Sponsored by BAVSOUND
Old 07-31-2012, 02:11 PM   #21
Handsome Kev
My Ride: 328
Originally Posted by XXXXXJASONXXXXX View Post
I'd say yes put the crossover in the door between the tweeter and bass as per my photo above, the crossover has two outputs one for the bass and one for the tweeter. Remember to remove the inline resistor on the tweeter cable if it is present in your car (see photo above) and solder connections for best results.
http://www.diyaudioandvideo.com/FAQ/Crossover/
There's lots of videos on the web for how to wire a crossover - google is your friend
Thanks, I was simply referring to the wire colors and what wires am I running to the crossover in the amp slot since I have no amp
Sent using Bimmer App
Handsome Kev is offline   Reply With Quote
Old 08-01-2012, 09:14 AM   #22
XXXXXJASONXXXXX
My Ride: E46 M Sport Cab
Exactly, mine has no amp and if you did, chances are the amp has a crossover built in so you wouldn't need to use the ones that came with your speakers. So use the harness wires to feed your crossovers and put in a new cable FROM the crossover to your speakers OR splice and solder some new connections into your existing harness so you can retain the factory terminals if ever you want to revert back and use the new connections to feed the crossover and again use new cables to connect your crossover to the speakers.
Colours are:
http://www.e90post.com/forums/showth...t=52193&page=2
XXXXXJASONXXXXX is offline   Reply With Quote
Old 08-02-2012, 01:17 AM   #23
Handsome Kev
My Ride: 328
Yeah but which wire do I connect to the amp spot on the crossover?
Old 08-02-2012, 06:23 AM   #24
jgold47
My Ride: 2004 X5 3.0
whatever you are using to feed the signal.
that said, if you are using the factory amp, I wouldnt bother with the crossover, and just go directly to the speakers, the factory amp is already crossing over.
let me know how your install goes, I just got the same speakers.
Religion, Politics, and which oil is the best to use. Three things never to be discussed in polite company...
my about me link
http://forum.e46fanatics.com/showthread.php?t=791566
jgold47 is offline   Reply With Quote
Old 08-03-2012, 09:52 AM   #25
Handsome Kev
My Ride: 328
I just hacked the oem speaker connectors off and soldered them to the new speakers. I'll post up pics later
Old 03-01-2014, 10:13 AM   #26
Daron666
My Ride: 02 330CI Coupe
Has anyone used infinity ref 6500cx speakers for the front doors in a coupe? I currently have hk speakers with factory amp.
Daron666 is offline   Reply With Quote
Old 03-06-2014, 11:09 AM   #27
jmillsner
My Ride: 330Ci 6 Spd, 335Cic
i actually wouldn't splice into the stock connections if you don't have a factory amp, running aftermarket speakers on stock H/U power isnt going to be good. and if you're going to get an aftermarket amp then use your own wiring for better quality
jmillsner is offline   Reply With Quote
aftermarket, connector, door, speaker
