Old 12-17-2009, 04:03 PM   #1
Finch 330ci
My Ride: 330 Ci Sport Convert
E46 330CI Engine install problems
Does anybody know if ECU and ignition needs recoding if a replacement engine is fitted ?
I have just had another 330ci m54 engine installed, the car is currently a 330ci. a local mechanic has installed is not an expert on bmw.
Is there somethink programmed or summit that would stop you starting the car after fitting a replacement engine ?
It is really annoying, car has been off the road two months now ! engine has been in over a week but cant start it !
Any ideas ?
thanks
The car wont start, sensors have been checked and swapped with original engine.
Thought after this were that the code may have been erased from the key, spare key has also been tried with no joy !
Finch 330ci is offline   Reply With Quote
Old 12-17-2009, 04:17 PM   #2
paraklas
My Ride: ESS TS2 320ci
No programming required. When I did a M54B22 to a M54B22 swap, it fired up immediately. Is your fuel pump working? Does the car crank at least?
Old 12-17-2009, 04:27 PM   #3
Finch 330ci
I'm not sure i havent been down to see it. as far as i know its doing nothink.
hence why they think it might have lost the code or summit
Old 12-17-2009, 06:46 PM   #4
PEI330Ci
58mm of Bliss
PEI330Ci's Avatar
My Ride: 330i, 330Ci
The DME will not allow the starter to turn over if the Throttle Body is not connected. Have him check that the 6 pin connector is seated properly.
Old 12-17-2009, 09:10 PM   #5
mrshelley
My Ride: 2004 330i
Check to make sure everything is hooked up in the DME area (i.e. the coil pack power connector).
Old 12-18-2009, 10:43 AM   #6
ZeroSum
My Ride: 05 325
Has your mechanic hooked it up to a scanner? That should help narrow the issue down.
ZeroSum is offline   Reply With Quote
