///M3 Forum
Old 01-04-2010, 01:26 PM   #1
infantrytroop22
My Ride: M3
Why do my RPMs drop when coming to a stop?
I have an '05 E46 M3 and the big issue I am having is the RPM's dropping when I come to a quick stop. They drop to between 600 and 800 before jumping right back up and holding steady at 900. It only happens when I come to a quick stop and it only seems to happen when the car is warm. The RPM's will also fluctuate up and down (about 50 to 100 variation) every once in a while at a stand still. My car has 27k miles, Delage intake, pulleys, supersprint section 2 pipe, and GruppeM muffler. Other than those few things, the engine is stock. I am taking my car in to my mechanic early next week, so I am hoping to get a good idea of what I may be looking at...Thanks.
infantrytroop22 is offline   Reply With Quote
Old 01-04-2010, 02:16 PM   #2
KiNi///SoN
My Ride: E46///M3
My car has done the same thing since the day i got it. Its not a big deal, and in some cases sounds kinda cool. I dont really think its a problem man. U can also prevent it by giving it a little gas in neutral while ur coming to that stop. Does it only happen when you got the clutch in? guessing ur not in an SMG.
KiNi///SoN is offline   Reply With Quote
Old 01-04-2010, 02:34 PM   #3
twboy1999
My Ride: 03 CB/KIWI
same problem here (SMG)
only when the car is warm up, for me the problem got worse grdually, and it wont go away
i read somewhere ppl have the same problem and said it was the vanos solenoid, and my vanos did have problem, i clean up the vanos because it was very clug up, the car runs alot better now, but the RPM still drops
if u find out the peoblem, please let us know
twboy1999 is offline   Reply With Quote
Old 01-04-2010, 02:46 PM   #4
infantrytroop22
My Ride: M3
I should have specified. My car is an SMG.
Old 01-04-2010, 02:52 PM   #5
AtotheJ
My Ride: E46/E90/R53
http://forum.e46fanatics.com/showthr...ight=idle+drop
"Do or do not..there is no try.." Yoda
AtotheJ is offline   Reply With Quote
Old 01-04-2010, 02:59 PM   #6
dcf
My Ride: 02 e46 M3 SMG - LSB
That is the delay before the computer "pushes in the clutch pedal". Then, once the driveline is disengaged, the RPM's come back up to the normal operating idle. Nothing out of the ordinary in what you described.
dcf is offline   Reply With Quote
Old 01-04-2010, 07:28 PM   #7
toddkageals
My Ride: 2008 335i sport/prem
Hate to disagree with you and it's hard to tell just by a written description but what you wrote is NOT consistent with how my SMG transmission operates. When coming to stop, mine disengages smoothly right BEFORE 900 RPM. Now....I DO have an idle drop problem when the A/C is on but not when coming to a stop.
toddkageals is offline   Reply With Quote
Old 01-04-2010, 07:39 PM   #8
EndlessAP1
My Ride: e92 M3, e70 X5, TL
That sounds normal to me. My NSXs, 350z, S2000, M3, etc all did that when AC is turned on or off. That is normal. Sorry to say, but true.
Acura TL
E92 M3
E70 X5
EndlessAP1 is offline   Reply With Quote
Old 01-04-2010, 08:30 PM   #9
toddkageals
Uhh...no...not in this case. I'm not talking about 100RPMs or so. In my car, engaging the A/C (or the automatic cycling of the compressor) causes the RPMs to drop so low that the engine vibrates the inside of the car. I have had this problem in all 3 of the BMWs that I have owned. I corrected the issue on my 328i by having the VANOS replaced (under warranty thank God). On my 330i I found a vac. leak that was causing the problem. Both cars had a rock steady idle (A/C on or not) once the repairs were completed. I will find the cause on the M3, I just have not had time to work on it yet. Again...I'm sure some RPM drop is normal but not to the extent that I have it!
Old 01-04-2010, 08:35 PM   #10
toddkageals
Oh...I should mention that I temporarily fixed this "problem" by resetting the DME adaptation values using carsoft 6.5. Worked for about a day and then went back to dropping revs. once it started adapting again.
Old 01-05-2010, 10:46 AM   #11
mirob
My Ride: E46 M3
usually its a early symptom of VANOS Solenoid failure, happened to me...
mirob is offline   Reply With Quote
Old 01-05-2010, 01:28 PM   #12
infantrytroop22
My Ride: M3
The VANOS solenoid is not that expensive to fix, right?
Old 01-05-2010, 02:46 PM   #13
mirob
My Ride: E46 M3
its easy, but not exactly cheap, you are looking at approximatelly $650 includeing the seal plate ($20), and I do recommend changing that as well...
Old 01-05-2010, 03:52 PM   #14
twboy1999
My Ride: 03 CB/KIWI
infantrytroop22
if u get it done, let us know how it goes
Old 01-05-2010, 03:52 PM   #15
infantrytroop22
My Ride: M3
How many hours of labor is it?
Old 01-05-2010, 07:31 PM   #16
twboy1999
My Ride: 03 CB/KIWI
changing solenoid, should be under 1hr
read somehwere, only take like 30-40 mins to change
Old 01-05-2010, 09:10 PM   #17
m3e46freak
My Ride: m Twee lol
Well since you spoke about it.. how did you clean up the vanos.. perhaps it will help my problem.
Rock Hard Abs Racing
ST Coil!
BREMBO
Apex!
Agency Power Headers!
Euro Cats!
Scorza Mufflers!
FRANK!! 311RWHP-260Torque
m3e46freak@yahoo.com for outside contacting
ebay/craigslist verified 100% FEEDBACK
m3forum 96% FEEDBACK
m3post/e46fanantics Great FEEDBACK
zpost/bimmerforum Great FEEDBACK
m3e46freak is offline   Reply With Quote
Old 01-05-2010, 10:35 PM   #18
twboy1999
My Ride: 03 CB/KIWI
no idea
my shop did it for me
Old 01-06-2010, 01:10 AM   #19
m3e46freak
My Ride: m Twee lol
Cant be that hard.. hrm...
*search*
ST Coil!
BREMBO
Apex!
Euro Cats!
Scorza Mufflers!
