Go Back   E46Fanatics > Tuning & Tech > Suspension & Braking
Old 03-11-2010, 03:26 PM   #21
ECSTuning
ECSTuning's Avatar
My Ride: BMW
Originally Posted by SpeedDemon View Post
I'm confused.... do all of the FK Coilovers come with Koni dampers or only certain versions?
The FKs that come with Koni shocks are the following...
Silverline
Silverline X
Konigsports
800.924.5172
Old 03-12-2010, 08:20 AM   #22
Project330i
My Ride: in awesome cars.
Man, $699 for a 6 way adjustible coilover setup w/ Koni's!?
I live in Boston and I run Koni yellows and H&R race... i'm looking to go with coilovers so that I can A. Get adjustability (raise for long drives north and lower for spirited driving) and B. get an aggressive setup for the occasion track use...
What do you guys think about going to this setup from what I'm running now?
I paid $700 for the Koni's and $250 for the springs before shipping... so thats over $1k going to a $700 suspension......... skeptical but about ready to make the jump
Project330i is offline   Reply With Quote
Old 03-16-2010, 12:59 PM   #23
redlin'r
My Ride: (E46) 330Ci
Joe,
Can you give us the spec's on the spring ratings for the following:
Sport Edition Plus E46 3-Series Coilover Suspension Kit-Externally Adjustable:
Konigsport E46 3-Series Coilover System-Adjustable Shocks:
Silverline X E46 3-Series Coilover System-Adjustable:
I noticed in some of the pictures on line that some shocks come with new rear mounts in the pictures and some don't. Can you answer which kits are going to come with new rear shock mounts?
I have been waiting to pull the trigger on coils and was pretty close to buyin K-Sport, however, the liftime warranty, vendor and reveiws plus new price are the pursuaders for me.
What is covered under the liftime warranty? Rebuilds? Corrosive housings malfuncting?
My last comment (I appologize for having so many) is regarding adjustments. Do they all listed above have 6 way adjusting, externally with dials? And just to clarify the height adjustments is not seperate and will modify the spring travel, correct?
redlin'r is offline   Reply With Quote
Old 03-16-2010, 01:57 PM   #24
ECSTuning
ECSTuning's Avatar
My Ride: BMW
If your planning on daily driving this vehicle I would suggest the Silverline X's.
FK Silverline X Coilover systems feature a corrosion resistant stainless steel bodies especially desirable for cars in salty or wet conditions.
These FK Silverline Coilover systems are height adjustable from 40-70mm's.
This FK Silverline Plus X coilover system for your E46 3-Series also feature Koni Adjustable shocks.
These Koni shocks give a firm & sporty ride with outstanding performance capabilities and come with a lifetime warranty!
Originally Posted by redlin'r View Post
Joe,
I have been waiting to pull the trigger on coils and was pretty close to buyin K-Sport, however, the liftime warranty, vendor and reveiws plus new price are the persuades for me.
What is covered under the lifetime warranty? Rebuilds? Corrosive housings malfunctioning?
My last comment (I apologize for having so many) is regarding adjustments. Do they all listed above have 6 way adjusting, externally with dials? And just to clarify the height adjustments is not separate and will modify the spring travel, correct?
Unfortunately, FK does not release their spring rates on those models. We have tried on several occasions, and they simply will not give the rates out. This is similar to H&R's policies on their springs.
Actually only the Sport Edition Plus's come with new rear shock mounts.
FK Automotive warranties cover the original owner's product to be free from defects in workmanship and assembly, for as long as they own this FK product.
This warranty covers the build quality over all and the damper (springs and housings only). All claims will go thought us ECS Tuning and we will facilitate any repair or replacement with FK on your behalf.
The sport edition plus are the only ones that are different. They have an adjustment knob that comes with them. The rest are built in.
To make the adjustments on fronts you can adjust while installed, however in the rears would need to be removed to adjust dampening. The shock needs fully compressed to alter them.
As always please let me know if you have any questions! Feel free to shoot me a PM or email.
Cheers,
Joe
800.924.5172
Old 03-16-2010, 02:01 PM   #25
Snik
Snik's Avatar
My Ride: IR M3 Vert.
Joe, how is after warranty support on things like, replacement wrenches, spring perches, shock rebuilds, etc?
Stuff for sale!!!!!
Do you ride a sportbike?
Old 03-16-2010, 02:05 PM   #26
ECSTuning
ECSTuning's Avatar
My Ride: BMW
You simply contact us send photos if it is something that needs repaired send us the part and will take care of it from there.
However if it is something that will need replaced you again will need to send photos and then we will determine cause then send you a replacement.
Those are the two most typical situations, it does not work like that 100% of time because each situation is unique, however those are the two best examples to answer your question.
Best,
Joe
800.924.5172
Old 03-16-2010, 02:09 PM   #27
Snik
Snik's Avatar
cool, im trying to work a deal on a used set, otherwise, i'll most likely go new with you guys later on.
Stuff for sale!!!!!
Old 03-16-2010, 05:31 PM   #28
hummermaniac88
My Ride: 320i
^ should get new from ECS cause you can take advantage of the life time warranty!
hummermaniac88 is offline   Reply With Quote
Old 03-16-2010, 05:37 PM   #29
Snik
Snik's Avatar
pockets are slim bro, just put full suspension on the bike. it aint happening soon
Stuff for sale!!!!!
Old 03-26-2010, 02:43 PM   #30
redlin'r
I just bought mine today and now the ETA is April 26th? What's the reason for this now....This is a big deal if it's going to take that long......PM me please to confirm when my order will be shipped!
Old 03-31-2010, 12:02 PM   #31
zugellos
My Ride: '02 330i
I decided to go with Raceland's!
I've had mine in for a couple of weeks now.
Racking up miles on them...I think I've logged about 1000 miles already.
I'm lov'n it.
Pretty darn good considering how much I paid for them!
zugellos is offline   Reply With Quote
Old 03-31-2010, 12:15 PM   #32
ECSTuning
ECSTuning's Avatar
My Ride: BMW
PM sent!
Thanks for the orders everyone!
800.924.5172
Old 03-31-2010, 01:14 PM   #33
jrmichelbook
My Ride: 2004 BMW 325xi
Will these work for XI models?
jrmichelbook is offline   Reply With Quote
Old 03-31-2010, 01:17 PM   #34
ECSTuning
ECSTuning's Avatar
My Ride: BMW
XI use there own specific coils which you can find below...
Click HERE to order or for more information.
As always please let us know if you have any questions! Feel free to shoot me a PM or email.
Cheers,
Joe
800.924.5172
Old 03-31-2010, 11:14 PM   #35
Dskinn91
My Ride: 04 330i Zhp
http://www.ecstuning.com/BMW-E46-330...ries/ES248296/
how low will theses go on my zhp???
Dskinn91 is offline   Reply With Quote
Old 04-01-2010, 07:26 AM   #36
ECSTuning
ECSTuning's Avatar
My Ride: BMW
FK Silverline's feature height adjustment from 40-70mm's lower then stock. In reality they lowering specs are used for DOT approval. Typically FK systems can go lower than what is stated.
I have created a custom link specifically for you. Click HERE to order or for more information.
From there all you need to do is simply enter your postal code and you will be given an exact & instant shipping quote with no need to log in!
Please let us know if you have any questions! Feel free to shoot a PM or email.
Cheers,
Joe
800.924.5172
Old 04-01-2010, 09:55 AM   #37
glovesoff
My Ride: 1999 328i
so I see the "corrosion resistant" coils... but what are the consequences of running Sport Edition Plus coilovers in the snowy Midwest? I like the price/adjustment capabilities of the Sport Edition Plus, but are they going to rust away after 3-5 years?? Is that covered under the warranty?
glovesoff is offline   Reply With Quote
Old 04-01-2010, 10:00 AM   #38
ECSTuning
ECSTuning's Avatar
My Ride: BMW
As long as you keep the thread on the coils coated in a grease, they should be fine. What most people are concerned about are not the housing rusting away, but the threads corroding to the point where you will not be able to adjust them.
So as long as they are coated there shouldn't be any problem. FK does not warranty rust, nor does any suspension manufacture that I know of.
Please let me know if you have any questions! Feel free to shoot me a PM or email.
Cheers,
Joe
800.924.5172
Old 04-01-2010, 10:48 AM   #39
glovesoff
My Ride: 1999 328i
How often do the threads need coated? How hard is it to get to the coils to spray them once the c/o's are on the car... do you just have to take the wheels off to get to them?
And to confirm, there is no worry of rust on the coil springs or housings?
Old 04-01-2010, 10:54 AM   #40
ECSTuning
ECSTuning's Avatar
My Ride: BMW
I would check them every spring and fall just to be safe, using your judgment. You will want to take the wheels off yes, if you need to respray them.
They will not rust any more then any of your stock suspension components.
Best,
Joe
800.924.5172
