Old 11-22-2009, 10:27 PM   #1
Dan99
My Ride: 2001 330xi
Is it Safe to Drive With a Camshaft Sensor Error?
My car just pulled a p0344, which is a intake camshaft sensor error, so I was wondering if it's going to be safe driving it for awhile before I get it fixed next week?
Thanks,
Dan
Dan99 is offline   Reply With Quote
Old 11-22-2009, 10:32 PM   #2
hvirani
My Ride: e46 320i
You may experience sluggish acceleration and random stalls.
But to answer your question, I honestly don't know.
hvirani is offline   Reply With Quote
Old 11-22-2009, 10:44 PM   #3
jmay87
jmay87's Avatar
My Ride: e36,e46,e90
I drove mine around for like 2 days with it bad and the car definitely did not drive very well. It would stall out randomly and did have sluggish performance but it did not seem to do any harm. So yes its probably drivable but not for a while. Get the sensor ordered and put on ASAP.
--1995 E36 M3--2001 E46 325i--2008 E90 335i--
jmay87 is offline   Reply With Quote
Old 11-22-2009, 10:44 PM   #4
justin0o
My Ride: '01 330i
i drove around for a day and i was fine, and you will be slow as hell. Its probably not safe for you as a person, incase you need to make any quick manuevers or speed up suddenly.
justin0o is offline   Reply With Quote
Old 11-22-2009, 10:51 PM   #5
Dan99
My Ride: 2001 330xi
k, thanks guys. I guess I'll be carpooling for this week.
i swear e46 are like blonds, they're so high maintenance and they need a lot of attention.
Old 11-22-2009, 11:13 PM   #6
BodyMan
My Ride: 2002 325i
I drove around with mine bad for a month. It was a pain in the butt. It didn't do any further damage but, I don't recommend letting it go that long.
BodyMan is offline   Reply With Quote
Old 11-22-2009, 11:16 PM   #7
iansanderson
My Ride: 2001 330CiC
it can ruin the catalytic converters. I personally did it in an E38, but it was under warranty at the time so the $3200 bill for the new cats went to BMW. I wouldn't recommend it.
Cheat Sheet:
GT1/ISIS/MoDiC = Factory authorized diagnostic system used by BMW dealerships across the world.
NCS Expert = BMW Factory R&D programming tool available on the internet (not intended for the public and not available to the dealership network)
OEM = Genuine BMW part only available from a franchised BMW dealership.
DME = Engine Management Computer
iansanderson is offline   Reply With Quote
Old 11-22-2009, 11:23 PM   #8
BMW_Matt
My Ride: 135
I did ride around on mine for a few days. It's really easy to install too. Just order from tischer and have it there soon lol
BMW_Matt is offline   Reply With Quote
Old 11-22-2009, 11:36 PM   #9
Dan99
My Ride: 2001 330xi
thanks guys, I don't know what I'd do without you guys.
Old 11-22-2009, 11:38 PM   #10
BMW_Matt
My Ride: 135
Who needs those anyway
Old 11-22-2009, 11:53 PM   #11
Mike325i
My Ride: 2001 325i
Send a message via AIM to Mike325i Send a message via Yahoo to Mike325i
I drove around with mine for a while like that. Probably around a month. The only real noticeable thing was the random stalling. It started off random then it got progressively worse. Eventually I got off my ass and bought the thing. I don't have cats either, so it's not a concern to me
Mike325i is offline   Reply With Quote
Old 11-23-2009, 12:04 AM   #12
Chriztofor
My Ride: 2000 323i (Auto)
Answer: No. My car died while taking a corner.
For most BMW problems start off by reading your codes using a peake research tool. Note, as mentioned by other members, although Autozone checks your codes for free they use a generic OBDII tool that does not have the BMW specific fault codes.
Chriztofor is offline   Reply With Quote
Old 11-23-2009, 12:14 AM   #13
BMW_Matt
My Ride: 135
Rofl. Probably cause u were riding with it going bad for a long time.
Old 11-23-2009, 12:18 AM   #14
Solidjake
Zero. Leaks.
Solidjake's Avatar
My Ride: '02 330i 6MT
Change it ASAP. My car died on me while I was accelerating up a hill...
Old 11-23-2009, 12:29 AM   #15
BMW_Matt
My Ride: 135
Lol I noticed you both have auto's and it died on u and us manual guys just had lagged performance. observation.
Old 11-23-2009, 12:35 AM   #16
Len013091
My Ride: S52 E30, 330i
Send a message via AIM to Len013091
Cause we can dip the clutch in when the engine starts to bog real bad and potentially save it.
Len013091 is offline   Reply With Quote
Old 11-23-2009, 12:56 AM   #17
iDriftYou
My Ride: is a HighWay monster
Yes its safe. Your car will be sluggish and might stall. Symptoms are different for each car.
-Shehroz
Current: 1990 Toyota Supra
Mods: CP pistons/ Eagle rods/ HKS MHG/ 264 Cams/ Rebuilt CT26
Future: GT35r
My DIY:
DIY ZF 5HP19 Transmission Drain/ Refill : http://forum.e46fanatics.com/showthr...12#post9551712
"My life doesn't only move in a straight line, why should my car?"
iDriftYou is offline   Reply With Quote
Old 11-23-2009, 01:11 AM   #18
mkodama
mkodama's Avatar
Definitely not safe. The only time you get an SES code is if something is wrong with the emissions system or there is a vital faulty sensor or misfiring is detected. A camshaft position sensor is a vital component.
Camshaft position sensors are frequently used to determine camshaft advance or retard on variable timing engines, as well as they are also frequently used for ignition. Both of these readings are valuable and can cause pinging if incorrect.
Misfiring, pinging, knocking, pre-detonation, etc... is very bad for your engine. If you don't already know what pinging is, it is when the gasoline in your cylinders ignites prematurely. When this happens, the piston will not be at top dead center yet, forcing the piston backwards against the the connecting rod and crankshaft. Extreme stress on all of these parts, and wear on all of bearing that connects them. Also the intake valve will not be completely closed depending on how prematurely this pinging occurs, and you will have exhaust gas shooting through a partly open intake valve, which can cause even more damage.
Old 11-23-2009, 01:36 AM   #19
Dan99
My Ride: 2001 330xi
Thanks for the great info! I am sure glad I read that.
Old 11-23-2009, 09:29 PM   #20
CokMinusTheS54
My Ride: '01 TiAg 325Ci 5mt
I've been driving mine with that code since I bought the car, over two years ago.... Symptoms occurred randomly, then finally happened really bad last night when my dad was riding in the car with me, so he made me send it into the shop to verify what was wrong. They quoted me $225 to fix it but after a bit of looking I decided I'll DIM.
Anyways, is it safe to go with a non OEM part? Here are some I found, just tell me which I should buy.
http://www.bimmerspecialist.com/usa/...FRDxDAodgTh0nQ
http://www.joetlc.com/position-sensor-p-18676.html
Thanks!
~Christian
CokMinusTheS54 is offline   Reply With Quote
