Old 12-06-2009, 11:58 AM   #1
lkstaack
My Ride: 04 330iZHP, 05 325iT
Z4 Differential Cover Install (Not DIY)
I just replaced my the differential cover with a cover from a Z4 while I installed a Quaife LSD. This is not a DIY for the procedure. However, I did want to point out two items that are required for a proper install that I didn't know about when I ordered my cover.
The Z4 cover is a direct bolt on for non-M3 E46 differentials. However, you need to purchase two additional items: 1)Loctite 5970 Gasket Maker, and 2)one 60mm diff bolt (M10X60-8.8-ZNS up to 9/03 build or M10X60-10.9ZNS3 from 9/03)
You won't find diff gaskets any more; BMW uses the loctite in lieu of a gasket. The loctite is difficult to find outside of BMW dealerships, but it is out there. BMW charges about $45 a tube. Off the shelf products will not resist gear oil the way the loctite product does; the diff will leak after awhile.
Although you can reuse the bolts from your old diff, the Z4 cover requires one bolt that is longer than the others.
Lars
2004 330i ZHP ESS TS2
lkstaack is offline   Reply With Quote
Old 12-06-2009, 04:27 PM   #2
kaotek323i
My Ride: red 1999 323i
what are the advantages of the z4 diff cover?
1999 BMW 323i... MR. CARBON FIBER
raceland coils, ACS Front Tower bar-Rotora Rear, 19's 8.5 front & 9.5 rear,
Carbon Fiber- kidney grill, shark fin, headlight eyebrows/inner trim, rear window wing, acs mirrors, b-pillars, front splitters, Oem hood, Csl trunk, gas lid, interior trim
VF stage1, v2 compressor w/ v1 internals, ebay headers
kaotek323i is offline   Reply With Quote
Old 12-06-2009, 11:15 PM   #3
B33MER
My Ride: 330i SMG M-Sport
Also ... Can you write a short review on the lsd ? did you feel any improvement?
Thanks for sharing
330i SMG M-Sport Paket II Euro Spec
Mods:
CF Roundels all around, Black grillz, 7000k Angel eyes,6300k HID fog lights, Hamman Lip reps, ACS roof spoiler reps, Alutech front and rear struts, BMC CDA with DIY heatshield, Pro RS braided brake line, ///M Billet Oil Cap, OEM ///M mats, ///M aluminium pedals,
B33MER is offline   Reply With Quote
Old 12-07-2009, 08:44 PM   #4
mrshelley
My Ride: 2004 330i
Just so you know, the run of the mill loctite silicone sealant will work for the diff. For example, the ultra-black will be suffice. For any of you old timers, Permatex Aviation form-a-gasket is excellent (Indian Head Shellac works too) is a cheap alternative.
FYI: Red loctite all of the diff cover bolts if you track your car and run solid bushings. This is a great way to reduce your maintenance time between events (I use a bunch of red loctite on my cars).
Old 11-09-2012, 08:53 PM   #5
Oz Striker
My Ride: '00 330Ci, '07 350Z
Thread resurrection here, but I've just purchased a LSD an awaiting it arrival. I plan on installing the Z4 finned diff cover, my car is a pre 03 model so i will be buying the M10x60-8.8-ZNS version of the long bolt. However for the remaining 7 bolts will i need my E46 bolts or the equivalent Z4 bolts for models up to 09/2003?
For those interested and wondering why install the z4 cover, the fins help keep the diff oil cooler and thus better protection for the diff itself. E46's didnt have diff fins.
My YouTube Channel incl Muffler delete vids: http://www.youtube.com/user/OzStryke...view_as=public
My blog on E46 DIYs & Mods http://lifewithabmw.blogspot.com/
Oz Striker is offline   Reply With Quote
Old 11-09-2012, 09:48 PM   #6
Steven747
My Ride: 05 330ci
i used autozone permatex. 5 months later and zero leaks. i also used a oem gasket that i was able to find from a member on here so i used both
i have non lsd 3.46 with finned diff cover. it look awesome under there
Old 12-27-2012, 10:49 PM   #7
rkneeshaw
My Ride: 330i ZHP
Looks like this stuff could be safely used as an alternative to the pricey loctite 5970 stuff:
http://www.permatex.com/products/pro...t-maker-detail
Permatex part number 81182
2003 BMW 330i ZHP
ESS Twin Screw Stage 2 - Wavetrac - Headers - Magnaflow - BMW Performance
Turner Motorsports - Powerflex - StopTech
Build thread: http://forum.e46fanatics.com/showthread.php?t=696662
Wheelwell: 2003 BMW 3 Series
Fuelly: 2003 BMW 330i
rkneeshaw is offline   Reply With Quote
Old 12-29-2012, 08:10 AM   #8
rkneeshaw
My Ride: 330i ZHP
Also the BMW part number for the longer bolt is 07119905148
2003 BMW 330i ZHP
Old 01-02-2013, 11:09 PM   #9
lui328i
My Ride: 99 Bmw 328i
It finned so it keep oil cooler
always modding
lui328i is offline   Reply With Quote
Old 01-03-2013, 02:22 PM   #10
wanganstyle
My Ride: e36 M3 / E30 GTS1
The E46 Motorsports Finned cover is avail as a BMW Motorsports part; slightly different casting than the Z4 unit. Same effect also and avail brand new from BMW
The Higher capacity of oil compared to standard cover is nice for thermal stress as well; the cover is also heavier and stiffer/stronger (more metal)
BMW Motorsports cover (NEW):
Z4 finned cover (used)
Casting difference at bolt mounting: the required length of bolts are different!
Z4 finned cover
Billet Original CNC LSD for 188K
http://www.wanganstyle.com/
S54B32 E36 M3 DTA S100 Sedan Street car full swap:
http://forums.bimmerforums.com/forum....php?t=1437471
E30 M20 2,7L Alpina + Euro E46 320D ZF 6 speed install
http://www.e30tech.com/forum/showthread.php?t=110010
wanganstyle is offline   Reply With Quote
Old 06-08-2014, 10:21 AM   #11
paraklas
My Ride: ESS TS2 320ci
Z4 finned cover
Happen to have part numbers or from which model to get the bolts from?
Old 06-19-2014, 11:46 AM   #12
wanganstyle
The BMW motorsports cover (for non-M e46) does not come on any models from the factory; the BMW motorsports car that was shipped from the factory in E46 era is named "M3"
the Z4 rear cover comes from a .......... what model car?
Old 07-01-2014, 08:13 AM   #13
Mafik
My Ride: 320 AT->330 MT turbo
p/n for this cover 33117512980.
It's just finned transmission cover, in case of BMW e46 - only for e46 330(i/Ci/Ci Convertible) for USA with Performance package. Actualy it's a first time when I see "BMW Motorsport" for this cover.
But, in case of e46, this cover fit fine to any TYP 188K differentials
Mafik is offline   Reply With Quote
Old 06-01-2016, 02:09 AM   #14
Taper
My Ride: Espaņa
As I can read on the outside of the diff cover box:
this bolt is also included
What's the correct torque for the diff cover bolts?
Taper is offline   Reply With Quote
