Old 12-01-2009, 07:22 PM   #1
AEmedic
My Ride: 2008 528i
Send a message via Yahoo to AEmedic
P0491 & p0492
My car has these codes and an SES light
Chris
2008 528i - Deep Green Metallic
AEmedic is offline   Reply With Quote
Old 12-01-2009, 07:23 PM   #2
AEmedic
My Ride: 2008 528i
I replaced both hoses near the pump and valve cleared the codes and they came back a day later... It seems to run quietly for about a min in the morning though.
Chris
Old 12-03-2009, 07:59 PM   #3
AEmedic
My Ride: 2008 528i
I just checked the salmon colored Relay behind the glove box and it looked new inside...
Chris
Old 12-05-2009, 08:35 PM   #4
ken@bimmertools
Is NOT A Mechanic
ken@bimmertools's Avatar
My Ride: F30
Please have a look at the article in my signature titled "Is your check engine light on?" BMW maintains a separate, factory programmed diagnostic system that dealers and techs use for actual repair work.
Using a generic OBDII tool (which yielded those P codes) may yield misleading information. Often, a group of chassis-specific BMW factory codes are represented by a single OBDII code Start with the factory codes.
Start with the codes that are meant for your BMW.
ken@bimmertools.com if you have any questions about the article or the Peake Research non-OBDII, BMW-specific scan tools we represent.
Good luck,
Ken
Bimmertools is under new ownership! Please welcome Taylor@bimmertools.com.
Click Here to say hi.
ken@bimmertools is offline   Reply With Quote
Old 04-29-2010, 10:11 PM   #5
e46starbai
My Ride: ...
Did you ever fix the problem? and if so what'd you do?
e46starbai is offline   Reply With Quote
Old 04-29-2010, 11:09 PM   #6
AEmedic
My Ride: 2008 528i
Mine ended up having a bad Air Pump, it was locked up, so I broke it free but it still wouldn't run. I bought a used one off of a guy on here and it works great!
Chris
Old 04-29-2010, 11:23 PM   #7
e46starbai
My Ride: ...
Ah i see...
This is the 2nd time the light came on.. the first time it came on for about a day or two and then came off. That was about 2 weeks ago... This time it seems like its staying on.
Old 04-29-2010, 11:38 PM   #8
AEmedic
My Ride: 2008 528i
Diagnose Follow this link, it will help you diagnose your issue.
Chris
Old 04-29-2010, 11:41 PM   #9
e46starbai
My Ride: ...
wow awesome link, thanks!
