Old 12-30-2009, 01:45 PM   #1
Bryan@Jlevi SW
1.888.JLEVISW
My Ride: E46 330i ZSP
Send a message via AIM to Bryan@Jlevi SW
Jlevi SW | LED bulbs (License, Reverse, Turn, etc.)
sales@jlevisw.com | 1.888.JLEVISW | www.jlevisw.com
Jlevi SW has reduced pricing on our LED line of replacement bulbs.
NOTE: All Prices Listed are for a SET
JleviSW V3 Xenon White High Output LED License Plate/Footwell Bulbs (6418)
New, Class-Leading Features:
-9 Ultra-bright 1W SMD LEDs PER BULB, Totaling 18 LEDs.
-Our brightest, most evenly-illuminating version yet!
-Brighter and more distinctive than OEM bulbs!
-More crisp, clean, xenon white color!
-1 Year Warranty
-Never burn out, guaranteed!
-Less heat than "hyper-white" halogen bulbs
-Direct replacement installation, no messy wiring required
V2 High Output LED SideMarker Bulbs (194)
Includes 2 194 fitment LED bulbs, with 6 Bright LEDs each. It will convert your sidemarkers to bright LEDs, changing the color (for white) as well as giving an "instant on, instant off" blinking effect.
COMPLETELY clear when off! Available in blinking amber or xenon white.
Click Here to Order
Xenon White LED Backup Bulbs - V2 High Output (Multiple Fitments)
After experiencing great success with our Version 1 24LED backup/reverse bulbs, JleviSW is proud to present our 32LED high output LED Bulbs.
Standard Setup Includes
-(2) LED Bulbs of your select fitment & color (Each 32 LED Matrix Design, except 7440 which is 30LED)
-LIFETIME WARRANTY
Click Here to Order
High Output 32 LED V2 Bulbs for Turn Signals (Multiple fitments)
-Instant on, instant off blinking. No more slow "fade" blinking like halogen bulbs
-Improved output LEDs, and more of them, to help fill the entire housing with bright, colorful light
-Improved 6000K color - Unmatched by any "hyperwhite" halogen bulb
-Virtually no heat from actual bulb
-Improved, Richer Amber color for Amber bulbs
-No egg yolk - bulbs are perfectly clear when off
-Never burn out!
Click Here to Order/More Info
Bryan@Jlevi SW is offline   Reply With Quote
Old 01-08-2010, 03:26 PM   #2
Bryan@Jlevi SW
1.888.JLEVISW
Thank you guys for your orders.
Old 01-12-2010, 12:23 PM   #3
dreamteam1000000
My Ride: 2003 x5 (e53)
just ordered mine hey i didnt get the ones that go in the corner lights do you have those
e46
dreamteam1000000 is offline   Reply With Quote
Old 01-13-2010, 02:34 PM   #4
Bryan@Jlevi SW
1.888.JLEVISW
yes we carry those as well.
Old 01-14-2010, 01:57 PM   #5
alumniu
My Ride: 2002 BMW 330i
Was thinking about getting some of the reverse lights...do these need a separate resistor to work? Will they trigger a bulb out warning if no resistor?
alumniu is offline   Reply With Quote
Old 01-14-2010, 02:11 PM   #6
Bryan@Jlevi SW
1.888.JLEVISW
the resistors are only necessary for the turn signal LEDs I believe
Old 02-12-2010, 11:22 AM   #7
mooshu1221
My Ride: 2008 335i E92
when ordering the led turn signal from your website, does it include the load equalizer in it already or do i have to buy that seperate?
mooshu1221 is offline   Reply With Quote
Old 02-12-2010, 01:38 PM   #8
Bryan@Jlevi SW
1.888.JLEVISW
those are sold separately at $15/set.
Old 11-28-2010, 07:12 PM   #9
M-tech7
My Ride: 330ci zhp
which I use for my 2006 330ci license plate 36mm or 39mm?
M-tech7 is offline   Reply With Quote
Old 11-29-2010, 03:41 PM   #10
Bryan@Jlevi SW
1.888.JLEVISW
We only offer one size for the LED festoon bulbs for the license plate. The PN is LEDLPL. It should fit fine but it'll be slightly longer than stock.
