Old 12-01-2009, 02:13 PM   #1
aggieE46
Keep it clean
aggieE46's Avatar
My Ride: 03 Evo, 07 Passat
New Stett Performance Radiator Hoses
Hey Guys! Just got these this morning. Big thanks to Chad Stett of Stett Performance for making this boy's dream a reality. I was going to go by and pick them up, but Chad wanted to install them and make sure everything was perfect (and it is). Perfect fitment, top quality. Very thick. Kit includes the 2 large hoses, new hose clamps, and new, oversized o-rings. The hoses are VERY heavy duty. I don't think an exploding fan would take these out.
These will fit all E46 M54 engines. Chad also has the M3 hoses available.
He's working up pricing. I'll have it soon. If you guys are interested, send me a PM with your name and email. I'll get you pricing when he has them available.
Also, he's finishing up the tooling on the intake hoses. Those should be awesome!
Pics: (Excuse my dirty engine bay, I would have cleaned it up if I had known there would be pics today).
Old 12-01-2009, 02:33 PM   #2
AdamBath
My Ride: E30
That looks great!
AdamBath is offline   Reply With Quote
Old 12-01-2009, 02:36 PM   #3
Devious1
Invalid User
My Ride: 330ci
Send a message via AIM to Devious1
sweet hose!
Devious1 is offline   Reply With Quote
Old 12-01-2009, 02:36 PM   #4
poynter
My Ride: RAV4
Did you have to modify the radiator and thermostat housing to get these to work? It looks like there is still a piece of the lower hose there with the temp sensor attached...
-tony
poynter is offline   Reply With Quote
Old 12-01-2009, 02:42 PM   #5
aggieE46
Keep it clean
aggieE46's Avatar
Nothing has to be modified. You just have to cut off the old metal clamps and reuse the plastic couplings.
Old 12-01-2009, 02:50 PM   #6
aggieE46
Keep it clean
aggieE46's Avatar
Chad said he could work up a group buy. Let's see if we can get some interest so we can get you guys a good discount!
STETT Performance E46 Silicone Radiator Hose Kit
These large bore 4 ply extreme duty silicone hoses can withstand temperatures up to 550 degrees and maintain flexibility down to -65 degrees. Specially formulated Viton oring replacements provide a higher resistance to petroleum products and antifreeze while providing a greater seal under extreme temperatures thanks to tighter tolerances aimed at reducing thermal expansion under high heat. Each kit comes with upper and lower silicone hoses, replacement connector orings, aux fan switch oring and hose clamps. Available in red, blue and black.
Kit Retail: $145
Old 12-01-2009, 02:59 PM   #7
Devious1
Invalid User
My Ride: 330ci
what would the GB pricing look like?
Old 12-01-2009, 03:01 PM   #8
aggieE46
Keep it clean
aggieE46's Avatar
Dunno. More people = cheaper. Start a list.
1.
2.
3.
4.
5.
6.
7.
8.
9.
10.
Old 12-01-2009, 04:21 PM   #9
Megalocnus
My Ride: 05 330i ZHP/MT
What's the advantage? The original hoses are cheap and of good quality too.
Megalocnus is offline   Reply With Quote
Old 12-01-2009, 04:33 PM   #10
aggieE46
Keep it clean
aggieE46's Avatar
You'll never have to change these. They definitely won't blow up on you at the track.
Old 12-01-2009, 04:43 PM   #11
bcs325ci
My Ride: blown
If the price was right, I would probably get a red set.
bcs325ci is offline   Reply With Quote
Old 12-01-2009, 04:44 PM   #12
Devious1
Invalid User
My Ride: 330ci
Originally Posted by bcs325ci View Post
if the price was right, i would probably get a red set.
+1
Old 12-01-2009, 04:44 PM   #13
B
OG Moderator Extraordinaire
B's Avatar
My Ride: 325iX-M3-525iT-M5
Send a message via AIM to B
what about M52TU? S52? thx
B is offline   Reply With Quote
Old 12-01-2009, 04:44 PM   #14
aggieE46
Keep it clean
aggieE46's Avatar
Get some people interested in a group buy. I'm sure we can get the price down.
Old 12-01-2009, 04:46 PM   #15
aggieE46
Keep it clean
aggieE46's Avatar
Yep, should work fine. I believe they use the same radiator hoses.
Old 12-01-2009, 04:47 PM   #16
paraklas
My Ride: ESS TS2 320ci
ESS's modified radiator hose is just an OEM one reversed.. I wonder if I can stick these hoses in place. They do seem thick, are they flexible enough?
thanks
Old 12-01-2009, 06:16 PM   #17
Megalocnus
^Ha, I like how they've pushed the upper hose away from the intake pulley :-)
Old 12-01-2009, 07:41 PM   #18
Autobot325i
My Ride: 2003 325i E46
Send a message via AIM to Autobot325i
hell of a lot better than VF where youpray the hose does not expand to the point of scraping the upper hose. twice its happen to me. in for this set aggie..let me know
***NEW UPDATE***
1985 318i E30
Autobot325i is offline   Reply With Quote
Old 12-01-2009, 10:01 PM   #19
HighBoostin330
My Ride: 2002 Stock 330Ci
I'd be interested on this if we can confirm it will clear the S/C pulley on the ESS TS kits.
HighBoostin330 is offline   Reply With Quote
Old 12-02-2009, 08:06 AM   #20
aggieE46
Keep it clean
aggieE46's Avatar
I'll see if I can get TXZHP04 to go by and look at it.
