Walbro(ish) fuel pump install in e46nonM - Page 2 - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 12-17-2009, 06:03 PM   #21
howie
My Ride: CLK55 AMG, E90 335i
Send a message via AIM to howie Send a message via Yahoo to howie
walbro > *
/thread
howie is offline   Reply With Quote
Old 01-09-2010, 06:10 PM   #22
bigjae1976
bigjae1976's Avatar
My Ride: 2011 E90 M3
How did this turn out?
2013 F30 328i - Melbourne Red
2004 E46 M3 - Imola red
Old 01-09-2010, 07:51 PM   #23
WALKD U
My Ride: Just Fast!
Walbro FTW! I used the 255lp on my 5.3L V8 Swap in the Jeep.. Works Great! Rated up to 500 or so HP...
-TrippinBimmer
2005 AW/IR M3
MaximumPSI Stage4
993whp/651wtq SAE Corrected
2005 JB/BLK 330i ZHP
NA Bolt-ons
207whp/216wtq SAE Corrected
1996 BLU/BLK M3
NA Bolt-ons
235whp/225wtq SAE Corrected
1988 SETA 325I
NA Bolt-ons
165whp/160wtq SAE Corrected
Old 01-09-2010, 09:40 PM   #24
bigjae1976
bigjae1976's Avatar
I've been doing some research and found this...
http://www.fuel-pumps.net/walbro-forgeries.html
Old 01-09-2010, 09:43 PM   #25
FTWeisse
My Ride: has no hip-hop rimz
Originally Posted by howie View Post
walbro > *
/thread
I think you meant Bosch, not Walbro.
Old 01-09-2010, 09:56 PM   #26
bigjae1976
bigjae1976's Avatar
So if I buy the 255lph walbro, do I need some sort of other fitting to hook it up?
I've read that a Bosch 040 is comparable to and lasts longer than the 255lph walbro. Is the Bosch unit also quieter?
Old 01-09-2010, 11:10 PM   #27
bluejeansonfire
ninja editor
My Ride: m5xual
Send a message via AIM to bluejeansonfire
i'm on tre pump #2
Pump #1 left me stranded in front of a 3-mile long bridge in pensacola in the dark on Christmas
My next move is 040... skip all the walbro stuff and its third world siblings.
01 330cit-92 s13c-99 328i/5-04 x5/6
bluejeansonfire is offline   Reply With Quote
Old 01-10-2010, 12:15 AM   #28
bigjae1976
bigjae1976's Avatar
Cool, good info. Bosch it is! A 040 is a drop in for non-M's or is there some "custom" work involved?
Is $180 a good price?
http://www.expressfuelpumps.com/bosc...nk-p-3804.html
Old 01-10-2010, 11:21 AM   #29
TxZHP04
My Ride: ESS TS2+ ZHP
How much boost are you running that you're having fuel issues? What issues are you having? Why not just run the M3 pump?
I upgraded to the M3 pump a while back in an attempt to resolve my ~ 1/4 tank fuel starvation under hard acceleration problems and haven't had any problems since (my theory is that the non-M pump provided enough fuel for the motor under boost but not enough excess fuel for adequate return flow from the FPR to siphon fuel from the L side to the R side of the tank, thus the pump pickup would go dry).
Old 01-10-2010, 04:36 PM   #30
bigjae1976
bigjae1976's Avatar
9psi. Fuel isn't the issue, more like the fuel pump is getting old. Just over 90k and I am just researching my options. M3 pump ($317) vrs Bosch 040 ($180 and a little elbow grease).
Old 01-10-2010, 05:04 PM   #31
PEI330Ci
58mm of Bliss
PEI330Ci's Avatar
My Ride: 330i, 330Ci
That's a pretty good theory...I hadn't thought of it that way before.
Old 10-11-2010, 04:19 PM   #32
bigjae1976
bigjae1976's Avatar
Julio...do you still have the Tre pump? If so, how's it holding up?
Old 10-11-2010, 07:29 PM   #33
bluejeansonfire
ninja editor
My Ride: m5xual
my car hasn't run since march... the hardware is together, but since my wiring looks like it was done by wild animals, I'm having someone else do it. At this point I'm waiting on wiring for the car to fire. Due to my fear of the TRE pump failing, I replaced it for a walbro, I have a Bosch inline as well going through a slightly larger line. The TRE filter design actually looked a good bit better than the walbro, but oh well, I'll just keep the fuel level higher at all times. Fuel pressure will be observed in-car.
Old 10-11-2010, 10:12 PM   #34
bigjae1976
bigjae1976's Avatar
Thanks. So basically I should buy 2 Tre pumps in case 1 goes bad.
...I think the correct term is "bowl of spaghetti".
Old 10-11-2010, 10:30 PM   #35
bluejeansonfire
ninja editor
My Ride: m5xual
sort of... yes... if the first one goes out and you return it, you can get another free, or a refund for the second one you purchased.
Real Walbros aren't the most reliable pumps in the universe, but they're not that bad... so its knock-off, which is not that dissimilar in price, is either a) really similar or b)simply worse, unlikely to be c)better... that was my rationalization... leaning on a/c... then to conclude on b
