Old 01-01-2010, 07:53 PM   #1
sally325i
My Ride: 330
overheating all the wayy across the williamsburg bridge...
i was coming from work and my 03 325ci needle was on red started overheating smoking... car shuts off on the bridge.. i open hood my bleedscrew on upper radiator hose had cracked and melted... nd steam was shooting out... i had to get it off the bridge so i started it again nd it started sounding like it was knocking.. kept turning off.. nd smoking then when i got it off bridge i parked it nd it wont start... sucks man day before xmas eve this happened.. my battery is drained to 8volts.. and i towed the car back to my house and even with a jump it cant seem to start. anyone can relate to these problems or heard of this before. because im hoping i dont need to buy a new cylinder head.. i checked my oil its not mixed with coolant . and i dont and didnt have any smoke out the tailpipe. just smell of burnt coolant. if anyone can shed some light on the subject that would be nice
sally325i is offline   Reply With Quote
Old 01-02-2010, 03:14 AM   #2
bigjae1976
bigjae1976's Avatar
My Ride: 2011 E90 M3
Yup, called expansion tank failure followed by engine failure.
So basically, your needle was on the red and you kept driving with the car running? Should have shut it off and coasted to the side. You probably f'd your block so its time for a brand spanking new $10k BMW engine.
2013 F30 328i - Melbourne Red
2004 E46 M3 - Imola red
Old 01-02-2010, 09:35 PM   #3
mrshelley
My Ride: 2004 330i
Start looking for a salvage yard motor. If it won't start, it's too damaged to repair it vs. getting a salvage motor.
Old 01-02-2010, 11:30 PM   #4
bigjae1976
bigjae1976's Avatar
would his VANOS unit be good? I could use an extra one.
OP needs to part that engine out.
Old 01-04-2010, 05:20 AM   #5
chrisnetcom
My Ride: 05 330Ci
That engine is GONE GONE GONE. Start looking for a replacement engine or a new car. How many miles? Had you ever done a cooling system overhaul?
chrisnetcom is offline   Reply With Quote
Old 01-04-2010, 09:35 AM   #6
bigjae1976
bigjae1976's Avatar
Prob not.
