Go Back   E46Fanatics > Tuning & Tech > Suspension & Braking
Old 11-21-2009, 06:36 PM   #1
honhatch
Banned
My Ride: bimmer
after installin h&r race springs my car sits lower on one side
Like title says. i lowered the car since its been lowerd the driver side is about .25 in higher then the passenger side. i raised the car up on a lift and looked at both sides and springs are seated in the shocks and cups right. could i of missed something. i got 00 328ci h&r race springs on stock stocks and struts. thanks
honhatch is offline   Reply With Quote
Old 11-21-2009, 09:04 PM   #2
BMWespresso
My Ride: 2005 325CI
very normal, mine was .5" different before the drop and after the drop around .25"
BMWespresso is offline   Reply With Quote
Old 11-21-2009, 09:09 PM   #3
mvrk10256
My Ride: E30 325i
the hell?
that is most defnitly not normal.
i just did the same swap yesterday and my car is completly level.
so list of things that get messed with.
trailing arms, sway bars, struts, rear shocks. you should not have messed with anythign else when doing this. possible issue.. the lower mount of the struts, the strut just slides in so make sure it was slid in all the way before you tightened the compression lock.
really cant think of why the back would be different except that if the spring didnt seat properly on the top mounting stub.
good luck, get it fixed, and dont forget to get aligned .
Old 11-21-2009, 10:05 PM   #4
1importroadster
My Ride: 2001 330i Sport
I have a similar problem, but i am running bone stock (i plan on upgrades soon) but my car sits a full inch low on the right rear. i work for a bmw dealership and was able to get my car on a lift in the shop. one of my tech friends looked at it can can't see anything wrong, but said that the rear shock going bad. I wonder though.....if the shock mount is bad or broken can you see it enough to know? 1 inch seems like alot to me!
2001 330i sport 5 spd, Alcantara M-
steering wheel, 20% Window Tint, Hotchkis Sport Springs, Koni-str.t Struts 18in ZHP M-wheels.
1importroadster is offline   Reply With Quote
Old 11-21-2009, 10:12 PM   #5
firefirefire90
Banned
My Ride: suce ma bite
Send a message via AIM to firefirefire90
maybe you guys are just fat?
firefirefire90 is offline   Reply With Quote
Old 11-21-2009, 10:23 PM   #6
Kris.R
My Ride: 2012 Dodge Charger
You guys crack me up. Arguing like little females. Our cars sit lower on the passenger side no matter if you drive a sedan or a coupe. Its BMW's "weight compensation" design engineering with ONLY the driver in mind. My sedan was like that, and now my coupe also (H&R Race w/Bilstein Sports btw). Live with it, because as little difference there is in the gap, it wont make a difference at all.
- Kris -
"America will never be destroyed from the outside. If we falter and lose our freedoms, it will be because we destroyed ourselves."
-Abraham Lincoln-
Kris.R is offline   Reply With Quote
Old 11-25-2009, 05:06 PM   #7
socalbeast
My Ride: 09 black charger 22'
Ur shock is bad-
I hit a few dips hard in my time and it threw my ride height off ,
replace all 4 shock/struts at same time-
Previous ownwer maybe replaced 1 or 2 and that caused uneven wear-
2010 black charger lowered on geovanna canelli's
E46 steel blue 323ci 5spd.
socalbeast is offline   Reply With Quote
Old 11-26-2009, 04:44 AM   #8
Safar
My Ride: comes with blow
This man speaks the truth.
If I were you I'd be worried if the driver side sits lower than normal, but the passenger side should be a little lower (empty car) by design.
Vehicle history
1999 BMW E46 328Ci TS2
1992 BMW E36 316i Sold
1987 Suzuki VS1400
1996 Suzuki LS650 Sold
1984 Kawasaki 305CSR RIP
Went from 305cc > 650cc > 1400cc > 2800cc
No prizes for guessing what my next engine will be...
Safar is offline   Reply With Quote
Old 12-06-2009, 01:31 PM   #9
honhatch
Banned
My Ride: bimmer
thanks for the info. me and my boy put the car up on the lift and messed with it for a good while everything we perfectly fine but still couldnt figure it out. at least i know why my car sits sideway lol.
Old 12-06-2009, 02:24 PM   #10
kaotek323i
My Ride: red 1999 323i
ya my car did that also..
1999 BMW 323i... MR. CARBON FIBER
raceland coils, ACS Front Tower bar-Rotora Rear, 19's 8.5 front & 9.5 rear,
Carbon Fiber- kidney grill, shark fin, headlight eyebrows/inner trim, rear window wing, acs mirrors, b-pillars, front splitters, Oem hood, Csl trunk, gas lid, interior trim
VF stage1, v2 compressor w/ v1 internals, ebay headers
kaotek323i is offline   Reply With Quote
Old 12-07-2009, 01:57 AM   #11
KwhyLE
My Ride: '04 325i Alpine
Send a message via AIM to KwhyLE
+1
if you hardpark your car you should be worried about this....
get in the drivers seat and watch the eyes follow.
KwhyLE is online now   Reply With Quote
Old 12-07-2009, 08:08 AM   #12
e46techtuner
My Ride: 2000 328i
If the car is lower, 1" or more on only one corner its usually because of a sagging spring.
e46techtuner is offline   Reply With Quote
Old 12-08-2009, 10:51 PM   #13
honhatch
Banned
My Ride: bimmer
the only reason why it really bothered me was cause we tryin to fit m3 wheels on my car. and since the driver side was higher it didnt rub as bad as the passenger side. but we cut, and cut, and flared and got the wheels to fit. now gotta get body work done.
Old 04-04-2010, 09:19 PM   #14
1importroadster
Thanks guys, i went ahead and dropped my car with fresh Hotchkis springs koni shocks/struts today. Everythings great now except it needs an alignment for sure!
Old 10-01-2010, 03:54 PM   #15
N89
My Ride: 330Ci
Bump for a similar issue...
My drivers side sits 1/4" lower on the drivers side after a week on a new H&R Cup kit and around 150 miles driven... should I wait a little longer for them to settle or should I start worrying? It's only 1/4" but it's still noticeable... so there's no design compensation going on here... any ideas? I rarely have passengers could that even make a difference?
N89 is offline   Reply With Quote
