The Showroom
Thread Tools Search this Thread Rating: Thread Rating: 129 votes, 4.79 average. Display Modes
Old 11-30-2012, 07:39 PM   #601
willsbma
My Ride: 99 323i
After my exterior is pretty I'll be doing something similar. This is insane and it looks like it was worth all of the effort. I just need to think of a color that I want to use for the two tone. Decisions decisions... Awesome thread man!
Matte Black Kidney Grilles | Smoked Tails & Corners | Mtech II Bumper | Hotchkis Springs | ACS Roof Spoiler | M3 Spoiler | 20% Tint
WTB: Black sun visors & grab handles - PM ME!
I have P.A. Soft and a 20-pin adapter. Only used it a few times but pm me if you need anything coded!
willsbma is offline   Reply With Quote
Old 04-06-2013, 04:15 PM   #602
Rezist09
My Ride: 325i sedan
what kind of spray did u use for the headliners
where did u get the dye/brushes/spray cans for?
Dyeing tips:
Don't buy foam brushes, buy artist acrylic brushes: 3/4" - 1"
When dyeing, do NOT stop in the middle of a panel, make it to the closest seam and stop. If you get bubbles or heavy spots of dye, blow on them to even them out.
You might think that you will get brush marks, swirls, etc when the dye dries, but just be patient, they will even out. The WORST mistake I made while dyeing was trying and touching up half dried dye, it scuffed up and make a mark when dry. If you mess up, DONT touch it. Let it dry and wetsand out w/ 1500 grit, then apply another coat. It will even out
When dyeing, you will notice that the dye separates really quickly. No lie, you will get some dye on your brush and paint a bit, then go back to get more dye on the brush and the dye will have already separated. You need to keep stirring the dye before you go and paint with it.
Take the seats apart. I don't know how Alec did the dye job with his seat together. I did my drivers seat like that and I realized that the seams where the seat cushion met the back were going to be messed up. So I took them apart and they were horrible, the dye had made the leather stick to itself and I had to rip it apart, breaking the dye. I had to go back and wetsand and redo the portion of the drivers seat that was messed up. I did my passengers seat the proper way, taking it apart and dyeing the panels separately.
Painting tips:
Duplicolor vinyl and fabric paint is a great product, no lie. But the spray can is a pos. It doesn't really have a good nozzle so if you are spraying downward, the spray paint coming out will splatter and make your piece look horrible. This is when I realized that if I wanted good work, I was going to have to use my hands. I just held my piece up and spun it around whichever way I needed to spray and painted while it was in my hand. I got spray paint on my hand and arm, no biggie though. Just a tip
Make sure you are painting in the right conditions, this is very important. It was damn cold outside so I set up a spray booth inside my house to paint, it worked out very well.
Procedures
Door panels:
Take apart door panels, don't be a bum and keep them together and mask off portions with newspaper. If you take them apart, you will get a better result in the end, I promise.
Leatherique leather inserts, let rejuvenator soak in for 24 hours. When applying the rejuvenator, use about 2-4 ounces per panel and massage it into the panel with your hands. Like really, think of it as you giving a piece of leather a massage, it's weird. Then do all the necessary pristine clean and dyeing procedures
Clean vinyl door panels - scrub with green works and sponge, then scrub with warm water and wipe dry. Let them sit for a while because the vinyl will still be damp feeling after you wipe it. Then spray with duplicolor vinyl and fabric paint. Remember! light coats
Take apart arm rests - leatherique leather pads, prep and sand bottom portion for duplicolor vinyl and fabric paint.
Put door panels back together using screws and washers
Seats:
Scrub clean with wet rag
Apply leatherique rejuvenator and scrub into the leather, let sit for 24 hours minimum, I let all of my pieces soak for 48 hours.
Spray pristine clean onto leather using spray bottle and let sit for 20 mins, scrub with toothbrush and wipe off with terry towel. Wait 2 hours.
Put leatherique prepping agent into glass bowl and get 1000 grit sandpaper, dip sandpaper into bowl and start to wetsand leather seats. Wait 6 hours minimum
Ready for dye. For my black leatherette seats, I found that 5 coats was necessary to make it look absolutely perfect. 4 coats and you could still see some black through the dye. For the tan leather, 4 coats was plenty.
[insert dyeing procedure here]
Headliner, rear deck and pillars:
Clean with wet rag
Soak them with rit dye, no lie, soak them. Don't hesitate to use as much dye as the panel will take without dripping
Door seals:
Clean with wet rag
Apply rit dye using bowl and sponge brush, same as headliner pieces
Plastic pieces:
Spray down with green works and scrub as much dirt off as possible.
Wipe pieces with a wet rag and sand with 600 grit sandpaper.
Place in hot water bath to get rid of all the powder, let sit until completely dry
Lots and lots of light coats of spray paint, waiting about 10 minutes between coats.
Rezist09 is offline   Reply With Quote
Old 04-06-2013, 08:23 PM   #603
Skazzy
My Ride: X Wing
just saw the thread tags
Skazzy is offline   Reply With Quote
Old 07-09-2013, 12:22 PM   #604
_k
My Ride: e46 coupe
amazing work!!!! went through the whole thread. great job. love cinnamon interiors!
_k is offline   Reply With Quote
Old 07-23-2013, 12:17 AM   #605
Gheybe
Gheybe's Avatar
My Ride: F80 M3
bump
op is a known india god
Gheybe is offline   Reply With Quote
Old 07-23-2013, 04:29 PM   #606
Anderspr0
My Ride: E46 320ia
Love it, perfect
Anderspr0 is offline   Reply With Quote
Old 08-05-2013, 07:17 PM   #607
JJR4884
My Ride: BMW
hopefully in a months time i'll create a thread half as epic as this one... good thread, good info
i didn't get a change to read through the entire thing, but Neil, do you have the screw lengths that you used when putting the leather inserts back in the panel? I just removed the leather from the panels, and i'm waiting for my leather dye to be delivered... i had everything, but my dye was the wrong color so I sent it back almost 2 weeks ago to get the correct color
JJR4884 is offline   Reply With Quote
Old 08-06-2013, 02:17 PM   #608
AndrewCross
My Ride: 2000 323Ci
Neil1138's Interior Project, tis gonna be fun
Still one of the most inspirational and motivating threads on this site
AndrewCross is offline   Reply With Quote
Old 10-06-2013, 10:57 AM   #609
David McMahon
My Ride: '99 E38 740iL
I woke up today thinking "Give my mats a quick dye, to hide the driver's feet damage"
Well I've ended up removing the rear carpets, most of the dash parts and now I need to commit to removing it all! Seems I might need to cut to avoid the heater box? I'm trying not to cut anything. I'm already glad I did remove rear carpet so I can tidy up a drain hole "on the turn"
http://imgur.com/a/S56ew?gallery
David McMahon is offline   Reply With Quote
Old 04-30-2014, 11:43 PM   #610
Northwest
My Ride: 2001 330i
This thread right here... this is the reason I joined e46fanatics
Northwest is offline   Reply With Quote
Old 04-30-2014, 11:52 PM   #611
DropTopKingM3
My Ride: All German
You picked a damn good reason to join. Welcome aboard
..George..
..Is now Alpine White/Cinnamon...
^Don't say my car is topless, say the t!tties is out^
DropTopKingM3 is offline   Reply With Quote
Old 06-06-2014, 05:13 PM   #612
DEADF15H
My Ride: 2001 325i Auto
Wow! What an awesome job. It took a lot of time to take the pics and write it up, thanks for the DIY.
DEADF15H is offline   Reply With Quote
Old 06-06-2014, 05:27 PM   #613
Cowspoo
My Ride: 328Ci
Lol, this time stamp seems legit.
spacebarissolazy
doesntfeelikebeingpressed
Cowspoo is offline   Reply With Quote
Old 06-06-2014, 06:52 PM   #614
DEADF15H
After your post Cowspoo , I had to check the date on my computer, but all is right here
Old 11-19-2014, 08:00 PM   #615
golf_234
My Ride: E46, E90
These were the days. Is Neil still around here?
golf_234 is offline   Reply With Quote
Old 03-16-2015, 10:14 PM   #616
Carfanatic_Henry
My Ride: 2002 330CI Coupe
soooooo i just went through the whole thread and i am in love! cant believe it held up for so long and hope it is still holding up an looking amazing! now i want to do this. but first i want to do your headlight setup!
Carfanatic_Henry is offline   Reply With Quote
Old 03-16-2015, 10:18 PM   #617
JustinE36M3
My Ride: M3
After reading this thread it inspired me. Hated my all grey interior, so gave it a 2tone look. Still have to find a black center console and floor mats
ID:	593238Click image for larger version
And what it looked like for comparison
JustinE36M3 is offline   Reply With Quote
Old 09-20-2015, 09:18 PM   #618
Syfon
My Ride: 2004 6MT M3
Just read this entire thread. This has motivated me to dye my interior Cinnamon aswell!
I have Kiwi nappa leather with black inserts and black dash; it's not too bad but Cinnamon would look amazing throughout my M3!
Can you still order all the required dyes, prep items, etc from Leatherique?
Syfon is offline   Reply With Quote
Old 07-13-2016, 02:41 PM   #619
YoitsTmac
My Ride: 328Ci
Neil. I'm going to go broke following all your DIY's. This is beautiful, along with your photography. Why'd you sell your E46, especially the clear amount of love you had for the car? Would also like to know if the dye's are still available, and if you think they will be for a while. I'm thinking of two-toning my grey interior for now, and then go cinnamon when I'm ready.
YoitsTmac is offline   Reply With Quote
Old 07-13-2016, 02:42 PM   #620
///BM3R
My Ride: 330ci...///M3 soon
this just motivated me to get rid of the tan and in with the cinnamon ))))
///BM3R
///BM3R is offline   Reply With Quote
cinnamon, cinnamon interior, drama, dyeing, epic, is taking too long, leatherique, neil drinks yoohoo, pure sex, sexy seats, will never be like oem
