Sponsored by The Tire Rack
Old 12-26-2009, 12:30 AM   #1
///Miller325ci
My Ride: 2005 Dinan-S2 325Ci
Exclamation GARY: Tire SIZE Question about the BMW Style 195's
OK so I have been searching for a while but I cant find the answer so im going to ask... my car came with 225/45/17's all around I know that as an option i can mount a 245/40/17 on the car in the rear... and since i know or at least... im pretty sure that the rims are the same sizes on all four corners...
My Question can I fit a 245/45/17 on all 4 corners on the stock 17X8 rim at least I am pretty sure they are 17X8.... and does it make sense to do a 245/45/17 or is there negative side affects i want to increase my contact patch to the ground on all 4 corners so that i can easily rotate them and at the same time have a square setup which has less understeer than running a staggered setup
oh yes i do romp on it pretty hard and often so im not going for the larger contact patch for just looks haha =]
///Miller325ci is offline   Reply With Quote
Old 12-26-2009, 06:16 PM   #2
///Miller325ci
funny how its been viewed 45 times and nobody has answered
Old 12-26-2009, 06:26 PM   #3
shortyb
My Ride: Has blue lights
You may want to consider 245/40/17s. 245/45 will be too tall. And yes, 245s will fit on an 8" rim just fine.
shortyb is offline   Reply With Quote
Old 12-26-2009, 07:00 PM   #4
///Miller325ci
humm sounds like a good idea then... so ill probably affect my speedometer a little though right? um the 245/45's would rub ya think?
Old 12-26-2009, 11:00 PM   #5
cheech320
My Ride: Is TiAg
depending on the offset of the wheels and how much you have lowered the car, you will probably rub with a 245/45
-Anthony
Photobucket
cheech320 is offline   Reply With Quote
Old 12-28-2009, 05:50 AM   #6
///Miller325ci
well right now im stock ride height on sport suspension haha for now
Old 12-28-2009, 08:36 AM   #7
Rudy@Tirerack
Moderator
Rudy@Tirerack's Avatar
My Ride: 1-800-428-8355 X4664
245/45R17 will likely rub, but 235/45R17 works in most cases with no problem.
Refer to 'Rudy/E46Fanatics' as your previous contact when you order online. Credit E46Fanatics.com by clicking here.
Rudy@Tirerack is offline   Reply With Quote
Old 12-29-2009, 04:16 PM   #8
///Miller325ci
hummm that might be the answer! haha didn't think of that
Old 01-06-2010, 06:18 PM   #9
///Miller325ci
i do have another question haha if got those 235s do you think that they would last longer than a 225...my thoughts were that since i would be putting a little bit more rubber down on the road the tires would have to work less hard to maintain traction the same level of traction as with a smaller width tire.... because i figured that with a larger tread width the heat that the tires generate would be diffused over a greater area making the the heat spread out more instead of being more focused over a smaller area of tread... keep in mind i typically get tires around 200-220 treadwear and get about 8000-9000 miles from them
Old 01-06-2010, 07:01 PM   #10
shortyb
Uh, no. Wear will be the same. Think of it this way, you are subjecting an additional 10mm (nominal) of the same compound to the same kind of use/heat/wear as the other 225mm (nominal). Its just a wider version of what you already have. The only "gain" will be a very slight increase in grip (longitudinally and laterally) that you most likely will not notice.
Old 01-06-2010, 08:00 PM   #11
///Miller325ci
hummm interesting well if u think about it in terms of brakes.... smaller rotors usually means that it will heat up faster and be more prone to fade... larger rotors the heat transfer is over a larger area which allows the heat move around more and cool off quicker... which is why i was thinking tire wear might be related to how much u heat them up... to some extent... my thoughts are that if this is true with brakes then tires would work in a similar way... the heat would have more room to transfer around and cool... keeping the tires cooler... ? maybe the effect would be greater over a more drastic change in tire width...
Old 01-07-2010, 06:15 PM   #12
shortyb
Apples and oranges comparison with brakes, but I see your point. I believe heat and subsequent wear vs. width is more linear in regards to tires.
Old 01-07-2010, 06:41 PM   #13
TxZHP04
My Ride: ESS TS2+ ZHP
All other things being equal, increasing the width of the tire only changes the shape of the contact patch not its area.
Old 01-10-2010, 06:34 AM   #14
///Miller325ci
ah yeah i see haha good call haha anyone know a good place to buy bbs RGR rims that are 17x8 that aren't ridiculously expensive haha
Old 04-13-2010, 02:38 AM   #15
///Miller325ci
I actually ended up going with a 245/40/17 on all for corners... =] its a pretty good set up =] but since im currently running a 17x8... i am wondering if i went to a 17x9 going from the stock ET47 offset to a BBS RGR in 17*9 on all four corners at a ET42 if I will be able to fit without rubbing... I know that dinan fits a 19x9 on all four corners running a 245/35/19 however i don't know their offsets.... and from what i know... it doesn't rub on their suspension kit which i am getting put on any day know =]
