#1 |
Interior gas smell
I smell gas inside the cabin of my car before starting it up. The smell than goes away. There is no smell in thetrunk or engine bay, with the engine off or on.
What would cause fuel vapor in the cabin with the engine off? Fuel filter?
#2 |
Check if your evaporative canister is saturated and leaking gas as a result. Since cabin air intake is at the base of the windshield you would pick up the gas fumes smell. The canister can become saturated by overfilling just once.
#3 |
fuel filter
#4 |
smell seems to have gone away now... I will get under the car and check the fuel filter and canister tonight as you guys have mentioned tonight.
#5 |
keep me posted on what you find, im having a similiar problem with my canister.. any easy fix guys?
#6 |
lift up the rear bench and remove the rubber cap dome things and look for some gas there. If there is any at all, your o ring may need replacement. cheap and easy fix, no biggie.
#7 | |
I will take a look under the seat tonight and I have not ruled out the fuel filter connections either. But, what would cause vapor from the tank/lines when the system is NOT in use? I see no leak/drip under car either.
![]() Last edited by pjo33us; 12-03-2009 at 11:41 AM. |
#8 |
This is a realoem.com diagram of the fuel ventilation
![]() some components can be stressed by a saturated canister which is below the trunk. Also check the purge valve and fuel injection rail. There is less fuel evaporation in cold weather.
![]() Last edited by xi_ter; 12-03-2009 at 02:12 PM. |
#9 |
im having the same issue
![]() would anyone be kind enough to walk me through some of the steps on how to check things out? it would be greatly appreciated
- Stan Peng - EUROPROJEKTZ Southeast | Co-Director ![]() |
#10 | |
Any idea why the smell disappears once I start the car? Thanks everyone for your input.
#11 |
UPDATE: Smell is completely gone. I have done nothing. I have not even checked the fuel filter. I am now under the assumption that the evaporative canister in the rear near the fuel tank was saturated and that excess fuel has worked its way thru.
#12 |
Eat less fiber
#13 |
Hello Fanatics,
I know it's an old thread but i don't want to start a new one, I've noticed the smell right after refueling and sometimes without. Also my fuel gauge is not so accurate, are they related, any idea on a DIY on how to take care of this issue, Help will be greatly appreciated. thanks
Last edited by Bimmer_Addict; 10-04-2012 at 08:56 AM. Reason: horrible spelling!! |
#14 |
My Ride: '03 325i --> '13 GTI
Parents jag had the same issue. Popped the rear seat bench off to inspect the gas tank seals, sure enough, they were in need of replacement. I'm guessing that could very well be the cause in e46's as well |
| Tags |
| fuel, gas, interior, smell |
