Sponsored by The Tire Rack
Old 12-08-2009, 02:35 PM   #1
frogg320
My Ride: 2000 323i
Can you identify these rims?
I was thinking about buying these from someone:
who claims they fit 318i, 320i, 323i, 325i, 328i, 330i, and Z3.
he also included the following code: 7JX16HZ (from the tire? not specified)
Anyway, I don't know of a 3er-compatible rim that looks like this...aren't these e39 rims with the different bore?
If you can help me ID these wheels, I'd really appreciate it! It looks like a good deal, so if they're right I'll take the 45 minute drive to check them out. Of course, I'll test fit, but if you can save me 1.5 hours of useless driving, I'd appreciate it
frogg320 is offline   Reply With Quote
Old 12-08-2009, 03:56 PM   #2
Mike@F1 Autohaüs
Past Site Sponsor
My Ride: E46 330ci
Those wheels are for an E39 5 series and will not fit due to the center bore:
Mike@F1 Autohaüs is offline   Reply With Quote
Old 12-08-2009, 04:11 PM   #3
frogg320
My Ride: 2000 323i
Thought so! Thanks very much. I owe you guys an hour and a half!
Old 12-08-2009, 04:19 PM   #4
SWINFORD
///PIITB
SWINFORD's Avatar
My Ride: Low Life Marie
Send a message via AIM to SWINFORD Send a message via MSN to SWINFORD
They will fit you just need the hub centric rings
Swinford-Hypnotyzd : Dirty South-Swinny
| Hypnotyzd FB |Tischer BMW|
SWINFORD is offline   Reply With Quote
Old 12-09-2009, 05:50 PM   #5
frogg320
My Ride: 2000 323i
Looks like the offset for these is ~20mm...and I need something more in the 40mm range, if I'm correct. Swinford, I know you said you fit e39 rims with spacers, but my research tells me spacers should only decrease the offset--so probably these will poke nomatter what and I'm screwed? Oh well...too bad they look so nice!
Old 12-10-2009, 09:54 AM   #6
SWINFORD
///PIITB
SWINFORD's Avatar
No that makes mine ET15 Makes them poke more. The decreased number makes them poke more the increased number brings them in.
Old 12-10-2009, 12:16 PM   #7
VMRWheels
VMRWheels's Avatar
My Ride: 1:25 Scale Enzo
Spacers will virtually lower the offset of the car (pushing the wheel out) since you are adding more material onto onto the hub. Unfortunately it looks like these wheels will not work without a good amount of modifications.
-Charles@VMRWheels
Kevin @ VMR | Wheels
Tel: 714-442-7916 | Email: kevin.a@velocitymotoring.com
Facebook! | Flickr! | Blog!
Old 12-10-2009, 01:53 PM   #8
SWINFORD
///PIITB
SWINFORD's Avatar
