Old 01-26-2010, 04:36 PM   #81
aggieE46
Keep it clean
aggieE46's Avatar
My Ride: 03 Evo, 07 Passat
He should have resent today
Originally Posted by derek0606 View Post
You've got mail....
Waiting on pmt from:
derek0606
bigjae1976
Dj_Frost
AdamBath
Old 01-26-2010, 05:25 PM   #82
bigjae1976
bigjae1976's Avatar
My Ride: 2011 E90 M3
My paypal went screwy for a couple of days. Can he resend the payment request?
2013 F30 328i - Melbourne Red
2004 E46 M3 - Imola red
Old 01-26-2010, 11:37 PM   #83
HighBoostin330
My Ride: 2002 Stock 330Ci
When are these being shipped out?
HighBoostin330 is offline   Reply With Quote
Old 01-27-2010, 12:17 AM   #84
330i ZHP
330i ZHP's Avatar
My Ride: have 5 doors and FI
if only someone would make a better looking intake hose for the ts
/_________\
O==[][]==O
Old 01-27-2010, 12:22 AM   #85
HighBoostin330
What's wrong with the TS intake hose?
Old 01-27-2010, 12:25 AM   #86
330i ZHP
330i ZHP's Avatar
it is not the most attractive thing
hows the car holding up? anything new
/_________\
O==[][]==O
Old 01-27-2010, 12:27 AM   #87
HighBoostin330
It is definitely one of the best put together kits for the E46 non-M in terms of stealth install.
Car is holding up great. Need to put in an oil cooler if I want to continue tracking the car.
Just doing maintenance on it right now. How's your car doing now that you have a tune for the MS45?
Old 01-27-2010, 12:30 AM   #88
330i ZHP
330i ZHP's Avatar
it is running well. i am sure there is still power to be had from a better tune. I have been too busy and need to get Aj to come out here to tune the thing.
I had my first belt failure and of course it took the tensioner, a few pulleys and the oil filter housing with it in a matter of seconds
/_________\
O==[][]==O
Old 01-27-2010, 12:34 AM   #89
HighBoostin330
Just be happy you have 93 octane over there!
I had my belt failure on the track, but lucky it didn't take anything with it. Sorry to hear about that. Are you using the mechanical or hydraulic tensioner?
Old 01-27-2010, 12:39 AM   #90
330i ZHP
330i ZHP's Avatar
hydralic on both - i now have two oil filter housings with broken tabs (hopefully they can be welded) and a new one as a spare sitting in a box on a shelf...that and a spare tensioner, spare pulleys and spare hoses and belts. I have also found for the ts2 a slightly longer (5mm) belt doesnt squeak
/_________\
O==[][]==O
Old 01-27-2010, 12:42 AM   #91
HighBoostin330
You're starting to build quite a collection of spare parts. I hope I don't start breaking oil filter housing, pulleys, and tensioners. You just reminded me, I should change out my belt - cheap insurance.
Old 01-27-2010, 12:50 AM   #92
330i ZHP
330i ZHP's Avatar
the thing is, i dont know if the tensioner broke or the belt jumped...i started the car and the car was dealing with the cold start idle jump and then stalled. I restarted it and knew instantly something was wrong and shut it off (all this was in my driveway and the whole event was over in less then a few seconds from getting in the car to shut down) as soon as i saw the alt light i knew what happened and i popped the hood...as soon as i saw the belt i figured the tensioner was toast...ordered one from tischer and had it delivered...didnt move or work on the car until sunday and sure enough all that stuff was trashed
i would rather stock the parts I think or know will fail than be stuck without a car. i just wish the cars would stop destroying the expensive oil filter housings. one each to date (although I am certain the tensioner was broken the first time and on the sedan)
/_________\
O==[][]==O
Old 01-27-2010, 12:53 AM   #93
HighBoostin330
How does the oil filter housing get chewed up by the broken belt? Is it the velocity at which it hits the oil filter housing breaks it apart? How much are the oil filter housings?
Old 01-27-2010, 12:57 AM   #94
330i ZHP
330i ZHP's Avatar
it is the tensioner (i assume when it snaps back) it breaks a tab on the upper mount (there are three bolts holding the tensioner to the oil filter housing assembly)
new housings are about $300 and the other pulleys, belts and tensioner run about another $200...
/_________\
O==[][]==O
Old 01-27-2010, 12:59 AM   #95
HighBoostin330
Geebus! That is like a front control arm and bushing change for me.
Old 01-27-2010, 01:04 AM   #96
330i ZHP
330i ZHP's Avatar
not to mention it is a pita job to swap the parts. the ts doesnt really make it too much harder but it doesnt make it any easier either. the ts snout is somewhat in the way so three of the bolts securing the housing and the vanos high pressure line banjo fitting end up being removed and installed with your arm contorted and no real way to see what you are doing
/_________\
O==[][]==O
Old 01-27-2010, 01:05 AM   #97
HighBoostin330
You're making this sounds horrendous to change all this stuff out.
This sounds like a lot of "feeling" install than "seeing" install.
Old 01-27-2010, 04:02 AM   #98
WBVenom
My Ride: Car 54
Hey, guys. This is a thread for the Stett radiator hose group buy. I'm in it, and it's all I want to read about.
WBVenom is offline   Reply With Quote
Old 01-27-2010, 04:24 AM   #99
Str86ix
My Ride: 01 325ci 9psi
Im down for a group buy.
Str86ix is offline   Reply With Quote
Old 01-27-2010, 08:22 AM   #100
330i ZHP
330i ZHP's Avatar
the op likely wont care if two OG TS guys discuss things - if you dont like it, dont read it
/_________\
O==[][]==O
