Old 11-26-2009, 10:18 AM   #21
Hartman
My Ride: 2000 323i
Originally Posted by redrum0486 View Post
I'm not going with the 6000k LEDs, so I am going to want the DRL's on as the ones I am sourcing will look very close to the OEM ones.
My concern with the Acc circuit is that since it stays on momentarily after the car is off, it might be a little undesirable with them still on as I walk away from the car. I hope I don't sound to anal over this, but I am very particular with my car and what I want to do with it.
Hartman is offline   Reply With Quote
Old 11-29-2009, 11:07 PM   #22
KILLAJON
My Ride: 2004 bmw 325ci
does any one know how do i connected my halos
KILLAJON is offline   Reply With Quote
Old 11-29-2009, 11:08 PM   #23
KILLAJON
Old 11-30-2009, 11:08 AM   #24
daedalus34r
My Ride: 2004 BMW 330i
thats cool, you dont need to go 6000k, just work with a vendor to get whatever color you'd like. I've seen 5000k bright white, looks really nice. 4300k is too yellow for my tastes, but it will fit right in with e90/e39 look.
Well this is something you will definitely need to figure out, sounds like you are willing to lose sleep over something so miniscule.
in my experience:
-- 95% of the time, the AE's shut off approx 6~7 seconds after the ignition is turned off.
-- 5% of the time, the AE's take a significantly longer time to turn off. This may be due to long trips or for some freakish reason the e46 has a ton of spare juice running through the system. My way of fixing this [if i get picky] is to simply turn the car to acc [engine off], let the xenons fire up and run for about 5 seconds and then turn it off again. Now it goes back to the typical 6~7seconds post shutdown run-time.
That is my experience, i'd like ot hear from others to see if they have something similar. You have the right to be picky with your car's performance, functionality, just dont go so far that you limit what modifications you can do to make your ride sweeter.
daedalus34r is offline   Reply With Quote
Old 01-12-2010, 12:43 AM   #25
BigMikeE46
My Ride: 02 325i, 03 SC COBRA
Send a message via AIM to BigMikeE46
say thanks dude....for real he answered every repeated question you had.
Engine is bone stock, rims and tires, 7000k Angel eyes, 7000k Low beam/Fog, Tinted windows ??%....may the mods begin!!!
Below is a pic taken on 1/16/10
Photobucket
BigMikeE46 is offline   Reply With Quote
Old 03-27-2010, 02:17 PM   #26
hummermaniac88
My Ride: 320i
Ok I have a question that is somewhat related. I want to tap the harness to the interior lights so it would fade out when I lock the car or open the car. However I do not have a footwell light. Where would be the next closest light or accessory that I could tap into?
Thanks!
hummermaniac88 is offline   Reply With Quote
Old 04-30-2013, 09:21 AM   #27
e46ken
My Ride: 01 e46 330ci
Pictures of the wire to tap into? I am installing angel eyes on my 2001 330 CI also. I want them on when the Ignition is on and off when I turn the key off. Which wire do I tap into? Thank you
e46ken is offline   Reply With Quote
