheaper than you can find it online and its still in the box.
http://www.ebay.com/itm/221049546966...#ht_500wt_1202
If you can't be good, be good at it!
InterlagosBlau is offline   Reply With Quote
Rate This Thread
