Old 12-16-2009, 01:54 PM   #1
bluejeansonfire
ninja editor
My Ride: m5xual
Send a message via AIM to bluejeansonfire
Walbro(ish) fuel pump install in e46nonM
So I knew I'd need this... a few days after my car started running, over nothing, it started to lean out. My stock pump had nearly 120k miles on it and I'm one to run the tank dry, completely dry, I've pushed my car to pumps many times over.
So, yesterday I received in the mail the TRE 340 walbro knock-off pump. Why a knock off? Walbro is so cheap. Walbro has no warranty, TRE gives me a year's warranty... and it's a bit cheaper, and TRE sells it with a "BMW" install kit for $69.99.
Now, I think this install kit is meant for e36s, but we're nearly e36s, so I figured I'd give it a whack.
Above is a picture of the assembly almost complete. When removing the stock pump from its carrier, seen above attached to the larger carrier, i dropped the pump carrier with the pump and it shattered. Lucky for me, not 20ft away was a used e46 m pump assembly with a slightly broken larger carrier and a bad pump. So I used its carrier. Keep in mind, the carrier of the nonM pump is meant for the nonM's fatter pump, while the M pump is skinnier, I think more what this kit was intended for. With some ingenuity, this can be fitted to the nonM, just needs more material to hold the pump in the carrier.
01 330cit-92 s13c-99 328i/5-04 x5/6
bluejeansonfire is offline   Reply With Quote
Old 12-16-2009, 02:09 PM   #2
Snik
Snik's Avatar
My Ride: IR M3 Vert.
ok im totally lost, how did you do this, do you just pop out the stock unit and pop this one in?
is it the black cylindrical thing and tub, how different are the power connections, or does the kit handle that?
whats that bag looking thing?
sorry i dont knwo jack about pumps but my OEM pump has over 180k miles on it, so this has my interest.
Do you ride a sportbike?
Old 12-16-2009, 10:36 PM   #3
BadBoostedBmwM3
My Ride: 323i & e36 Turbo M3
Im glad you are back boosting at 13psi...
This is my signature....
BadBoostedBmwM3 is offline   Reply With Quote
Old 12-16-2009, 10:52 PM   #4
bigjae1976
bigjae1976's Avatar
My Ride: 2011 E90 M3
I thought the OEM M3 pump could simply be dropped into a non-M. So if you used the M3 carrier, why would you need to do some further mods to make it fit?
2013 F30 328i - Melbourne Red
2004 E46 M3 - Imola red
Old 12-17-2009, 12:16 AM   #5
bluejeansonfire
ninja editor
My Ride: m5xual
I'm using a walbro equivalent 255lph. I don't think the e46M pump will flow that much. The e46M pump might be sufficient, it might not, but this is proven to hold up 550-600whp. The pump didn't have the strapping bevel on the outside of the body like the oe pump, nor is it as tall, so I used the included neopreme jacket folded over once to secure the pump in the clips of the carrier.
Old 12-17-2009, 01:11 AM   #6
Snik
Snik's Avatar
What about my n00b question?
Old 12-17-2009, 01:13 AM   #7
paraklas
My Ride: ESS TS2 320ci
Is the heatshrink fuel-resistant?
Old 12-17-2009, 01:17 AM   #8
Snik
Snik's Avatar
Old 12-17-2009, 02:14 AM   #9
BMW_Matt
My Ride: 135
Sweet, Julio.
BMW_Matt is offline   Reply With Quote
Old 12-17-2009, 02:22 AM   #10
RACEMX-M3
My Ride: M3
Is that a mini or a maxi pad on the bottom of the pump?
RACEMX-M3 is offline   Reply With Quote
Old 12-17-2009, 07:59 AM   #11
bluejeansonfire
ninja editor
My Ride: m5xual
two-wire solder. black thing in middle is new pump. bag is filter pickup
Old 12-17-2009, 08:00 AM   #12
bluejeansonfire
ninja editor
My Ride: m5xual
it was a concern initially, but without internal glue, yes
Old 12-17-2009, 08:03 AM   #13
Snik
Snik's Avatar
yaayy, thanks.
so any suggestion for which pump to get for a none boosted 328?
Old 12-17-2009, 08:04 AM   #14
bluejeansonfire
ninja editor
My Ride: m5xual
yaayy, thanks.
stock
Old 12-17-2009, 08:05 AM   #15
Snik
Snik's Avatar
stock
stock aint cheap
Old 12-17-2009, 08:09 AM   #16
bluejeansonfire
ninja editor
My Ride: m5xual
stock aint cheap
you can do the same thing i did too
Old 12-17-2009, 08:10 AM   #17
Snik
Snik's Avatar
so running a higher rating pump than needed wont hurt anything, or even damage said pump?
Old 12-17-2009, 05:58 PM   #18
bluejeansonfire
ninja editor
My Ride: m5xual
not unless you overwhelm your fpr
Old 12-17-2009, 06:59 PM   #19
Snik
Snik's Avatar
eeeehh... on the sellers ebay site they recomend the 361, so im slowly researching that.
Old 12-17-2009, 07:01 PM   #20
performancenut
My Ride: AA s/c 3 series
Any idle or driveability issues with the increased flow rate? Need for a retune based on extra fuel capability?
"Sell the 323 and buy an M, it's not worth it"
performancenut is offline   Reply With Quote
