Old 11-30-2009, 05:20 PM   #1
jgall
My Ride: BMW 325xi
Question 325xi Acceleration Issue
Today 03:15 PMjgall
I have a 2003 325xi with about 1280k miles. The car has developed an intermittent issue that only appears after the car has been driven for 90+ miles at 65-75 mph. At this point, if you come to a stop and then attempt to accelerate, the car shutters violently. However, if you let off the gas slightly and let the car VERY SLOWLY accelerate, the shutter does not occur. If you stop the car and let it rest/cool for about 30 minutes, the shuttering does not occur until you have driven for a considerable distance has high speed. It does not occur when the cruise control is on operation. However, if you turn the cruice control off, to rapidly accelerate to say, pass a vehicle, the shuttering will occur. The computer throws no error codes and the BMW mechanic finds no problems. Any ideas or recommendations? Much appreciated.
jgall is offline   Reply With Quote
Old 11-30-2009, 06:17 PM   #2
botaman
My Ride: 330xi/530 Blown
Classic problem with XI, the grease inside the front CV boots gets warm and run off after driven.
You need to re-pack your front CV joints both sides, and might as well replace those boots too.
But if the grease inside the CV joints has been dried for a while then you may need new front axles.
botaman is offline   Reply With Quote
Old 11-30-2009, 06:20 PM   #3
mvrk10256
My Ride: E30 325i
if yours is an auto then the accelaration problem is perpetual......
Old 11-30-2009, 06:21 PM   #4
ixtoxi
My Ride: 02 330xi, 88 325iX
Precisely!
ixtoxi is offline   Reply With Quote
Old 11-30-2009, 06:25 PM   #5
jgall
My Ride: BMW 325xi
Thanks for the reply regarding the CV joints. Interesting enough, I had the front outer CV boot and shaft seal replaced shortly before this issue appeared. The front inner CV boot was replaced about 5 months later and left front inner CV boot was replaced a second time 3 months after that. A BMW dealership did the work. Is it possible that something was done wrong or the wrong type of CV grease was used? Thoughts?
Old 11-30-2009, 06:51 PM   #6
botaman
Never a good idea to do outters and then inners separately, labor wise it just doesn't make sense, and by the time you're done with pounding the hec out of the hub to get the halfshaft spline back in there the old ones started to give up.
Old 11-30-2009, 10:23 PM   #7
GCoop
My Ride: '04 325xi
Today 03:15 PMjgall
Automatic?
If so it could be one of 2 things depending on the type of shudder.
the first one has already been mentioned. Inner CV joints need to be repacked if they are still in good condition.
The second is it could be your tranny. (if you have an auto) I had the shudder with the same symptoms as you have described. Only ocurrs after a peiod of highway driving. and only on normal acceleration and above. Mine ceased doing this after I changed the tranny fluid.
GCoop is offline   Reply With Quote
Old 12-01-2009, 11:11 AM   #8
jgall
My Ride: BMW 325xi
Nope, not an automatic. 5-speed stick. But I did wonder if it could be the clutch.
Old 12-01-2009, 11:15 AM   #9
jgall
My Ride: BMW 325xi
Thank you everyone for your posts regarding my acceleration question. The car goes to the mechanic tomorrow.
Old 12-01-2009, 11:29 AM   #10
GCoop
My Ride: '04 325xi
I would think it has to be the the inner axle joints then. Let us know how it turns out.
Old 12-01-2009, 12:16 PM   #11
FastKA24DET
My Ride: 330ci,Turbo Altima2k
Do u have any engine codes because it's like mine
FastKA24DET is offline   Reply With Quote
Old 12-01-2009, 04:19 PM   #12
jgall
My Ride: BMW 325xi
Unfortunately the computer is not throwing any codes.
Old 12-01-2009, 04:53 PM   #13
FastKA24DET
man i have the same problem check your secondary air injection pump, i have read somewhere that it can get clought up and that could couse that.
I got this code with my car and i have same problem as u do
P0412 Secondary Air Injection System Switching Valve A Circuit Malfunction
Old 12-01-2009, 05:22 PM   #14
botaman
Secondary air pump has nothing to do with car vibration underload.
Old 12-01-2009, 06:31 PM   #15
So Lowww
My Ride: E36M
Today 03:15 PMjgall
thats alot of miles
S T A N C E | W O R K S
So Lowww is offline   Reply With Quote
Old 12-02-2009, 02:38 AM   #16
FastKA24DET
Well found online that it sounds like inner cv boot, so checked that. i will check mine today because i know when i change my outer cv boot on the inner i used clamp that you tight with screw driver so i guess it got loose and grease came out.
Stupid of me, I was going to buy the right clap but i forgot, i really hope that that is the case.
acceleration, intermittent, shutter
