Thread Tools Search this Thread Rating: Thread Rating: 17 votes, 5.00 average. Display Modes
Old 12-05-2009, 12:59 AM   #1
bimrkid
My Ride: 2002 BMW 325CI
Accidently cleaned my MAF with carb cleaner...will this ruin it??
I cleaned my MAF sensor with carb cleaner....im hoping it doesn't get ruined, with 150K on it though ill prolly have to replace it soon anyway right??
bimrkid is offline   Reply With Quote
Old 12-05-2009, 01:36 AM   #2
mkodama
mkodama's Avatar
Carb cleaner is nasty stuff from what I've heard, but I only have experience with CRC MAF and brake cleaner (same active ingredient). I'd think the working parts of your MAF would be fine being that it's glass and metal, which are pretty chemically resistant, but I'd be worried if the carb cleaner was harsh on plastic, or left a residue of any sort.
Old 12-05-2009, 01:40 AM   #3
Kris.R
My Ride: 2012 Dodge Charger
Not to thread jack, but where exactly on the MAF do you spray the CRC MAF cleaner on?
- Kris -
"America will never be destroyed from the outside. If we falter and lose our freedoms, it will be because we destroyed ourselves."
-Abraham Lincoln-
Kris.R is offline   Reply With Quote
Old 12-05-2009, 01:45 AM   #4
mkodama
mkodama's Avatar
Everything inside of the tube. Use liberal amounts. Plastic grills, metal screens, and most importantly, the wire/tube/resistor/electronic thingy hanging down into the middle of the MAF.
Old 12-05-2009, 01:57 AM   #5
kuksul08
My Ride: M3
I have used B12 Chemtool carb cleaner and that stuff is very nasty, I wouldnt be surprised if it melted plastic or made it very brittle.
Look at that subtle jet-black coloring. The tasteful thickness of it. Oh my God, it even has a 6mt.
S54 Valve Adjustment Spreadsheet & Info: http://dl.dropbox.com/u/28231781/S54...ent%20info.zip
S54 VANOS DIY Video: http://www.youtube.com/watch?v=9SkT2j3jsU0
kuksul08 is offline   Reply With Quote
Old 12-05-2009, 02:03 AM   #6
e46techtuner
My Ride: 2000 328i
I clean my MAF once or twice a year with MAF sensor cleaner. My original sensor went out around 40k...new one, now at 90k running(reading) strong!
e46techtuner is offline   Reply With Quote
Old 12-05-2009, 09:16 AM   #7
Hartman
My Ride: 2000 323i
Get the right stuff QUICKLY and clean the MAF again. Then see if your car runs right. The sensing element in the MAF is VERY fragile...so I fear the worst on this one.
Hartman is offline   Reply With Quote
Old 12-05-2009, 09:18 AM   #8
GoingNuts
Just Nuts
My Ride: 2004 330Ci
Instead of asking for random guesses from random people on the internet for random answers, why don't you use the MAF and see if it is ruined ? Since you probably don't know how to clean the MAF anyway, I don't think it matters what you put on the MAF. The outcome would be the same: crap. If you have crap on the MAF in the first place, it makes little difference if you put a bit more crap on it. Somehow, believing putting some crap on it can get rid of some other crap on it is just plain foolish. Imagine if you have some crap on your floor, do you A: remove the crap from the floor, or B: spray some other crap on the crap and be satisfied the crap will somehow cancel each other out ? The principle for crap on the MAF is the same. MAF's are expensive to buy for a reason. These are lifetime parts if you learn to eliminate crap from it. How difficult can it be ?
GoingNuts is offline   Reply With Quote
Old 12-05-2009, 10:36 AM   #9
330ciandr6
My Ride: .
Send a message via AIM to 330ciandr6 Send a message via Yahoo to 330ciandr6
carb cleaner shouldn't hurt it...
Have a oil or coolant leak? Click here!:http://forum.e46fanatics.com/showthr...732&highlight=
ABS/DSC/Brake/Airbag light on?? Click here!:http://forum.e46fanatics.com/showthr...648&highlight=
330ciandr6 is offline   Reply With Quote
Old 12-05-2009, 10:56 AM   #10
Hartman
My Ride: 2000 323i
Lifetime parts eh? Guess the hundreds of posts about bad or malfunctioning MAFs is just fantasy.
Old 12-05-2009, 11:17 AM   #11
Custom3
My Ride: HellRot 330CI
MAF dont have a set mileage for replacement...so it is pretty much something that should last the life of the vehicle if taken care probably....the hundreds of post your talking about, im will to bet 99% have some kind of after market intake installed. If you stick with a oem intake you should be fine.
Carb cleaner will not damage your sensor....how do I know? I have used it before on my MAF by mistake....so OP connect your sensor..turn the car on...and report back to us.
Old 12-05-2009, 11:22 AM   #12
shellback
My Ride: BMW with rear wiper
curious what a new MAF goes for
shellback is offline   Reply With Quote
Old 12-05-2009, 11:32 AM   #13
TxTorqueMade
My Ride: 330i
Send a message via Yahoo to TxTorqueMade
Approx 350.00
BMW e30 Bling
TxTorqueMade is offline   Reply With Quote
Old 12-05-2009, 11:40 AM   #14
guest0711
Banned
My Ride: 2006 bmw m3 coupe
is there anyway that if you let your car sit in the cold,that the MAF can freeze or the weather can damage it and your car will not start?
guest0711 is offline   Reply With Quote
Old 12-05-2009, 11:55 AM   #15
jzwu
My Ride: 2005 BMW 330Cic
The culprit may be after market air intake system/filter that fouls the MAF. On the Maxima.org forums, people have been debating and doing MAF cleaning with the CRF cleaner and I found out most folks have after market air filter/system or some sort. Usually the oil particles from those stuff foul the MAF.
I never ever needed to clean the MAF on my 2001 Nissan Maxima with 94k miles or my 2005 330Cic with 65k, because I only use the OEM paper air filter and don't mess with it.
Curious if we have a poll to see how many folks need to clean their MAF vs. having after market air filter/system and is there any correlation?
jzwu is offline   Reply With Quote
Old 12-05-2009, 01:46 PM   #16
ixtoxi
My Ride: 02 330xi, 88 325iX
Carb cleaner has toluene and acetone, MAF cleaner is mainly hexane. Toluene eats up many plastics, so I would not use carb cleaner on the MAF. If you already have used it, then clean it again with MAF cleaner.
ixtoxi is offline   Reply With Quote
Old 12-05-2009, 02:18 PM   #17
kuksul08
My Ride: M3
the MAF is a heated wire element I believe, so it shouldn't freeze.
Old 12-05-2009, 03:57 PM   #18
ixtoxi
This is correct. The MAF is a heated wire, part of a circuit called a Wheatstone Bridge. The same technology is used in many different airspeed measuring instruments. It will not freeze.
