E46 Xi Forum
Old 01-06-2010, 12:23 PM   #1
small_m
My Ride: 2002 325xit
Question Bad MPG in my XI... is this normal
I seem to be filling my car up all the time! I drive a 2002 xit manual. I dont have the trip computer but i have calculated that i am getting roughly 19-20mpg. This seems quite low concidering that i spent most of my time on the freeway. I would like to know what other xi drivers are getting. I dont drive with my foot on the floor the whole time so I am wondering if there could be something wrong with my car. I hear that a bad vanos can cause poor gas milege. Any other suggestions if looks like my car is drinking more than it should
small_m is offline   Reply With Quote
Old 01-06-2010, 12:46 PM   #2
Kubica
My Ride: 2003 325xi
I'm sure your vanos is fine.
Do you have any codes? I would start there- get them read.
I would replace the fuel and air filters, make sure you have good oil, check your tire pressures, check your intake for any cracks or leaks, spark plugs, and make sure you don't have a sticking caliper, etc.
Old 01-06-2010, 12:53 PM   #3
Chibo
My Ride: Nothing
I'm also getting right around 20mpg, I think it's normal, but I also waste gas sometimes.
2005 330i ZHP Sedan (Street/Track)
2002 Honda S2000 (Street/Track)
2003 Yamaha R6 (Track/Race)
2007 Aprilia Tuono 1000 (Street/Track)
Chibo is offline   Reply With Quote
Old 01-06-2010, 12:59 PM   #4
wdeerfield
wdeerfield's Avatar
My Ride: 2009 E90, 2011 F10
i drive highway and get approx 25-28 mpg.
but also, remember that during the winter, gas quality is poorer..
i would change your spark plugs, fuel filter, air filter, oil and filter as others have mentioned.
2013 EB 335i xdrive | Msport | Coral | DHP | ZPP | ZCW | ZTP | 400M | Coded | MPerformance Bits | M3 Grills | Painted Reflectors | BMS Exhaust Tips | LED Turn Signals
2011 JB 535i xdrive | ZPP | ZSP | ZCW | 6FL | NAV | 331s Square | MPerformance Spoiler | M5 Grills | Painted Reflectors
wdeerfield is offline   Reply With Quote
Old 01-06-2010, 01:03 PM   #5
GuidoPorkchop
My Ride: 2003 325xi
Ditto...I have 98k on my bad boy...I'm hoping the new plugs and air filter helps out a bit. Does anyone know what the most gas efficient speed is for the xi? 55MPH?
GuidoPorkchop is offline   Reply With Quote
Old 01-06-2010, 01:24 PM   #6
CRXnut
My Ride: 2004 325ci
what's your tire pressure?
CRXnut is offline   Reply With Quote
Old 01-06-2010, 01:27 PM   #7
GCoop
My Ride: '04 325xi
Highway only -- In the High 20's.
  • All time high was 31.5 (OBC) on a 280 mile trip returning from PA to VA
Mixed -- Mid 20's
Town only -- Low 20's
GCoop is offline   Reply With Quote
Old 01-06-2010, 01:29 PM   #8
wdeerfield
wdeerfield's Avatar
i find keeping it under 2500 rpms is the sweet spot, easy on the accelerator and limit your braking, utilize coasting into off ramps as oppose to gas pedal and then braking late.. I do cruise control at 68-71 and get good results.
Old 01-06-2010, 01:48 PM   #9
Mark M
My Ride: e30 M3 / e90 335d
I do ~70 miles a day which is about 50% highway at 80mph, 50% rural roads at 50mph.
If I am light on the pedal I can average ~27mpg per tank. If I am enthusiastic I typically score about 22mpg per tank per the OBC.
Make sure your tires are properly inflated.
Mark M is offline   Reply With Quote
Old 01-06-2010, 02:43 PM   #10
Kubica
My Ride: 2003 325xi
Yeah, i get 24.5 mpg on summer tires and 26.5 on all-season tires.
OP- this is what i would do:
1) check tire pressures first- i like 33Front/36rear
2) Fill up with Shell v-power
3) get a new Mann air filter
4) Check plastic intake prices for leaks
5) Drive half a tank and see if mileage goes up (forget the on-board computer, use the trip mileage counter and divide by gallons)
6) If that doesn't help, replace spark plugs (easy- NGK BRK EQUP) and fuel filter (messy- Mann).
Do you have any other symptoms besides low mpgs? No vibrations, rattles, noises, feelings that seem odd?
Old 01-06-2010, 08:44 PM   #11
dpgrand
My Ride: 2005 330xi
I average about 22 and i have the Dinan stage 3 throttle body
'05 330xi - Koni, H&R, Rogue, Supersprint, UUC, Dinan, Apex
dpgrand is offline   Reply With Quote
Old 01-06-2010, 09:00 PM   #12
Vade46!!!
My Ride: '03 AW 325xi
During the summer I was averaging near 24mpg and now getting just under 23mpg in below freezing temps. I drive about 50-75 miles a day, mostly highway, and I'm usually beating the crap outta the car. Since I have an automatic, I'd assume that what your getting with a manual is well below where it should be.
Vade46!!! is offline   Reply With Quote
Old 01-10-2010, 02:22 PM   #14
small_m
Good to hear i am about normal then. I do drive rather enthusiastic too which doesnt help. I have done all that is suggested bar the fuel filter.
Thanks for all the feedback
Lee
Old 03-20-2010, 10:45 PM   #15
chandrab
My Ride: Lotus Esprit SE/BMW?
I'm getting 19.9 on my 325xi, which surprised me considering it a 70/30 split of highway/city and I don't have a lead foot. I just replaced my sparkplugs and air filter today...I'll report back if I see an increase. I was surprised that I had OEM Bosch +4 installed and at 82K miles they looked pretty worn.
-Chandra
03 325xi
91 Lotus Esprit SE
chandrab is offline   Reply With Quote
Old 12-14-2010, 10:05 PM   #16
gordo325xiwagon
My Ride: 01 325xit '12 328i
A little controversy to stir the pot.
All the suggestions for better mileage are good, except the one about changing air filters. Unless an insufficient amount of air is getting through [sic. a completely clogged filter], a dirty air filter will NOT decrease your car's mileage; and changing it out will not increase your mileage.
I know this seems to run against everything we were taught about internal combustion engines; but all these recommendations advising a filter change refer to cars with carburetors, not electronic fuel injection (EFI).
Cars with EFI and Mass Air Flow meters always adjust the air/fuel ratio mix. If the throttle plate is opened, more fuel is allocated. The throttle plate is a much greater restriction to air flow, than any dirty filter could become.
Consequently, at a given speed, the throttle plate may be open wider on a car with a dirty filter; the amount of air is always the same. Hence no advantage to having a clean filter to allow more air... you don't need more air.
The only exception to this dynamic is at WOT wherein the total amount of air available has been diminished. In this case the power of the engine is likewise compromised. But in everyday driving, the air fuel mix always remains the same, regardless of dirty or clean air filter,... and so does the mileage.
____________________________________________________________ _____________
2001 325xit and 2012 328i Sportwagon
gordo325xiwagon is offline   Reply With Quote
Old 12-15-2010, 03:48 PM   #17
TwoDuckDad
My Ride: 2001 330xi jet black
pure interstate driving with some hills over a 260 trip I make twice a week using premium branded gas, car running like a champ, only engine mod is Dinan cold air intake and Dinan stage II software and I get 27mpg going 75-80mph and light on the pedal and 225/45-17 tires on stock wheels at 35psi with only me and light luggage in car. I don't spend enough time driving in the city to give any figures.
Premium, Sport, & Cold Weather Packages
If you dog doesn't like somebody maybe you shouldn't either.
TwoDuckDad is offline   Reply With Quote
Old 12-15-2010, 04:00 PM   #18
SamDoe1
My Ride: 4cyl of fury
Yes, this is true but with a small catch. You are talking about the actual volume of air in the cylinder is the same no matter what, and that is true. The ECU will always determine the amount of air pulled in and inject the appropriate amount of fuel for the equivalent intake charge. BUT, it's not about how much air is pulled in, but how easily it is pulled in. If you choke off the end of a vacuum cleaner, or restrict the intake, the motor works significantly harder to pull in the same volume of air. This brings us to the concept of "ram" air intakes in which the air is literally "rammed" into the intake instead of sucked in by the engine, this brings a small amount of efficiency with it as the engine doesn't have to suck the air in itself. So while the actual amount of air in the intake charge wouldn't change, the amount of efficiency lost from a dirty/clogged filter would have an impact. Now if the question is how much power will you gain, the answer is likely very very little to none. You will, however, gain a few miles per gallon because of the change in efficiency.
Also, I get approximately 24-26mpg driving to/from work in rush hour stop and go traffic. I get 32-35mpg cruising on the freeway for 5 hours straight.
Old 12-15-2010, 04:45 PM   #19
Capt1014
My Ride: 2002 325xi
Combined overall highway and city I'm getting approx 25 -26mpg, 5 speed manual.
Mods, Bilstein HD Struts & Shocks, H&R Springs, F1 Racing Stage 2 Clutch & Chromoly Ltw Flywheel...more to come.
Overkill is an often underrated state of achivement!
Capt1014 is offline   Reply With Quote
Old 12-15-2010, 05:33 PM   #20
lotar_6
My Ride: '01 xi, '94 Rado
stock '01 325xi manual I got 28mpg on a 700 mile trip w/ cruise set around 80mph when possible. I've yet to measure mixed city driving.
as mentioned, start w/ a basic tune-up, scan for codes, and check for air leaks.
lotar_6 is offline   Reply With Quote
