Sponsored by The Tire Rack
Old 11-22-2009, 08:22 PM   #1
seize330
My Ride: 330ci
Tire size question?
Im currently running 265/30/19's in the rear. My rims are 19x9 et 36.
My question is could i run 255's in the rear instead of 265's? without stretchin out my tires?
seize330 is offline   Reply With Quote
Old 11-22-2009, 09:50 PM   #2
VMRWheels
VMRWheels's Avatar
My Ride: 1:25 Scale Enzo
255/30's will work fine and should be sitting fairly square on a 9.0" wheel depending on tire manufacturer.
-Charles@VMRWheels
Kevin @ VMR | Wheels
Tel: 714-442-7916 | Email: kevin.a@velocitymotoring.com
Facebook! | Flickr! | Blog!
Old 11-23-2009, 07:34 AM   #3
Gary@Tirerack
Moderator
Gary@Tirerack's Avatar
My Ride: 1995 BMW M3
-Charles@VMRWheels
Agreed.
Refer to 'Gary/E46Fanatics' as your previous contact when you order online. Credit E46Fanatics.com by ordering through the sig link.
Click sig! -->
Gary@Tirerack is offline   Reply With Quote
Old 11-25-2009, 05:11 AM   #4
seize330
My Ride: 330ci
coo. thanks for the helpful info!
Old 11-25-2009, 05:12 PM   #5
VMRWheels
VMRWheels's Avatar
Not a problem!
-Charles@VMRWheels
Old 12-04-2009, 01:47 PM   #6
BigRoy
My Ride: 330ci
I have the Beyren Mesh wheels, came on the 330ci coupe I just bought, but it has stretched tires right now and they are almost bald, looking into a new set. He told me they are from discounttire.com - which are 19x8.5 et40 and 19x9.5 et45. He had 225/35/19 on the front and only 235/35/19 on the rear.
I've been searching and cant seem to find the answer to my questions. With these offsets, can I run 235/35/19 on the front, and 265/30/19 on the back without rubbing? Stock sport suspension.
BigRoy is offline   Reply With Quote
Old 12-04-2009, 02:36 PM   #7
VMRWheels
VMRWheels's Avatar
With 8.5 +40 front and 9.5 +45 rear, you will be able to run a 235/265 without a problem on a coupe.
-Charles@VMRWheels
Old 12-08-2009, 06:17 PM   #8
seize330
My Ride: 330ci
-Charles@VMRWheels
Whats the best tire/bang for the buck that I should get in 265/30. When I first hand Hankooks I didnt rub in the rear but when I put on Kumhos I would rub frequently..
Old 12-09-2009, 05:09 PM   #9
VMRWheels
VMRWheels's Avatar
Hakooks run a bit narrow with more rounded sidewalls then the Kumho's. How much are you willing to spend?
-Charles@VMRWheels
