Old 12-16-2009, 07:45 PM   #1
Sacrifice
My Ride: 2003 BMW 316i SE
Umnitza angel eyes wiring...
Hi there
i have angel eyes already installed that replace the DRLs and i'm really happy with the way it works... however, now i want them to turn on when i lock the car and fade out exactly the same as the way the interior lights fade...
i found the kit to do this, and the instructions:
http://www.fastm.com/m3/angeleyes_chromium.html
however, this involves:
1. replacing the current angel eyes
2. leaving the DRLs disconnected so the annoying warning light stays on as i don't want to reconnect them (ruins the effectiveness of the AE i think...)
so i was wondering if i could just buy the wiring harness:
http://www.fastm.com/m3/angeleyes/angeleyes04.jpg
and connect it up to the current transformers?? im not sure if it will work as the voltages might be different or something....
and i was also wondering if there's a way to 'trick' the car into thinking the DRLs r connected and working, even though they aren't?? i just like having my instrument cluster with no warning lights
Sacrifice is offline   Reply With Quote
Old 12-16-2009, 08:39 PM   #2
redrum0486
My Ride: 2011 328i xDrive
I thought you just had to connect the secondary trigger wire to the interior light circuit (?)
| 2011 328i xDrive | Titanium Silver [B]|
Past: | 2004 330xi | Titanium Silver
redrum0486 is offline   Reply With Quote
Old 12-16-2009, 08:45 PM   #3
I_kgb_I
My Ride: 2005 325i
^ +1...
that's what i did
brown trigger wire (on the pic that you provided) connects to your interior lighting and that does the trick.
Here is how you do it
As for the second question... i had mine turned off by a mechanic... Not sure if it is legal in UK but if it is - you can get your dealer to turn it off too...
http://www.projecttechnik.com
I_kgb_I is offline   Reply With Quote
Old 12-18-2009, 08:08 PM   #4
Sacrifice
hmmm okay....
but i was just thinking, i think not having DRLs is actually illegal, so is there a way for me to wire it in so instead of having it linked to the accessories wire (as the primary trigger), link it up to the DRLs so the AEs become my DRLs (that's legal here)??
Old 12-19-2009, 02:53 PM   #5
I_kgb_I
My Ride: 2005 325i
Not having DRLs is also illegal in Canada. According to a cop that i talked to - cops don't know what kind of DRLs most of cars are supposed to run... as long as you have something lit up front - they are happy. so just running AE's as your DRLs is not technically illegal... But dealers for the most part wont turn off your stock DRLs for you. Find an independent mechanic that has tools and skills to do it... that's what everybody does in Canada...
Old 12-20-2009, 07:45 AM   #6
Sacrifice
Ah okok thanks
oh yeah one more thing! will the Umnitza trigger wiring system work with any transformers and angel eyes?? because i got AEs from eBay, and i don't want to buy the hole system again...
Old 12-20-2009, 11:24 AM   #7
I_kgb_I
My Ride: 2005 325i
I am no expert but i don't see why not... it all depends on what AEs you bought, what kind of ballasts they have, etc....
Old 12-20-2009, 08:19 PM   #8
Sacrifice
ahh i can only try and hope for the best :|
thanks for all your help though!
Old 12-20-2009, 08:57 PM   #9
jbugg328
My Ride: BMW 328ci
can someone help me out real quick., i will be ordering the orion v2s from umnitza probably tomorow.. yes!!! but
the question is that they have A selection that i need to choose from
2000-2003 coupe/sedan/wagon
or
e46 323/328
i have a 2000 328ci. WHICH ONE DO I CHOOSE. I DONT WANT TO CHOOSE THE WRONG ONE. IF THERE IS A WRONG CHOICE..THANKS
THEY ARE GOING TO BE A XMAS GIFT FROM THE G.F. LOL
Instagram : JrVincent7
jbugg328 is offline   Reply With Quote
Old 12-21-2009, 11:12 AM   #10
I_kgb_I
My Ride: 2005 325i
No prob - enjoy your AEs
or
e46 323/328
i'd call 'em and ask - they have pretty good support
Old 02-07-2010, 10:51 AM   #11
Sacrifice
ok so i tried using the wiring harness on non-umnitza AEs rings and inverters... and it flopped :\
basically, the voltage coming through the wiring harness is 12V and the voltage coming from the DRL connections is 12V so i thought it would work :S however, when connecting the inverters up to the wiring harness, the voltage coming through changes to 3V :S
so now, i'm going to find inverters that umnitza do, connect them up to the non-umnitza AEs rings and see if it works otherwise, i'll buy the rings too....
does anybody know where to get umnitza inverters/ballasts??
(basically these: http://www.fastm.com/m3/angeleyes/angeleyes03.jpg)
thannkkksss
Old 02-07-2010, 11:05 AM   #12
3uroslut
My Ride: 328ci 5speed
i did the exact same thing it came with the kit i beleive
Originally Posted by I_kgb_I View Post
^ +1...
that's what i did
~~~~~INSTAGRAM @3uroslut~~~~~~
2000 328ci 5speeed uuc stage 2 clutch, 3.07 welded diff, ddm coils, solid rtabs, comber kit front and rear, bride zeta 2 racing seat, NEXT MOD: SLR super angle kit
3uroslut is offline   Reply With Quote
Old 02-07-2010, 02:37 PM   #13
Sacrifice
yup, thing is i installed non-umnitza AEs before, i just bought the wiring harness to see if i could use the current AEs to do it, but my previous post explains my problem
Old 02-07-2010, 02:51 PM   #14
Mike@F1 AutohaŘs
Past Site Sponsor
My Ride: E46 330ci
The wiring harness is universal and will work on any angel eye setup, regardless if they're CCFL or LED
Mike@F1 AutohaŘs is offline   Reply With Quote
Old 02-08-2010, 05:45 PM   #15
Sacrifice
i don't think so :S
the voltage across the harness connection to the ballast drops from 12V to 3V when the ballasts are connected... i think there's a difference in resistance... ill try once more i think, just in case you're right...
Old 02-08-2010, 05:50 PM   #16
Tremorz
My Ride: 01 325ci
sorry to sidetrack a little here..
but why would not having DRL's be illegal? i know some fairly new cars that don't come with them.
the same cars in the US that don't have them, are modified to have them in other countries?
Tremorz is offline   Reply With Quote
Old 02-09-2010, 08:15 AM   #17
Sacrifice
it's part of the UK's MOT, but i have no idea why it is :S
angel, drl, fastm, umnitza, wiring
