Old 01-06-2010, 05:58 PM   #1
Nightridr27
My Ride: 328i
is it normal for smoke to be coming out of the exhaust and from the hood if i have a leak in the valve cover gasket area?
Nightridr27 is offline   Reply With Quote
Old 01-06-2010, 07:04 PM   #2
///Orient3
My Ride: can't be defined
I'm not trying to be condescending, but burning oil does smoke, doesn't it?
[url=http://photos.e46fanatics.com/showphoto.php/photo/90077]
///Orient3 is offline   Reply With Quote
Old 01-06-2010, 08:38 PM   #3
Nightridr27
My Ride: 328i
no its all good im just trying to see if its i have a leak in the vcg for the smoke to also be coming out from the under the car or towards the back?
Old 01-07-2010, 12:15 AM   #4
95blkmax
My Ride: 00 BMW 328i
Send a message via AIM to 95blkmax
If the leak is really bad, then you may be having a slow drip at a corner or something. That may be causing the oil to fall right on your headers/ catalytics and thus burn up.
Put it this way, if you have never changed your VC gasket, and you have a 99-01... you should change it, chances are it needs to be replaced anyways.
Hi, my name is 95BlkMax, and I am a Boostaholic
"DANGER TO MANIFOLD!!!!" O_o!
95blkmax is offline   Reply With Quote
