The Showroom
Thread Tools Search this Thread Rating: Thread Rating: 129 votes, 4.79 average. Display Modes
Old 01-08-2010, 09:43 PM   #381
freshprince2421
My Ride: 325ci
first... omg!!
freshprince2421 is offline   Reply With Quote
Old 01-08-2010, 09:43 PM   #382
Fluxe46
My Ride: is low and slow
Send a message via AIM to Fluxe46 Send a message via MSN to Fluxe46 Send a message via Yahoo to Fluxe46
Neil
im glad you finally got it done
-Chris
[IMG]http://********************/Pictures/Mike/StanceWorks/osamasig.jpg[/IMG]
Fluxe46 is offline   Reply With Quote
Old 01-08-2010, 09:58 PM   #383
JEFFEFECKS
My Ride: 05 IB ZCP
Send a message via AIM to JEFFEFECKS
Neil you are the ****** man!!! Looks so good
'05 IB ZCP AA Stg 2
JEFFEFECKS is offline   Reply With Quote
Old 01-08-2010, 10:09 PM   #384
Chris-alfonso
My Ride: 330i
Amazinggg I love it. This has given me the inspiration to do a color change.
Goodwork Neil all your hard work has paid off
Chris-alfonso is offline   Reply With Quote
Old 01-08-2010, 10:17 PM   #385
evilstar
My Ride: 633csi & 325i
sick
evilstar is offline   Reply With Quote
Old 01-08-2010, 10:24 PM   #386
firefirefire90
Banned
My Ride: suce ma bite
Send a message via AIM to firefirefire90
Damn dude! All your work has finally come out! Keep up the good work!
Best interior or 2010?
firefirefire90 is offline   Reply With Quote
Old 01-08-2010, 10:25 PM   #387
hi its me alec
hi its me alec's Avatar
My Ride: BMWs + 1988 Pathy
Send a message via AIM to hi its me alec Send a message via MSN to hi its me alec
Hell yeah.
hi its me alec is offline   Reply With Quote
Old 01-08-2010, 10:29 PM   #388
Fluxe46
Neil only thing i hope is people don"t think this is an easy just paint it on project
-Chris
Old 01-08-2010, 10:30 PM   #389
neil1138
Oh hai, just some lessons learned and words of advice, don't take these words as truth. Just my experience and tips I think you should use
Dyeing tips:
  • Don't buy foam brushes, buy artist acrylic brushes: 3/4" - 1"
  • When dyeing, do NOT stop in the middle of a panel, make it to the closest seam and stop. If you get bubbles or heavy spots of dye, blow on them to even them out.
  • You might think that you will get brush marks, swirls, etc when the dye dries, but just be patient, they will even out. The WORST mistake I made while dyeing was trying and touching up half dried dye, it scuffed up and make a mark when dry. If you mess up, DONT touch it. Let it dry and wetsand out w/ 1500 grit, then apply another coat. It will even out
  • When dyeing, you will notice that the dye separates really quickly. No lie, you will get some dye on your brush and paint a bit, then go back to get more dye on the brush and the dye will have already separated. You need to keep stirring the dye before you go and paint with it.
  • Take the seats apart. I don't know how Alec did the dye job with his seat together. I did my drivers seat like that and I realized that the seams where the seat cushion met the back were going to be messed up. So I took them apart and they were horrible, the dye had made the leather stick to itself and I had to rip it apart, breaking the dye. I had to go back and wetsand and redo the portion of the drivers seat that was messed up. I did my passengers seat the proper way, taking it apart and dyeing the panels separately.
Painting tips:
  • Duplicolor vinyl and fabric paint is a great product, no lie. But the spray can is a pos. It doesn't really have a good nozzle so if you are spraying downward, the spray paint coming out will splatter and make your piece look horrible. This is when I realized that if I wanted good work, I was going to have to use my hands. I just held my piece up and spun it around whichever way I needed to spray and painted while it was in my hand. I got spray paint on my hand and arm, no biggie though. Just a tip
  • Make sure you are painting in the right conditions, this is very important. It was damn cold outside so I set up a spray booth inside my house to paint, it worked out very well.
Procedures
Door panels:
  1. Take apart door panels, don't be a bum and keep them together and mask off portions with newspaper. If you take them apart, you will get a better result in the end, I promise.
  2. Leatherique leather inserts, let rejuvenator soak in for 24 hours. When applying the rejuvenator, use about 2-4 ounces per panel and massage it into the panel with your hands. Like really, think of it as you giving a piece of leather a massage, it's weird. Then do all the necessary pristine clean and dyeing procedures
  3. Clean vinyl door panels - scrub with green works and sponge, then scrub with warm water and wipe dry. Let them sit for a while because the vinyl will still be damp feeling after you wipe it. Then spray with duplicolor vinyl and fabric paint. Remember! light coats
  4. Take apart arm rests - leatherique leather pads, prep and sand bottom portion for duplicolor vinyl and fabric paint.
  5. Put door panels back together using screws and washers
Seats:
  1. Scrub clean with wet rag
  2. Apply leatherique rejuvenator and scrub into the leather, let sit for 24 hours minimum, I let all of my pieces soak for 48 hours.
  3. Spray pristine clean onto leather using spray bottle and let sit for 20 mins, scrub with toothbrush and wipe off with terry towel. Wait 2 hours.
  4. Put leatherique prepping agent into glass bowl and get 1000 grit sandpaper, dip sandpaper into bowl and start to wetsand leather seats. Wait 6 hours minimum
  5. Ready for dye. For my black leatherette seats, I found that 5 coats was necessary to make it look absolutely perfect. 4 coats and you could still see some black through the dye. For the tan leather, 4 coats was plenty.
  6. [insert dyeing procedure here]
Headliner, rear deck and pillars:
  1. Clean with wet rag
  2. Soak them with rit dye, no lie, soak them. Don't hesitate to use as much dye as the panel will take without dripping
Door seals:
  2. Apply rit dye using bowl and sponge brush, same as headliner pieces
Plastic pieces:
  1. Spray down with green works and scrub as much dirt off as possible.
  2. Wipe pieces with a wet rag and sand with 600 grit sandpaper.
  3. Place in hot water bath to get rid of all the powder, let sit until completely dry
  4. Lots and lots of light coats of spray paint, waiting about 10 minutes between coats.
neil1138 is offline   Reply With Quote
Old 01-08-2010, 11:33 PM   #390
Blocked Out
My Ride: Imola 330i M-Sport
Exceptional work!
Original BMW Teile ///
Original BMW Parts for Sale - DISA, MAF, SAP, Coils, MS43 much more PM ME
IMG_1725
Old 01-08-2010, 11:43 PM   #391
Titan 3
Titan 3's Avatar
My Ride: E46 325ci, F36 428ix
Great work, Neil!! More pics of the car back together, when you get a chance!
Titan 3 is offline   Reply With Quote
Old 01-09-2010, 01:05 AM   #392
m1356guy
My Ride: is worth $5k
nice man....that one shot is soooo nice
m1356guy is offline   Reply With Quote
Old 01-09-2010, 01:15 AM   #393
srbija 328i
My Ride: has 262k miles
amazing work
M@R!O
srbija 328i is offline   Reply With Quote
Old 01-09-2010, 01:33 AM   #394
relentlessone
My Ride: '03 BMW 530i
Send a message via AIM to relentlessone
That looks f*cking awesome.
relentlessone is offline   Reply With Quote
Old 01-09-2010, 02:50 AM   #395
So Lowww
My Ride: E36M
Boner achieved
Best color combo!!
S T A N C E | W O R K S
So Lowww is offline   Reply With Quote
Old 01-09-2010, 03:19 AM   #396
DILLA
My Ride: 330i ZHP/VW Jetta
awesome work! looks fantastic. I can't wait to see the final/more pix
LRx
DILLA is offline   Reply With Quote
Old 01-09-2010, 04:14 AM   #397
T330
My Ride: X5
Send a message via AIM to T330
Great job
T330 is offline   Reply With Quote
Old 01-09-2010, 04:51 AM   #398
SHOF
My Ride: 911TT, E46 M3
Pure Sex
SHOF is offline   Reply With Quote
Old 01-09-2010, 05:20 AM   #399
Skazzy
My Ride: X Wing
wow! your interior looks like a million bucks. Are you also going to do the steering wheel (individial style?)
btw, you're in the lead for 2010's greatest thread! Exciting project, well put together and incredibly informative
Skazzy is offline   Reply With Quote
Old 01-09-2010, 05:33 AM   #400
MARiSA
My Ride: e90 328i
wow. absolutely amazing work.
MARiSA is offline   Reply With Quote
cinnamon, cinnamon interior, drama, dyeing, epic, is taking too long, leatherique, neil drinks yoohoo, pure sex, sexy seats, will never be like oem
