How to diagnose Xenon outage-ballast/igniter/bulb - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 11-30-2009, 06:46 PM   #1
skiierb54@
My Ride: 2005 330xi Oxfrd Grn
Send a message via Yahoo to skiierb54@
Hi guys,
I just wanted to post because I came home today to find that while my relative was driving my car today (05 sedan 330) my driver side xenon light apparently went out.
After searching for quite a while i've found that any of these three parts or combination or parts could be the problem. My question is...
How do I best diagnose/troubleshoot the problem so I can avoid the dealership and replace the proper components myself making sure that I only replace what is necessary...Mind you the car only has 23K miles on it and I did not expect the bulb to go out!
I would assume to test all three components separately but I am not sure of the process...i have read the DIY of taking about the light assembly but just have no idea where to go from there..
Any help greatly appreciated!
Nolan
skiierb54@ is offline   Reply With Quote
Old 11-30-2009, 08:18 PM   #2
jaray
My Ride: 2004 330ci ZHP M-pkg
Since I was just at the headlight swapping out my bulbs, I'll add my thoughts while I was in there.
Now that I've seen the contact points for where the ignitor or ballast make contact with the bulbs I could see this potentially being a problem at some point. I would think that if any of these metal contact surfaces was to become dirty or somewhat greasy you could experience the odd time where a bulb might not fire. Check the back of the red ballast/ignitor, I noticed a round flat metal contact. You'd definitely want to make sure that was always nice and clean for it to make a good contact.
Just a suggestion...
jaray is offline   Reply With Quote
Old 11-30-2009, 09:08 PM   #3
mujjuman
My Ride: not an E46
first thing you should do, is to switch bulbs.
before you do, wear clean rubber gloves, so that any grease from fingers does not get on the bulbs and cause them to wear out quicker.
take the passenger side bulb and switch it to the drivers side. turn on your headlights and see if that works.
if it doesnt work, then the problem is iether with ballast or ignitor, and you have ruled out the bulb.
i hope its a bulb
mujjuman
2003 325xi 5MT
Jet Black, ZSP, ZPP, ZCW, OEM Xenon ^^RIP
sig by Solidjake
mujjuman is offline   Reply With Quote
bulb, facelift, sedan, xenon
