Old 12-22-2009, 01:01 PM   #1
david @ eas
Past Site Sponsor
My Ride: E46 M3
eas | Macht Schnell - Competition Wheel Spacer kits for BMW
In order to give your BMW a much more aggressive stance while increasing handling, we offer our line of Macht Schnell Competition Spacer Kits.
Machined from 6061-T6 aerospace aluminum, these adapters are strong as well as lightweight to limit unsprung/reciprocating weight for maximum performance on or off the track. Spacer edges are also chamfered to allow for easy installation/removal if needed. After machining, the spacers are then anodized for additional strength, anti-corrosion & wear resistance.
A wider track stance increases lateral stability as well as giving your BMW a much more aggressive appearance after installation. Spacers also are used to correct wheel gap normally seen on otherwise stock suspension setups, pushing the wheels outward - filling the fenders.
Included with our Competition Wheel Spacer Kits are a full set of extended lug bolts in black OEM finish. All wheel fasteners are hardened and tempered to strength class 10.9 or 10 according to DIN/ISO standard 898 and meet the statutory requirements of all countries - including the US.
Competition Wheel Spacer kit Features:
- Machined from 6061-T6 aerospace aluminum
- Chamfered edges allows installation & removal quick and easy
- Black anodized finish for additional strength and corrosion/wear resistance
- Improve handling by reducing body roll with a wider wheel base
- Included black extended-length corrosion-resistant wheel fasteners
Macht Schnell - Competition Wheel Spacer kit for BMW - 03mm
http://www.europeanautosource.com/pr...oducts_id=2197
Macht Schnell - Competition Wheel Spacer kit for BMW - 05mm
http://www.europeanautosource.com/pr...oducts_id=2198
Macht Schnell - Competition Wheel Spacer kit for BMW - 10mm
http://www.europeanautosource.com/pr...oducts_id=2199
Macht Schnell - Competition Wheel Spacer kit for BMW - 12mm
http://www.europeanautosource.com/pr...oducts_id=2200
Macht Schnell - Competition Wheel Spacer kit for BMW - 15mm
http://www.europeanautosource.com/pr...oducts_id=2201
Macht Schnell - Competition Wheel Spacer kit for BMW - 18mm
http://www.europeanautosource.com/pr...oducts_id=2202
Models Supported:
2008+ 1-series
1992+ 3-series, including M3 (e36, e46, e90, e92)
2004+ 5-series, including M5 (e60)
2005+ 6-series, including M6 (e63, e64)
2004+ X3 (e83)
2000+ X5 (e53, e70)
2003+ Z4, including M-Roadster/Coupe (e85)
2001-2003 Z8
1996-2002 Z3, including M-Roadster/Coupe
All sizes are currently in stock and available for immediate shipment.
david @ eas is offline   Reply With Quote
Old 12-23-2009, 03:35 AM   #2
bigjae1976
bigjae1976's Avatar
My Ride: 2011 E90 M3
I have a stud kit already and I just need spacers on my 2 front wheels. Can I get 2 3mm and 2 5mm spacers w/o lugs?
2013 F30 328i - Melbourne Red
2004 E46 M3 - Imola red
Old 12-23-2009, 11:40 AM   #3
tom @ eas
european auto source
tom @ eas's Avatar
My Ride: e92 S/C M3
You have PM.
tom @ eas is offline   Reply With Quote
Old 01-06-2010, 09:02 PM   #4
mr. vapor
My Ride: '06 Carbon Black ZCP
Jurian,
it doesn't look like the spacers are showing up on your website anymore?
can you PM me a quote?
1 pair of 18mm with black studs
1 pair of 10mm with black studs
Shipped to 14425 (NY)
2006 M3 - Competition Package - Carbon black [Nav] [M-DSC] [HK] [ZPP] [ZCP]
[Powerflex RTABs] [Black kidneys/grilles] [Depo corner lights] [Powdercoated 19" CSL ] [235/265 CSL spec Potenza Pole Positions] [Smoked reflectors] [30% tint]
mr. vapor is offline   Reply With Quote
Old 01-07-2010, 12:17 PM   #5
david @ eas
Past Site Sponsor
My Ride: E46 M3
Originally Posted by mr. vapor View Post
Jurian,
Not sure why you didn't see them, they're right here!
Macht Schnell - Extended Wheel Lugs +10mm
http://www.europeanautosource.com/pr...oducts_id=2333
Macht Schnell - Extended Wheel Lugs +18mm
http://www.europeanautosource.com/pr...oducts_id=2336
I hope that helps!
Old 01-08-2010, 03:08 AM   #6
bombguy
bombguy's Avatar
My Ride: 2004 M3
What sizes would I need on a completely stock M3 with the stock 19's to push the wheels out in line with the fenders with no rubbing issues?
2004 JB
KWv2, Spacers 15/F-10/R, MVR Rep, Alpine IDA-X305 w/ KCE-BT400 Bluetooth,
Agency Power Exhaust, Khoalty AE's
bombguy is offline   Reply With Quote
