Thread Tools Search this Thread Rating: Thread Rating: 9 votes, 5.00 average. Display Modes
Old 06-19-2013, 01:02 PM   #41
taylor192
My Ride: 2003.5 M3
Mine reads '----' with 2L left in the tank. Use the hidden menu to read the tank level, or know that we have a 62L tank and I put in 60L at '----'.
I agree it is not smart to run the tank to empty. It is hard on your fuel pump and you're not saving anything since you have to fill up eventually. I did it once to see how much would be left if I ever was far from a station, since stations can be hard to find in my city.
That said, I could go 100 miles on '----' ... provided it was all downhill
Old 06-19-2013, 01:17 PM   #42
Shadow330xi
My Ride: 2001 Red 330xi
I was driving from Colorado to California through Utahs desert. And I was asleep with my friend driving, and he passed the last gas station for the next ~130 miles, and it got down to having 0 miles on the computer for about 30 miles. Needless to say, I was quite nervous about be stranded in the desert.
Shadow330xi is offline   Reply With Quote
Old 06-19-2013, 02:58 PM   #43
dgknight
My Ride: 02 325xi 5sp 120k
I recently had to swap out my fuel pump, and wanted to run the car dry first for safety reasons and to pump as much crap through the old pump as possible. The car ran for 10 nervous stop and go miles on ----, then sat idling in my driveway for over half an hour before it finally coughed to a stop. There was still gas in the tank and if not for the uphill slope in the drive, it may have run longer IMO.
dgknight is offline   Reply With Quote
Old 06-21-2013, 04:04 PM   #44
AudiEtr
My Ride: 330i
Originally Posted by beeemerdude View Post
Why would anyone purposely try to run out of gas just to see how far they can go after a 0 miles reading?
to see how far it would go after 0 miles.... I would rather know and not need the info then need the info and not know.
AudiEtr is offline   Reply With Quote
Old 06-21-2013, 06:23 PM   #45
havnfun328
My Ride: '99 328i, '03 M5
How far can you get after the fuel light comes on?
It's funny reading the people who say you will suck up junk from the bottom of the tank if you run out of gas. The pump feeds from the bottom so anything there will get sucked up first. Now stuff floating on top - that's different.
2003 E39 M5 Lemans Blue: Truly an amazing car
1999 E46 328i Bone stock 5-speed: Beater and Track Car
250K!!!!!!!!!!!!!!!!!!!
havnfun328 is offline   Reply With Quote
Old 06-21-2013, 07:16 PM   #46
jdstrickland
My Ride: '94 325iC & '00 323i
AND, when stuff got sucked up from the bottom of the tank, the tanks were made from sheet metal and they were prone to rusting and introducing the stuff one wants to avoid. If one is buyuing gasoline today in a Third World country like the United States of America, stuff in the gasoline that came out of the supply chain is pretty close to non-existant.
If you are driving in Mexico and getting your gas there, you _might_ get crap floating in the bottom of the tank, but the rest of North America should have a pretty sterile (clean) fuel supply chain.
Your BMW has a plastic gas tank, and it should be as clean as the day it was installed.
There is no reason to even attempt to drain the tank before doing service. You do not want the tank full, that's true. But there is no need to drain it so dry that the engine stops running. Drive to somewhere below 1/4 tank and do whatever you need to do. Do not smoke while doing it.
Old 06-21-2013, 07:23 PM   #47
JimErskine
My Ride: 2002 E46 Convertible
Hey that's what were trying to tell you, top goes to bottom when its empty. The biggest problem is a fuel pump burning out as it strives to supply 30 PSI and has air not fuel to pump! Hey burn it out its only money.
JimErskine is offline   Reply With Quote
Old 06-21-2013, 07:49 PM   #48
dgknight
Yes, my tank looked pristine when I yanked the old pump, and that was with 117k miles on it, and run to the bottom more often than I care to admit. I think the main argument for not running it too low now that I can see how the pump sits in the tank, is to stop it overheating.
The way the tank is designed, I can't see anything getting the opportunity to 'settle' to the bottom of the tank due to the circulating of fuel from the left of the tank to the right by the pump.
Since I was doing the service in my driveway (gas heater in the garage) I wanted as little gas as possible in it, and burning out an already burned out pump was not really a concern I had, just minimizing the fuel on hand in case one of my neighbors came by smoking.
Old 06-21-2013, 08:14 PM   #49
wildirish317
My Ride: 2004 325Ci vert
You know, if you can walk, you can go as far as it takes to get more fuel.
“The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed.”
Originally Posted by Mike Miller
I just don't know what I'd do with 560 hp that doesn't involve getting arrested.
wildirish317 is offline   Reply With Quote
Old 06-21-2013, 09:40 PM   #50
2003 325i
My Ride: '03 Orient Blue 325i
Originally Posted by Zell View Post
Definitely a smart thing to do to make sure you don't get too close to E, but not something necessary. I'd say that is more important in rural areas where gas stations are more sparse.
Speaking of which, I should probably do mine at some point too since it's so simple and relatively cheap.
I think the soft fail due to running the tank low is a lie. I'm blaming it more on a clogged fuel filter. In my 110K kms of ownership of this car I would say that 96% of my fillups are with the light on. I've never seen the "----" but have been to 11 kms early in my ownership and 32 kms just last week. I routinely fill up with approx. 80 kms to E.
Originally Posted by MTA330ci View Post
Does anyone have a recommendation on which is the best high performance valve stems?
Old 06-21-2013, 10:19 PM   #51
fishb0n3
My Ride: 323ci convertible
once i drove it till it showed 1 mile and the other time i drove it till it showed something like " ----- " but both times i was trying to see how far will it go.. i think i drove fairly 55+ miles ( that was with my 323ci ).
When it showed "----" i was in the gas station already.
2002 Viper GTS "2k original miles"
2003 e39 m5
1969 pontiac GTO the judge
1990 corvette ( C4 ) ZR1
2002 325ci vert " project car "
2000 323ci vert -totaled-
2003 z4 3.0i -sold-
fishb0n3 is offline   Reply With Quote
Old 06-21-2013, 10:49 PM   #52
beeemerdude
Banned User
My Ride: Cabrio. Stick.
I truly don't understand. If you own a BMW, you can't fill it with fuel? (keep it above the 1/4 mark? ) Unless it's a "thing" to try to test things to the max?.... I just read, long ago. on these BMW forums, DON'T DO IT...you'll wreck your fuel pump, your filter will get clogeed up of crap,...but most important to me....your dash lights will light up like a Christmas tree. The 3rd thing did it for me. I used to always run dry w/ my winter beaters, etc,...but do this in a BMW..? I think not. . I take some forum threads/posts srs'ly,...I like my dash lights nice & black. I refuse to pay a dealership $500 to remove some dash lights..What a waste. (To me,..like paying for an anchor tattoo on your 4-arm. waste of $)
beeemerdude is offline   Reply With Quote
Old 06-22-2013, 12:37 AM   #53
iRide113
My Ride: 2004 M3
You shouldn't be asking how far you can go, but rather how many gallons are left in the fuel tank. Everyone drives different and can get different MPG. I personally never let my car get below 1/4 full.
iRide113 is offline   Reply With Quote
Old 06-22-2013, 12:38 AM   #54
XKxRome0ox
Black and Proud
My Ride: RIP e46/'16 328i
Live a little
[bimmerapp]
2016 BMW 328i 6MT/M Sport Package/Track Handling Package/BMW M Performance Exhaust/Injen CAI
XKxRome0ox is offline   Reply With Quote
Old 06-22-2013, 10:16 AM   #55
AudiEtr
My Ride: 330i
I love how some people think they have it all figured out. Sure it's nice to never see your gas light, but some of us live in the real world... I never dropped below a half tank b4 the recession. Between 2008-10 only thing I cared about was paying it off and putting food on the table. And your anchor tatoo comment makes no sense at all.... My grandpa has one on his arm from the boat he was on in the war, I'll tell him you think it's dumb...
Old 06-22-2013, 10:35 AM   #56
Leezy321
My Ride: 2001 bmw 325i
And? We're talking E46 BMWs here.. Same price as a Civic Si, Toyota Corolla, RSX, Mazda 3, etc... It's not good to run ANY car out of fuel. Just because you/we drive a decade old BMW are we supposed to have higher standards in life or something? Are we supposed to have more $$$ than the guy driving his 06' Civic Si?
Anyway, I drove from Boston to my house (all highway) with my fuel light on. That's 19 miles. Then another mile the next morning to the gas station after all, it is a BMW.....
Leezy321 is offline   Reply With Quote
Old 06-22-2013, 01:24 PM   #57
Tbone8ty
My Ride: 2003 330i
in the manual it says my 2003 330i has a 2 gallon reserve...
usually when i fill up its about 16 gallons when yellow light comes on.
Tbone8ty is offline   Reply With Quote
Old 06-22-2013, 01:45 PM   #58
MJLavelle
My Ride: 2001 BMW 330ci
Well, I can take at least 2 of those worries away from you. Running your car out of gas is not an ideal situation, but it won't harm anything, and definitely not the engine. The first step to replacing the fuel pump or filter is to pull the fuse, and start the car, to depressurize the fuel system. Sure, everything will light up on the dash. It's supposed to - you just killed the fuel flow to the engine.
The second one is the urban myth of the "gunk at the bottom of your fuel tank". If you are driving a 1950 Pontiac, you may have some gunk in there. But I would be willing to bet that yours is nice and clean. So, you will not clog your fuel filter. First, because there is no gunk there. Second, and this is important, your fuel pump draws from the bottom of the tank all the time! If there was gunk, you would suck it in if the tank was full or empty. If you have ever replaced your fuel pump, you should have noticed the intake screen at the bottom of the pump.
The fuel filter clogging trash at the bottom of your tank does not exist!
Old 06-22-2013, 08:49 PM   #59
2003 325i
I can fill my car up whenever I want, I'm just not some paranoid fuelomaniac who thinks that if I run my tank low it's going to shorten the lifespan of my fuel pump. Like I said I run it low every tank with no adverse effects. 190K kms and counting... hey at least I know my low fuel light works
Old 06-23-2013, 11:47 AM   #60
e46techtuner
My Ride: 2000 328i
Some people just don't take care of their cars. Im a technician, I have seen the insides of engines and replace fuel pumps very often. I recommend filling up at 1/4 tank, changing fuel filters yearly and use fuel treatment once or twice a year. People who neglect to do this will get poor gas mileage and performance, ruin filters, pumps, level senders, injectors, valves, pistons and cats. I would even recommend replacing the fuel pump just because its old and has lots of miles.
e46techtuner is offline   Reply With Quote
empty, fuel, miles
