Thread Tools Search this Thread Rating: Thread Rating: 232 votes, 4.97 average.
Old 12-29-2009, 03:41 PM   #101
andy_bee
My Ride: 01 330i sedan
Originally Posted by Kelor View Post
I just got mine this morning. Ordered 16 days ago.
a few days extra for me, nearer christmas, but that isnt bad for regular post. Stuff from my folks to BC is at least 10-14 days
'01 330i ///M-Tech1 Sports Pack
andy_bee is offline   Reply With Quote
Old 12-31-2009, 10:57 PM   #102
andy_bee
So fitted it today. The instructions were a major help. The vent was tough to remove, so I used the butter knife, covered in masking tape to help it out did the trick.
The only thing I would add to the instructions is to make sure Connector B is routed around the back of the radio cage. I stupidly threaded mine through the big slot on the right and then the radio wouldnt slide all the way in.
I did have some off issues though. I got the unit to pair with the iPhone no problem, but then when I packaged all the cables up below the GM5, it wouldnt work properly. Try and make the call and it would fail and the radio would come back on. Pulled the cables back out, worked, pushed the cables back in, didn't....and repeat 3 times. Then went through each connector and everything is now stable and works.
Then the car wouldnt start, lights dimmed, air con turned it self off,,I assume its a drained battery as the ignition was on a fair bit this afternoon testing and with DRL in Canada, its probably drained it. Now on charage, so hopefully 2010 and the car will start well in tomorrow
Thanks for the guides. Great help
Old 01-01-2010, 12:36 AM   #103
steve.325i
My Ride: 2003 325i
Yup, killed my battery during the install as well but I also installed new door speakers @ the same time. Just like you I was a bit concerned but charging it overnight brought it back. That was two months (or so) ago.
Damn DRL's ... lol.
steve.325i is offline   Reply With Quote
Old 01-01-2010, 12:42 PM   #104
conciseusa
My Ride: 2002 325i
Installed this yesterday, thanks for the killer how-to
Installed this bluetooth mod in my 2002 325i yesterday along with a new radio so now I have bluetooth and AUX input.
I had a bit of a struggle getting the center vent out. Found an easy way that may help someone. Take a hanger and cut it to get a straight wire, use pliers to put a 45 degree small hook at the end and use it to go into the center area of the vent, hook up to the gap where the vent connects to the air tube and use it to give a firm constant pull. Then when I worked the clips of the four corners of the vent in to unhook them, the vent popped right out.
Thanks again. Looking forward to your other DIYs.
conciseusa is offline   Reply With Quote
Old 01-03-2010, 08:58 AM   #105
e46bonestock
My Ride: 325
I've installed the same pkg as delmarco, but I can't seem to tuck the wire into the top of the windscreen. It won't go in. I feel as if the adhesive to the windshield is there, and am afraid of prying into it. Can anyone help with this?
btw, I found it much easier by pushing out the climate control box and unscrewing the bracket holding it. what I've done is put the A-C connection to the left side of the centre vent. Then putting everything back in place. I couldn't tuck it behind the right side of where the spike that holds the Alpine radio unit. Before you put everything back or the glove box back, make sure the volume of the parrot is loud enough. I had to take it off to increase the volume on the parrot in the frigid cold.
Thanks delmarco for the DIY.
e46bonestock is offline   Reply With Quote
Old 01-03-2010, 03:47 PM   #106
bimmerme74
My Ride: 2004 325xi
Originally Posted by delmarco View Post
PART FOUR: Setting up your MIC
And that is it you are done!
I been getting a few PMs from folks with GPS Factory Navigation units looking for the 17 pin A Connector in their cars or wondering if they have the same connections.
From what I can tell you do have the same A Connector but it is location in the trunk with the GPS Computer ECU/DVD module.
and it will look like this
So you will need to hook up the parrot ck3000 and ctppar007 all in this trunk space and run the mic thru to the cabin dash area. The ck3000 mic wire is long enough to pass thru the firewall into the cabin along the driver's side and you can place it on the dash or A p!llar column. If it is short you can get a mic cable extender at Radio Shack or any electronics store.
Hi,
if i need to listen to my song from my BB(playlist), does it work with this connection?
thanks
bimmerme74 is offline   Reply With Quote
Old 01-03-2010, 08:05 PM   #107
farmdog
My Ride: Food Truck
How many phones can you pair with the unit?
farmdog is offline   Reply With Quote
Old 01-03-2010, 08:16 PM   #108
AMCINK
My Ride: 2000 323CI
Is this only to pair phones via bluetooth and use it handsfree - or would it also work for the iphone and play music in your stereo from the iphone???
AMCINK is offline   Reply With Quote
Old 01-03-2010, 08:46 PM   #109
Mike00135
My Ride: BMW
4 phones!
Mike00135 is offline   Reply With Quote
Old 01-03-2010, 08:55 PM   #110
Mike00135
My Ride: BMW
4 phones!!
Old 01-03-2010, 10:26 PM   #111
farmdog
My Ride: Food Truck
My car is telling me the memory is full...
What do I do?
Old 01-04-2010, 12:11 AM   #112
steve.325i
My Ride: 2003 325i
What do I do?
You have to reset the Parrot.
I don't know the procedure with the connect2. You may have to hook up the parrot controller to do it.
With the quickconnect I ca reset it like this:
Resetting the car kit:
Press
VOLUME & then VOLUME + 5 times
btw - I believe the number of phones that you can pair with is THREE, not FOUR.
Old 01-04-2010, 12:15 AM   #113
farmdog
My Ride: Food Truck
do i need the ignition on?
Old 01-04-2010, 12:28 AM   #114
steve.325i
My Ride: 2003 325i
Yes, because the Parrot system has to be live.
But I don't know the reset procedure for the connect2.
Old 01-04-2010, 12:30 AM   #115
steve.325i
My Ride: 2003 325i
Only handsfree wit the ck3000.
Other models from Parrot support what they call 'streaming'.
Old 01-04-2010, 01:15 AM   #116
farmdog
My Ride: Food Truck
Press
To reset the kit I had to take the glove box out and reset the controller by pressing the red and green button at the same time. It worked.
You can only pair 3 phones with this.
Thanks guys....great mod..easy DIY...and pretty cheap.
You cant go wrong with this one
Old 01-04-2010, 01:28 AM   #117
steve.325i
My Ride: 2003 325i
Glad you are up & running.
Old 01-07-2010, 09:06 AM   #118
mjmiske
My Ride: 2003 325i
Huge props to delmarco for the detailed posting. I just got the wiring harness in the mail yesterday, so this will be a Saturday morning project. Got both parts from ebay, the Parrot for $61 (free shipping) and the harness for $95. Still a great deal at just over $150.
mjmiske is offline   Reply With Quote
Old 01-09-2010, 04:52 PM   #119
Mike00135
My Ride: BMW
Stalk controls
hi there again. does anyone knows what does "STALK CONTROLS" do an a bmw? i have found this in the internet. it says that it also works with the steering wheel buttons.. any idea?
Old 01-09-2010, 05:40 PM   #120
delmarco
My Ride: 335xi Deep Sea Blue
Send a message via ICQ to delmarco Send a message via Yahoo to delmarco
The stalk controls the OBC function display (clock, fuel, temp, mileage) not the Bluetooth.
On earlier BMW models like the E36 there was a third stalk for the cruise control function which became steering wheel buttons on our E46.
I think BMW bought back the cruise control stalk in the later model BMWs like the E90s.
Either way none of this has anything to do with this DIY.
There is no stalk for bluetooth or telephony on the E46
delmarco is offline   Reply With Quote
Rate This Thread
