Old 11-18-2009, 12:33 PM   #1
RACEMX-M3
My Ride: M3
Rear View Mirror AEM Gauge Upgrade DIY for HPF M3's
The HPF AEM Rear View Mirror Gauge Upgrade is now available for all F/I M3's. The plug and play RVM setup is in stock and may be ordered directly from HPF for new gauge installations and M3 owners that currently have AEM Wideband and Boost Gauges installed may upgrade while your car is in HPF's shop in Portland or have the option to ship thier parts directly to me if you wish to DIY.
I am currently working on upgrades for Evil Twin Rob and a few other F/I M3 owners and this thread will provide existing HPF M3 owners detailed instructions for removing and re-installing the components required for the RVM Upgrade.
Disassembly Instructions
First remove the black plastic shell that encloses the mirror bracket. The cover has several plastic clips that snap together. Push down on the right hand side of the cover near the seam and gently pry apart with the screwdriver.
Once the cover has been removed, dismount the rear view mirror from the windshield by turning the mirror counterclockwise approx 45 degrees and it will come right off.
Disconnect power connection
Remove the 5 screws/clips from the cover below the dash and pull the cover off
Remove the connections and set the cover aside
Using a small screwdriver push upward on the two plastic rivets on the bottom of the steering column
Pull down gently on the lower portion of the steering column and set aside
Remove the AEM Gauges from the pods by gently pulling the gauges out and disconnecting the wiring connections from the rear of the gauges. The boost gauge (on the right) has a knock siren on the back of the gauge. Remove the nut securing the siren and leave the siren inside the pod.
Remove the screw on the top of the steering column
Detach the leather from the rear of the steering column by pinching the 4 clips together
Disconnect the the wiring connection labeled "GAUGE ASSY". Remove the upper steering column with remaining wires and components intact and set aside.
This completes the disassembly process. You will need to ship your mirror, both gauges and the upper steering column cover with the key switch, race fuel LED, knock siren and wiring attached.
NOTE - Installing the gauges inside the E46 M3 rear view mirror requires the rectangular SOS M3 mirror. If your car is currently equipped with the oval mirror we will accept the oval mirror as a core exchange and provide an oem SOS mirror for your installation.
RACEMX-M3 is offline   Reply With Quote
Old 11-18-2009, 12:34 PM   #2
RACEMX-M3
My Ride: M3
Assembly
Assembly Instructions
The LED displays from each gauge will be installed inside your mirror, the remaining portion of the gauge components will be placed inside the dash and connect to the existing wiring connections. We will install the race fuel key switch, LED and knock siren on a new oem steering column as shown.
Remove the thin portion of the driver's side A-pillar
Remove the 3 torx screws and the A-pillar cover
Remove the sun visor and visor clip as shown to allow the ribbon cables to be inserted inside the headliner
Remove the map light
Beginning under the dash, route the two ribbon cables as shown. The path for the cables zig zags a bit and I found it helpful to feed a couple of feet of safety wire through, attach it to the cables and pull them through.
Route the cables along the A-pillar and just inside the headliner as shown.
Re-install the rear view mirror on the windshield, route the cables through the headliner and connect the oem wiring connection and two ribbon cables as illustrated.
Plug the existing wiring connections for the AEM Gauges into the back of the pods and secure all loose wires and pods inside the dash as shown.
Install the steering column cover and re-connect the GAUGE ASSY
Install the lower portion of the steering column and secure the knock siren as illustrated.
Start the car and verify that the gauges are functioning properly.
The clamshell will need to modified as shown to allow room for the new wiring harness.
In case anyone's interested this is where my methanol switch is installed.
Re-install the sun visor, A-pillar cover, map light and lower cover and your HPF - AEM Gauge Rear View Mirror install is complete.
DIY for disabling the SES light available HERE
Old 11-18-2009, 03:50 PM   #3
m3 guy
My Ride: 2001 e46 m3
Sick, very nice DIY
*2001 E46 M3 Oxford Green Metallic II-Cinnamon*
*AST*Work*VRS*UUC*RE*Apex*Scorza*SS*Brembo*
m3 guy is offline   Reply With Quote
Old 11-18-2009, 05:24 PM   #4
HPF Chris
Past Site Sponsor
My Ride: 2002 M3, 2006 530i
Looks great Scott. I'm glad you're doing this.
Chris.
HPF Chris is offline   Reply With Quote
Old 11-18-2009, 07:00 PM   #5
docwyte
My Ride: '89 944 Turbo
Quite possibly the cleanest gauge setup out there!
'98 M3, track beast
'06 Porsche Cayenne Turbo S 521hp daily driver
'07 KTM 990 Adventure
docwyte is offline   Reply With Quote
Old 12-04-2009, 06:30 PM   #6
leletyM3
My Ride: 05 M3
Great DIY!!!! Cleanest set up ever!
05 BMW ///M3 SMG - Jet Black/Gray
HPF Stg2 Turbo 640rwhp, Eisenmann Race 83mmx4, Volk TE37 TA, Toyo T1R, Brembo BBK 380mm 6pots & 345, 6k HID, 6K HID Fogs, Depo Smoked Corners, Strassentech Front Lip, V-CSL Bootlid, V-CSL Diffuser
leletyM3 is offline   Reply With Quote
Old 12-04-2009, 08:17 PM   #7
ST06M3
My Ride: 2008 Subaru STi
Nice write up Scott. Is your offer still open for anyone breaking your record?
ST06M3 is offline   Reply With Quote
Old 12-04-2009, 09:56 PM   #8
Evil Twin Rob
My Ride: 2004 M3
Sweet. The diy for the re-assembley will come in handy.
HPF 2.5
Evil Twin Rob is offline   Reply With Quote
Old 12-05-2009, 12:21 AM   #9
RACEMX-M3
My Ride: M3
lol, I don't remember what I offered.. free mirror setup to the first person that beats my time? That was probably it.. ok still on but the time has to be verified by Divexxtreme. And if I beat my time first you have to beat the new time.
Old 12-05-2009, 12:49 AM   #10
RACEMX-M3
My Ride: M3
Rob, got a few oem steering column covers in today and installed your race fuel key, led and knock siren. Everything else is done, just waiting for a batch of the custom glass we use to replace the oem mirror and this should be on it's way back to you early next week.
Old 12-05-2009, 01:15 AM   #11
Evil Twin Rob
My Ride: 2004 M3
HPF 2.5
Old 12-06-2009, 07:11 AM   #12
0-60motorsports
My Ride: E30 325ic & E46 M3
Send a message via MSN to 0-60motorsports Send a message via Yahoo to 0-60motorsports
That is frickin Awesome!
EURO 04 M3: GC Coils, Eibach Sways, PF RTABs, RE RCAs, INTRAVEE II, Black Roundels, ///MFEST Badges, Depo's, VCSL Bumper + Race Lip + CF Trunk + CF Rear Diffusor + CSL center console, DIETZ TV in Motion, SS Stepped Headers, SS Catless S & Res X-pipe, SS Race, Z8 Starter Button, Lamin-X, OEM CSL Steering + CSL interior, OEM CSL Intake, EVOLVE Alpha-N Tune, BBS CH's, FX-R 3.0's, ST40's, DINAN Rear Strut Brace, BW Oil Cooler, 3.91 gears
0-60motorsports is offline   Reply With Quote
Old 12-06-2009, 09:41 AM   #13
e popa
My Ride: M3,Sc323ci,Ml320
That is the most impressive thing I have seen in awhile . I love the set up. It is so clean , will this become stock now for the HPF kits? Again great work.
OG f**k the fame I want the money
http://www.youtube.com/watch?v=ni6ZR18MXQ4
Supercharged 323ci SOLD SOLD SOLD
AW M3
Matte Black CSL's,gills & grills
brembos, Dinan exhaust
Alacantra wheel
OEM CSL trunk,VCSL roof,bumper,diffuser
e popa is offline   Reply With Quote
Old 12-06-2009, 11:48 AM   #14
ssracing10
My Ride: 1988 M3
Received my rear view gauge install 2 days ago! Thank you RACEMX-M3 (Scott), I will be following up with a complete review of the FI kit and the gauge install soon!
ssracing10 is offline   Reply With Quote
Old 12-06-2009, 07:41 PM   #15
RACEMX-M3
My Ride: M3
Thanks, the mirror is currently an upgrade option.
Stefan, can't wait to see some pics. Good luck with your setup.
Old 12-06-2009, 07:51 PM   #16
e popa
Do you have any videos of it working?
Also there is no way of making it work in the oval mirrior?
AW M3
Alacantra wheel
Old 12-06-2009, 08:11 PM   #17
RACEMX-M3
My Ride: M3
Here's a vid I posted a few months ago. Using the oval isn't recommended as there's just not enough mirror there to make it look good, imo. I'll be happy to put them in the oval mirror if that's what you want.
Old 12-06-2009, 08:58 PM   #18
supersickbimmer
My Ride: 617rwhp M3
Hey Scott. Whats an upgrade like this cost? PM me if you like.
supersickbimmer is offline   Reply With Quote
Old 12-06-2009, 10:15 PM   #19
RACEMX-M3
My Ride: M3
The mirror upgrade is $499 for the full plug and play setup (gauges are sold separately), including a new oem steering column cover (for current HPF owners) and transferring all of the components - race fuel key, led and knock siren. If you have the oval mirror and want to upgrade to the SOS mirror (recommended) we can accept your oval mirror as a core exchange. The mirrors are also available for s/c cars.
Old 12-07-2009, 09:03 AM   #20
supersickbimmer
My Ride: 617rwhp M3
Nice, Thanks
