Old 12-21-2009, 03:49 PM   #1
DenaliXTC
My Ride: S/C M3, 745i, X5M
Send a message via AIM to DenaliXTC
Whats the difference between a resonator and a muffler?
This is probably a stupid question. Flame suit on just in case.
Does one restrict airflow more than the other, or is one quieter than the other?
The reason I ask is because I am putting the HPF straight pipe exhaust on my M3. I wanted to put a small muffler on my aftermarket X pipe. I see that some xpipes are resonated. Wanted to know if it would be better to just slap a resonator or muffler on the x pipe. My car is NA and i know the HPF will be real loud hence why I want to muffler the X pipe.
TIA guys!
Active Autowerkes Gen 7 Stage 2 | Evosport | Vorsteiner | DPE | Supersprint | Rogue Eng.
Brembo 6pot 355/4pot 345 | Dinan 3.91 | HKS | HPF | Custom GTR | Radar Mirror | Leatherz | Beemer Evolution
LSB/Cinn M3 490 RWHP superflow dyno
2014 335 X-Drive M Performance OEM+
2011 X5 M White/Blk Vorsteiner
2007 M5 Dinan S3 5.8L Stroker+
DenaliXTC is offline   Reply With Quote
Old 12-24-2009, 03:57 PM   #2
zx5rider
My Ride: 03 M3 , 03 TT 330,
Send a message via AIM to zx5rider
I am told that Muffler is for volume and resonator is for rasp idk
'03 330 Technique Tuning Stage 2 Turbo. (Parting out)
'03 M3
'11 BMW s1000rr
zx5rider is offline   Reply With Quote
Old 12-24-2009, 04:04 PM   #3
Rene325ci
My Ride: a car
Found this on mufflers and resonators. It should help
Resonator
Originally Posted by Born Again View Post
relax kiddies ur 10 year old car is still god on this forum
Rene325ci is offline   Reply With Quote
Old 12-26-2009, 01:35 AM   #4
mkodama
mkodama's Avatar
A muffler in it's most simple form is simply designed to reduce volume of the exhaust. Frequently this is done by passing the exhaust gas through, or surrounding it in a combination of baffles, perforated mesh, and/or steel/ceramic wool.
A resonator is designed to amplify or cancel specific frequencies of sound. Usually though relatively precise placement of baffles and calculated volumes.
Quite often the terms are mixed together. In the case of an E46 exhaust system, if you look at the it, there will be 3 "chambers". Two will have a stamped and flattened design, and if you tap it with a piece of metal, it will have a pretty dead "thud" two it. There will be one resonator, and it will be a neater looking oval cylinder, and if you tap it with a piece of metal, it will have a little bit of a ring or higher pitched tap.
