Thread Tools Search this Thread Rating: Thread Rating: 232 votes, 4.97 average.
Old 02-05-2013, 09:22 AM   #1181
DamoBMW
My Ride: '02 325Ci M-Sport
Originally Posted by DamoBMW View Post
I already have the CK3000 and I was about to purchase the Connects2 CTPPAR007 wiring harness but decided to look through this thread some more first and found there are some issues with pairing Android devices.
I've got a Samsung Galaxy S3 4G (v4.1.2) and my CK3000 module is v5.24.
Can anyone confirm that I will be able to pair my phone without a problem?
Is there a way I could try pairing my phone to the CK3000 before I purchase the Connects2 wiring harness?
'02 BMW 325Ci 5MT M-Sport Individual Stratus Grey
DamoBMW is offline   Reply With Quote
Old 02-07-2013, 07:05 AM   #1182
DamoBMW
Anyone??
Old 02-07-2013, 12:05 PM   #1183
Bimmer_Addict
My Ride: E46 323i
You should be able to pair your phone by opening the BT app in your phone to pair, if your phone reads Parrot CK3000 or whichever kit you have, just enter the pairing code which I think is 1234 by default, I hope this helps you.
00 E46 323I current
08 Jeep Grand Cherokee Laredo current
08 E60 535I LEASE OVER
02 E66 745LI LEMON
98 E39 528I SOLD
91 E30 316I SOLD
Bimmer_Addict is offline   Reply With Quote
Old 02-08-2013, 06:43 PM   #1184
itismyname
My Ride: bmw 330ci
Does this diy enable me to play music from my phone via bluetooth, or does it only do voice command talking?
itismyname is offline   Reply With Quote
Old 02-08-2013, 08:38 PM   #1185
chuckdiez323i
My Ride: 2000 323i
cool mod!!
chuckdiez323i is offline   Reply With Quote
Old 02-13-2013, 05:47 PM   #1186
kilo1548
My Ride: 2002 325CI
Looks pretty straight forward... I may order these parts up to go along with my Nexus 7 install
kilo1548 is offline   Reply With Quote
Old 02-13-2013, 10:18 PM   #1187
Ballistic325
My Ride: slow and steady
No - for that you need a later model Parrot kit. Something in the 9xxx series.
Why not just use the BT on the Nexus?
I can help with
* Reading Codes / Coding your car
* R&R FCAs, Tie Rods, Sway links....
* RTABs
Need an RTAB tool? Or clutch fan and water pump tools? PM me.
Ballistic325 is offline   Reply With Quote
Old 03-13-2013, 03:06 PM   #1188
rickymacdonald
My Ride: 2006 BMW 325ci
Business CD & OEM Phone Buttons
Ok, I'm a newb , so don't shoot me. This is my first BMW and I'm new to all this modding stuff.
I just want to be clear before I purchase the wrong thing. I have a 2006 325ci Coupe. It has the "Business CD Player" and it has the "Talking Head" button on the steering wheel as well as the "R/T" button.
1. Will these parts work with my head unit?
2. Will I be able to utilize the OEM steering wheel buttons?
rickymacdonald is offline   Reply With Quote
Old 03-13-2013, 09:40 PM   #1189
steve.325i
My Ride: 2003 325i
The Parrot will work with ANY HU
Yup.
steve.325i is offline   Reply With Quote
Old 03-13-2013, 11:53 PM   #1190
rickymacdonald
Thanks Steve!
Old 03-17-2013, 06:29 AM   #1191
Daerve
My Ride: 318i
Just installed this in my E46 and it works great, except for the fact that my iphone 5 won't reconnect automatically. It pairs fine and works a treat, it's just that when the ignition is turned off it fails to reconnect on start up but connects fine if done manually.
Anyone got any suggestions? I've tried a different phone (Iphone 4s) and this does the same, I've also tried resetting by holding down the red and green buttons about 5 times. The result is always the same.
Daerve is offline   Reply With Quote
Old 03-17-2013, 06:49 AM   #1192
Imola.ZHP
My Ride: Imola ZHP
^ I've never had this problem, thats quite odd...
-- '03 330i ZHP
-- Marcus
Imola.ZHP is offline   Reply With Quote
Old 03-17-2013, 02:30 PM   #1193
steve.325i
My Ride: 2003 325i
I'm a blackberry user so I don't know for sure BUT a girl I work with has an iPhone4 and has the same issue with her stock BT setup in her 2012 Toyota Highlander. Could this be a 'feature' of the iPhone?
Old 03-17-2013, 03:42 PM   #1194
Lobstrosity
My Ride: 2003 325xi Touring
Did you have another phone paired with the parrot before? I had this issue when I upgraded to the iPhone 5. The parrot keeps a few phones in it's history and tries to reconnect to all of them, so it could take a few minutes (or indefinitely) before getting to the iPhone 5. You can reset the Parrot to clear out it's bluetooth history and then reconnect your current phone. That's what I did, and it's been fine since.
Can't recall the sequence of buttons to press, but it was in the Parrot user's manual.
Hope that helps!
*edit - Oops, noticed you said you "just installed" this. So this probably isn't the case unless you bought it used. But maybe this will help someone else having poor connection performance!
Lobstrosity is offline   Reply With Quote
Old 03-17-2013, 04:39 PM   #1195
Daerve
My Ride: 318i
Hope that helps!
Thanks for the suggestion, the kit was second hand so no doubt did have phone's paired before. I have however deleted the memory by holding down the red and green buttons until it cleared. In fact I've done this about 5 times and it's still not working properly.
Old 03-17-2013, 08:37 PM   #1196
alx.325i
My Ride: 02 325i
Parrot Upgrade Cable
Does anyone have a cable for updating the firmware for sale or even borrow. I tried ordering one last year overseas and never got it and had to do a charge back. I lost motivation after that and now want to try to update my firmware since i cant connect to my iphone 5.
Or does anyone know where i can purchase one here in USA. Thanks in advance.
alx.325i is offline   Reply With Quote
Old 03-17-2013, 09:18 PM   #1197
Daerve
My Ride: 318i
Check the firmware version you have first. It's either printed on the blue box or will show as the last digits of the device in the bluetooth connection menu on your phone. Mine is the latest version and I'm still having problems.
Old 03-17-2013, 10:28 PM   #1198
alx.325i
My Ride: 02 325i
yea, i'ts version 5.11, really old and doesn't even work with android, and just changed over to iphone 5 and IOS 6. either way, would be nice to be able to update whenever incompatible OS/devices come out.
Don't know why Parrot doesn't make the cable more readily available.
Old 03-18-2013, 01:24 AM   #1199
jayb328i
My Ride: E46 2000 328i
I got a Motorola Razr M. Been trying for weeks to update to 5.11. was able to clear all the memory, but no luck in downloading 5.11. Looking for the cable, or anyone who can do the pairing with the Parrot 3100
jayb328i is offline   Reply With Quote
Old 03-24-2013, 03:58 PM   #1200
warrior2005
My Ride: 05 325Ci
Big thread! I'd like to do this. 2005 e46 coupe. iPhone 5.
So could I purchase the connects2 ctppar007 and a later model parrot kit to make it work for phone and music? Is the DIY any different for that? If that would work, could someone link me to an appropriate Parrot kit?
warrior2005 is offline   Reply With Quote
Rate This Thread
