Old 08-24-2013, 11:16 PM   #21
jack.chris328
My Ride: is a truck.
There are a couple ways to do it. One is to remove the whole bi-xenon bracket by prying up on the self-leveling motor arm with a screwdriver. Then taking it out to get at the clips that hold the piece on. I use a set of 90 degree needle nose pliers going in through the high beam hole in the back(removing the rubber surround). The collapsing the clips and pushing them out. You will have to adjust the headlight bowls down(for the vertical) and toward the outside of the light(for the horizontal) to get a good angle at the clips.
jack.chris328 is offline   Reply With Quote
