Old 12-10-2012, 10:21 AM   #1
Mike444
My Ride: 2012 VW GTI 4dr DSG
04 325i died on the highway
Driving along at 70mph and it started missing and as I pulled off to the exit it died. It will crank and briefly start but dies again. Even if I give it gas the revs will not go above 1k.
I had it towed to the dealer that has done good work or me before but I don't want to be blind on this.
I tried a quick search but i'm at work so don't flame me, too much anyway.
Mike444 is offline   Reply With Quote
Old 12-10-2012, 10:26 AM   #2
HacksawMark
HacksawMark's Avatar
My Ride: 2014 Subaru XV
Almost sounds like it ran out of gas....
HacksawMark is offline   Reply With Quote
Old 12-10-2012, 10:31 AM   #3
choxor
My Ride: JDM
May be the fuel pump. Search for user jfoj and check his signature.
Old 12-10-2012, 10:31 AM   #4
Mctwist77
My Ride: '99' BMW 323i
Sounds like its in limp mode..going to have to pull codes
Photobucket
BMW 323I 5 Speed
Mctwist77 is offline   Reply With Quote
Old 12-10-2012, 10:44 AM   #5
Mike444
Funny you mention gas as the light was on but it said I still had 45 miles to go.
Old 12-10-2012, 10:44 AM   #6
WDE46
My Ride: '13 128i, '04 330Ci
why does that sound like limp mode? limp mode allows the engine to run...
OP, I've heard that a weak fuel pump will conk out with around 1/4 tank of gas left. Is that what you're at? Most sudden deaths seems to just be the pump. Luckily it's not that expensive and takes a half hour to DIY. Do you hear it prime the engine when you put the key in position 2 (don't crank it). It should "hiss" below you. That's the fuel going through the fuel filter.
Old 12-10-2012, 10:48 AM   #7
GSherbs
My Ride: 2002 330 xi
Have you put more gas in yet?
GSherbs is offline   Reply With Quote
Old 12-10-2012, 10:50 AM   #8
scarede46er
My Ride: 2001 BMW 325i ZSP
You need to change your fuel pump. nuff said.
Old 12-10-2012, 11:17 AM   #9
Cees
My Ride: 330i
^ This x2, but more like 1/6. Gas is required for proper fuel pump lubrication. Personally never leave mine below 1/4
Cees is offline   Reply With Quote
Old 12-10-2012, 11:18 AM   #10
Mike444
As I wrote I had it towed to the stealership. If I were home I would play with it as i always work on my cars but this caught me out of the blue. I had my daughter in the car and just need to get somewhere safe.
Old 12-10-2012, 11:23 AM   #11
rjskalet
My Ride: TiAg M3
More than likely it was out of gas. Honestly I had the same problem in my old 325i it said I had 42 miles left started going up a hill and it died. Filled it up with gas and haven't had a problem since.
rjskalet is offline   Reply With Quote
Old 12-10-2012, 11:27 AM   #12
scarede46er
Really? You were with your daughter. In Baltimore. And you do not have the sense to keep your fuel at a safe level? Parenting fail. I hope the dealer robs you blind as a lesson.
Old 12-10-2012, 11:32 AM   #13
Mike444
Light comes on at 50 miles which means you can drive what at least 60 miles. I was driving 12 miles to her school and was going to get gas on the way.
You can criticize me as a car owner but not as a parent. Do not cross that line.
Old 12-10-2012, 11:34 AM   #14
rjskalet
My Ride: TiAg M3
I agree how is parenting related to gas levels? Lol
Old 12-10-2012, 11:36 AM   #15
scarede46er
Mike: its common sense. You just do not do that in that hell hole of a criminal town like Baltimore. Especially when you're with your loved ones. I hope you carry a concealed weapon.
Old 12-10-2012, 11:44 AM   #16
EverydayGetaway
My Ride: 2003 330i ZHP
You could have avoided this, by avoiding this. Your range estimate is just that, an estimate. Always avoid letting the fuel light come on in any car, just fill up when you get to a quarter tank. Lucky for you fuel pumps on BMW's are very easy to replace, if yours is in fact dead.
(Please pardon my auto-correct)
EverydayGetaway is offline   Reply With Quote
Old 12-10-2012, 11:45 AM   #17
Mike444
Dude what is you problem? Do you know Baltimore? Beside that who are you to judge?
I was in Timonium, hardly a hot bed of criminal activity. I was not driving through the hood looking for a dime bag.
Old 12-10-2012, 11:47 AM   #18
scarede46er
Yes I know Baltimore. I presumed you were in the city from your profile.
Old 12-10-2012, 12:03 PM   #19
WDE46
Really? You're questioning his parenting? You must be the kind of person who complains to the HOA about their neighbor's car being parked outside. Shut up right now about his parenting.
Everybody telling the OP he is dumb for letting his fuel light come on also need to shut up. It does not hurt the car at all to have a low tank. As long as the fuel pump doesn't go dry, you can go low. Use some reasoning for god's sake. Stop being so freaking condescending. The only other person in theis thread who even knows what they are talking about is choxor anyway. All you other people can continue to argue whether or not low fuel hurts the car (hint, it does not).
The estimate will not be off by 50 miles. The fuel level senders are quite accurate in our car. If the car went empty, then it would have said 0 when it ran out. The car knows it has fuel left. It is definitely the pump.
tl;dr: stop judging people. OP change fuel pump.
Old 12-10-2012, 12:03 PM   #20
FenderGuy05
My Ride: 2002 BMW 325i
+1 on this. If the dealer confirms this, I would have it towed to your house...you can get a pump online for around 120 or so, but dealer charges 300-400 dollars just for the part
FenderGuy05 is offline   Reply With Quote
