DIY: Starter Replacement...Finally!!! - Page 3 - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Thread Tools Search this Thread Rating: Thread Rating: 56 votes, 5.00 average. Display Modes
Old 10-05-2010, 06:25 PM   #41
AtlantaViking
My Ride: 03 330CIC
I've been lurking around here for too long without saying thanks - but this starter thread saved my bacon.
A real "thank you" because I was ready to start pulling the intake manifold to pull the starter out. But going at from beneath was the trick. Still a pain for sure but definitely the preferred method.
Just an FYI, my starter problems were not the typical ones. As a matter of fact, I can't find any record of anyone else running into it in an E46. In my case, the car would start fine but as I backed down the driveway (a decline) when I would get to the steepest part this really loud rattling racket started and varied with engine speed. It sounded like marbles in the oil pan. After sitting there for 30 minutes running through all of the variables, it finally hit me. The starter gear was hitting the flywheel. Soooo....when I finally got the starter out I had to confirm my suspicions and sure enough - the spring that holds the starter gear in place until the bendix throws it to the flywheel had broken. The gear would just slide back and forth on the shaft. Thats the first time I've ever seen that happen. But maybe some poor soul will come upon this thread with a random google search and find the answer to a similar problem. I say that because its a weird one in my book.
Thanks again for the post though OP. Great job and REALLY appreciated.
AtlantaViking is offline   Reply With Quote
Old 10-24-2010, 12:17 PM   #42
Texas Mike
My Ride: 2003 330ci
Great write-up, just finished replacing my starter. This DIY made it much easier. Removing the fuel filter cover makes all the difference IMHO for getting to the bottom bolt.
Thanks again for taking the time to put this together.
2003 330 CI
Vanos Seal Mod
Bluetooth
BMW Ipod
Texas Mike is offline   Reply With Quote
Old 11-29-2010, 07:29 PM   #43
jbl_91762
My Ride: 01 330i BLK Sedan
Great write up for an automatic, but it will not be of help for manual. Ive got the car up took everything out as per the DIY but cant locate the inner bolt for the life of me. damn 2 hours into it and I cant figure it out. Also searched our site and found an M3 and they had to remove the entire manifold. Looks like manual trannys have to do the same Im tempted to take it to a shop
jbl_91762 is offline   Reply With Quote
Old 11-30-2010, 08:33 AM   #44
newtuner
My Ride: '04 330CI, M package
Sorry to hear your having troubles, did you check to see if there is a different starter for a car with an auto or manual tranny? I would think the starters would be pretty much the same, that second bolt should be there in and around the same place.
newtuner is offline   Reply With Quote
Old 12-02-2010, 08:57 AM   #45
jgold47
My Ride: 2004 X5 3.0
I think this is actually somewhat common. I know a couple of other people who have had this but manifesting itself as a start up screech on cold days, basically the spring doesn't retract quickly enough.
Religion, Politics, and which oil is the best to use. Three things never to be discussed in polite company...
my about me link
http://forum.e46fanatics.com/showthread.php?t=791566
jgold47 is offline   Reply With Quote
Old 12-19-2010, 02:04 PM   #46
KILLAJON
My Ride: 2004 bmw 325ci
good thread
KILLAJON is offline   Reply With Quote
Old 01-15-2011, 12:50 PM   #47
dxi_3
My Ride: 325xi
This DIY worked for 6spd manual
I was just helping a friend do this on his 330Ci 6 speed. We definitely did not have to take off the manifold. Everything was pretty much the same as newtuner explains (thanks for the write up!). We got the new one in with the wires on it, but then realized that it didn't have threaded holes like the old one did!
Do some e46s have starters bolting to the block (no threads in starter)?
Either way, it's always smart to double check this stupid stuff prior to installing.
dxi_3 is offline   Reply With Quote
Old 01-20-2011, 01:47 PM   #48
skatetokil
My Ride: 03 325xi
Anybody know if the procedure is the same on an xi auto?
A local shop just quoted me $775 to do the work and I don't know if I can stomach that.
skatetokil is offline   Reply With Quote
Old 03-18-2011, 01:52 AM   #49
tice123
My Ride: 2003 325i
Newtuner, I seriously worship the ground you walk on! Thank you so much for do this. There is nothing else out there. This is it. You are awesome! Thank you.
tice123 is offline   Reply With Quote
Old 04-16-2011, 01:54 PM   #50
Cobra
My Ride: '00 328i & '06 R6S
thanks for a great write-up! may be attempting this soon...
Cobra is offline   Reply With Quote
Old 04-30-2011, 03:05 AM   #51
LeTz MoB Inc.
My Ride: 93' 325is/ 00' 328i
Send a message via AIM to LeTz MoB Inc.
Thanks, will be trying this out this weekend.
I was going to get an independent mechanic to do it, but even they become costly. So, I am deciding to have this be my first DIY... I am not totally foreign to car mechanics, but it is hard to find the time....
I will be working on 328i 2000. Should work fine...
LeTz MoB Inc. is offline   Reply With Quote
Old 07-30-2011, 04:34 PM   #52
jlb37388
My Ride: 2000 323i
I replaced my clutch in my 2000 323 today, I had to take a break.. everything went fairly straight forward except getting the starter to go back on the alignment dowel pin...that has been the biggest PITA! If I can ever get this starter to seat on the pin correctly all left to do is reconnect the drive shaft, should put new starter on since I have gone through all this, would hate for starter to go out next week, rather pull trans again if didn't have to deal with the starter.....
jlb37388 is offline   Reply With Quote
Old 07-31-2011, 03:36 AM   #53
Dan330Ci~
My Ride: 330Ci Clubsport
I just had to use this DIY, thanks. Had a bit of trouble getting the starter off the pin but after that it was easy.
'04 330Ci Clubsport | Estoril Blue | 6MT | Black Leather/Silver Cube
Turner Motorsport | Ground Control | Stett Performance | Moroso | Powerflex | Meyle HD | Goodridge
Dan330Ci~ is offline   Reply With Quote
Old 08-19-2011, 09:28 AM   #54
325xit2003bt
My Ride: 2003 325xit
I just completed the starter replacement in my 03 325xit. I could not for the life of me how get to the bottom bolt from underneath the car.
What I did was the following:
I took a 3/8 box wrench that has a slight offset and cut off.the open end side. I then wrapped some silicone tape around the end that I cut off to protect myself from the sharp edge and the hold it just snug enough in a 1/2" x 18" pipe that I used for leverage. With this set up I was able to get to both top bolts pretty easily.
The issue I had was that the tranny had a flange that was in the way of the extension/wobble combo. I am not sure if this is because of it being an xi/xit or not. But just as the pictures show the new starter was a little bigger but fit just fine.
Thank you for the thread and writeup it saved me $700.
325xit2003bt is offline   Reply With Quote
Old 08-19-2011, 09:11 PM   #55
black325xi
My Ride: 03 325xi
Just did this PIA job on a 2003 325xi. This article was get help; Thanks!!
A couple of things I learned. To get to the lower starter bolt, take a micro-racheting 3/8" box end wrench and bend it in a vise from the standard 15 degree offset to about 35 degrees. This allows you to reach the bottom bolt from the starter side. When having trouble getting the starter on the alignment pin, first get some emery cloth and polish the pin and the hole. If that does not work, run a drill bit in the starter hole that is .001/.002 larger than the hole. Polish the hole and no more issues.
black325xi is offline   Reply With Quote
Old 08-20-2011, 04:13 PM   #56
ahyie323i
My Ride: 323i
good job!
ahyie323i is offline   Reply With Quote
Old 09-02-2011, 09:19 AM   #57
curt2199
My Ride: 05 BMW 325i
Hey guys, I have an 05 325i (2.5L) that was giving me increasingly random no starts and the battery was good so I am in the process of changing out the starter. I just wanted to let you know that at least on mine, it is possible to remove the starter from the top of the car with minimal tools.
I followed the steps in this tutorial up to removing the heater hoses. That was probably the most irritating part because the hoses were stuck on and eventually after breaking the seal with a flathead, one came flying off and covered my face with anti-freeze. So be careful there, however after that, I could see the starter bolts and knew it was possible to get them from there. I used a short 3/8" wrench and a long 1/2" wrench attached as a breaker/extension (if you've never done this, hook then closed end of the 1/2" to the open end of the 3/8") and broke both bolts loose from the top... while holding a small led flashlight (I know, pure talent, lol). Anyway, they broke loose fine and then I just used the short 3/8" to slowly loosen each one with the small turn radius you have. I probably spent a half hour just turning the two bolts but eventually they were finger loose. Now I'm 6'4", 245lbs so I have big hands and forearms and I was able to do this, so just about anyone should be able to.
Once I had the two bolts out, I grabbed the starter with my right hand through the hole exposed by moving the heater hoses and rocked it up and down and wiggled it around and it broke free. Then I turned it so I could get a socket and 3/8" long handled pivoting head socket wrench on the large positive nut and loosened it, then took it off with my fingers (13 or 15mm). Then turned the starter so the wires/solenoid were facing up and removed the other two wires (8mm and 10mm, I think) with a small 1/4" drive socket wrench.
Now that I had the starter loose, I wasn't about to squeeze myself under the car and go removing all that crap to get it out. If you turn the starter so that the bellhousing (starter gear) is facing up, you can actually wiggle it up through the hole exposed by unhooking the heater hoses. It is a little tight but if you go slow and feel where it's catching and turn it a little here and there, it will come out! I got the starter out from only the top of the car with only a few basic wrenches and sockets in 2 hours from start to finish, in the dark while holding a small led flash light. Except when turning the starter bolts, I had to use both hands to hold and turn the wrench on the bolts but you that can be done with just some good left/right hand coordination.
Now the new starter will be here today so I'm assuming it will go in easier than the old one came out so I'm shooting for under 4 hours for the entire process!
curt2199 is offline   Reply With Quote
Old 09-03-2011, 12:55 PM   #58
e46allday
My Ride: 01 325ci
Everything is pretty simple and straight forward except im having problems with the alignment pin...has anyone had starter spin but not turn over motor...
e46allday is offline   Reply With Quote
Old 09-03-2011, 08:17 PM   #59
cullenj
My Ride: 04 330Ci
Replacing mine this weekend because of starter spinning without engagement mostly when cool. 6 hours out and hopefully just a couple in tomorrow. Newtuner rocks!
cullenj is offline   Reply With Quote
Old 09-12-2011, 05:12 PM   #60
dmast
My Ride: 330ci
I'm now going here too. I was having an intermitant problem with the motor spinning and not engaging the fly wheel. That problem has gone away and now the pinon is not fully retracting and rubbing the flywheel while the engine is running(I think). Sounds like a couple of bolts rattling around in a spinning can!!!
My 2001 330ci has 2 hoses going to the heater core and they are right above where I need to access the mounting bolts. I want to just loosed the band clamps and pull them out of the way. Anyone know if this would be a problem???
dmast is offline   Reply With Quote
